maximumentropy 24 Posted January 25, 2017 Posted January 25, 2017 In the web client, there used to be a simple way to navigate to the previous or next season of a TV show. With recent versions, including 3.1.2.0 which I am currently running, I need to navigate back to the show and then select the desired season. I would like for the previous/next season navigation functionality (or something like it) to be re-implemented. Thanks! 1
Happy2Play 9813 Posted January 25, 2017 Posted January 25, 2017 There needs to be buttons on the left and right of the episode slider to go back or forward a season.
Koleckai Silvestri 1154 Posted January 25, 2017 Posted January 25, 2017 Don't even know why a different screen for seasons is needed... Show the Series as it is now. Show the seasons like they are. Under the posters show the episode list starting at the first available season. When the user clicks on a Season poster, show the episodes for that Season.
Luke 42246 Posted January 25, 2017 Posted January 25, 2017 Don't even know why a different screen for seasons is needed... Show the Series as it is now. Show the seasons like they are. Under the posters show the episode list starting at the first available season. When the user clicks on a Season poster, show the episodes for that Season. In other words you're suggesting just flatten them to avoid the drill down?
invertedknife 13 Posted January 25, 2017 Posted January 25, 2017 is in possible to get his back in the new UI? the old UI had the arrows that allowed you to do so. 1
Koleckai Silvestri 1154 Posted January 25, 2017 Posted January 25, 2017 I am suggesting that between the Season and Cast & Crew rows, there would be an Episode row. If no season is selected, then it should display the episodes from Season 1. When a different Season is clicked on then its episodes are displayed via AJAX.
Happy2Play 9813 Posted January 25, 2017 Posted January 25, 2017 I am suggesting that between the Season and Cast & Crew rows, there would be an Episode row. If no season is selected, then it should display the episodes from Season 1. When a different Season is clicked on then its episodes are displayed via AJAX. That is fine adding another view point, but still doesn't fix once you enter an episode you have back out to get to the next/previous season. 1
Luke 42246 Posted January 26, 2017 Posted January 26, 2017 I am suggesting that between the Season and Cast & Crew rows, there would be an Episode row. If no season is selected, then it should display the episodes from Season 1. When a different Season is clicked on then its episodes are displayed via AJAX. Ok I see, so basically you want to avoid the navigation.
Koleckai Silvestri 1154 Posted January 26, 2017 Posted January 26, 2017 Ok I see, so basically you want to avoid the navigation. Less clicks and a more modern interface, yes.
maximumentropy 24 Posted January 28, 2017 Author Posted January 28, 2017 I like the current season display because it allows me to take in a lot more information about a season in a glance without scrolling back and forth. I think the existing display (or something like it) should be preserved. It would be OK with me if it were outside the normal navigation and took an extra step to get there. This would basically be what @Koleckai Silvestri suggested, with the in-episode season slider having a hot link to the season-at-a-glance display.
chowbok 136 Posted October 22, 2018 Posted October 22, 2018 This went a little off-topic. I like the per-season pages, but, like the original poster, I'd like to have previous/next navigational buttons on them. Can these be added? Doesn't seem like it'd be a difficult change...
