Abobader 3485 Posted January 24, 2017 Posted January 24, 2017 1.0.20 has launched. Enjoy Well done! Problem with subtitles is now fixed. Still transcode 4k title as I just test it. My best
Luke 42240 Posted January 24, 2017 Posted January 24, 2017 Thanks. We'll need to see an example of the 4k transcode. thanks.
SamES 1084 Posted January 24, 2017 Posted January 24, 2017 Well done! Problem with subtitles is now fixed. Still transcode 4k title as I just test it. My best 4K has much higher bitrates, so this may be your problem, especially on wireless. In the app settings try changing the Max bitrate from Auto to 4k - 80mbps and see if that fixes it. 1
Abobader 3485 Posted January 24, 2017 Author Posted January 24, 2017 Good day, Thanks. We'll need to see an example of the 4k transcode. thanks. Here is the transcode file: ffmpeg-transcode-a11a0c63-c0fc-477f-a5ac-ca919444b97c.txt 4K has much higher bitrates, so this may be your problem, especially on wireless. In the app settings try changing the Max bitrate from Auto to 4k - 80mbps and see if that fixes it. This on wired lan gb switch, I will test the setting and report back. My best
SamES 1084 Posted January 24, 2017 Posted January 24, 2017 Looks like Auto bitrate detection may be limiting to ~32Mbs, file is 61Mbs. I think forcing to 80Mbs may stop the transcoding but you may get buffering.
SamES 1084 Posted January 24, 2017 Posted January 24, 2017 You can also make sure Auto is actually selected in the Max Bitrate setting. If you change the bitrate via he OSD while playing an item it will actually change this setting for everything. It may not actually be set to auto any more, you need to go into settings and change it back to auto
Abobader 3485 Posted January 24, 2017 Author Posted January 24, 2017 Looks like Auto bitrate detection may be limiting to ~32Mbs, file is 61Mbs. I think forcing to 80Mbs may stop the transcoding but you may get buffering. Good day, I setup to 80, but now from now and then busy circle start to happens, do you want the log for this? My best
Abobader 3485 Posted January 24, 2017 Author Posted January 24, 2017 Strange, as at emby dash, it say it direct play:
Abobader 3485 Posted January 25, 2017 Author Posted January 25, 2017 I split these posts so I can still testing and provide more feedback. 2
Abobader 3485 Posted January 25, 2017 Author Posted January 25, 2017 Good day, I forgot to mention that this tv as my pc monitor, 50 inch, the model: UA50KU7000K Now with latest emby server: 3.1.6234.27466 dev And the settings: No more busy circle and the play went very smooth, but still transcoding for 4K title, here the log: ffmpeg-transcode-05fdc335-8409-4055-812d-f4a3c08c4e33.txt My best
Luke 42240 Posted January 26, 2017 Posted January 26, 2017 @@Abobader this one is due to the truehd audio. 1
Abobader 3485 Posted January 26, 2017 Author Posted January 26, 2017 Well done Luke! I will test today with same one before as "Deadpool".
Abobader 3485 Posted January 26, 2017 Author Posted January 26, 2017 Good day, Emby server: 3.1.6235.2624 dev Same setting as in post #10 Thing not good this time, always busy circle and come a lots with titles I tried, I could not find transcode logs at the log folder, so here the emby complete log file: server-63621045959.txt My best
Luke 42240 Posted January 26, 2017 Posted January 26, 2017 In this case, you're getting what you asked for. You forced your own bitrate in settings, but it's probably too much for the tv or network connection.
Abobader 3485 Posted January 26, 2017 Author Posted January 26, 2017 Good day Luke, I will role out the tv, because it can handle 4k without problem, i test that with direct usb and play / test 4k titles I run more test but from now, it not my lan issue, but test and run some monitor software will not hurt anything My best
Luke 42240 Posted January 26, 2017 Posted January 26, 2017 It can handle 4K but most streaming 4k is a lower bitrate than your bluray rips. 1
Abobader 3485 Posted January 26, 2017 Author Posted January 26, 2017 It can handle 4K but most streaming 4k is a lower bitrate than your bluray rips. Good point buddy, and fully understand the issue here. I will see if I can find a fix for the lan issue.
