zelogik 0 Posted January 26, 2017 Posted January 26, 2017 Hi, I have configured tvheadend, the live tv, work right, even the timeshift option. For version: It's an turnkey lxc container inside proxmox. But I can't record at all. tvheadend and Emby are configured to writing inside a nfs mount. (same path on both ie;/mnt/Node/public/Records/), and right seem ok. And I getting a full server log (and plenty /var/lib/emby-server/root/default/Recording[1-11...111]) Version: 3.1.2.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.4.35.1 64-Bit OS: True 64-Bit Process: True Mono: 4.6.2 (Stable 4.6.2.7/08fd525 Mon Nov 28 20:21:32 UTC 2016) Processor count: 1 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.IO.PathTooLongException: Path is too long. Path: /var/lib/emby-server/root/default/Recordings111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111 at System.IO.Directory.CreateDirectoriesInternal (System.String path) [0x00070] in <8f2c484307284b51944a1a13a14c0266>:0 at System.IO.Directory.CreateDirectory (System.String path) [0x000a4] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Common.Implementations.IO.ManagedFileSystem.CreateDirectory (System.String path) [0x00000] in <bef7798f4baf4a2cbd193bda78100cb9>:0 at Emby.Server.Implementations.Library.LibraryManager.AddVirtualFolder (System.String name, System.String collectionType, MediaBrowser.Model.Configuration.LibraryOptions options, System.Boolean refreshLibrary) [0x000e9] in <94cb9849d4534920b1b6cc233e9f2dbd>:0 at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.CreateRecordingFoldersInternal () [0x000eb] in <94cb9849d4534920b1b6cc233e9f2dbd>:0 System.IO.PathTooLongException at System.IO.Directory.CreateDirectoriesInternal (System.String path) [0x00070] in <8f2c484307284b51944a1a13a14c0266>:0 at System.IO.Directory.CreateDirectory (System.String path) [0x000a4] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Common.Implementations.IO.ManagedFileSystem.CreateDirectory (System.String path) [0x00000] in <bef7798f4baf4a2cbd193bda78100cb9>:0 at Emby.Server.Implementations.Library.LibraryManager.AddVirtualFolder (System.String name, System.String collectionType, MediaBrowser.Model.Configuration.LibraryOptions options, System.Boolean refreshLibrary) [0x000e9] in <94cb9849d4534920b1b6cc233e9f2dbd>:0 at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.CreateRecordingFoldersInternal () [0x000eb] in <94cb9849d4534920b1b6cc233e9f2dbd>:0 2017-01-26 14:13:13.5288 Error App: Error creating virtual folder *** Error Report *** So ... I hope my today emby premiere purchase worth it ;-)
Luke 42244 Posted January 26, 2017 Posted January 26, 2017 Hi, welcome. This issue is resolved for the next release of Emby Server. For a quick workaround, go into live tv settings and remove the trailing slash from the recording path.
zelogik 0 Posted January 26, 2017 Author Posted January 26, 2017 Hi, Thanks Luke, removing completely the recording path in Emby and leave tvheadend set it correctly have worked wonderfully But with that issue, I have seen that the "restart" button in the dashboard stop the daemon, but don't restart it... have you already logged that? Or i need to sent a complete log ?
Luke 42244 Posted January 26, 2017 Posted January 26, 2017 Yes please send a log, as we're not aware of any issues with that. Thanks.
zelogik 0 Posted January 26, 2017 Author Posted January 26, 2017 (edited) It's enought ?? don't think so, so don't hesitate for another thing I can do edit: Oups forget to click on the add Log.txt Edited January 27, 2017 by zelogik
zelogik 0 Posted January 26, 2017 Author Posted January 26, 2017 Each time I've got a: service emby-server status [FAIL] emby-server is not running .... failed!
zelogik 0 Posted January 27, 2017 Author Posted January 27, 2017 @@Luke, just an update, as restart button don't work ... Log (1).txt
Luke 42244 Posted January 27, 2017 Posted January 27, 2017 Thanks for the report. We'll do some testing.
