Blueeyiz702 223 Posted January 25, 2017 Posted January 25, 2017 When i try to identify a actor image that does not show on movie,and input imdb id it keeps returning a blank like actor does not exist and it has to be done manually. Its happened multiple time over past couple of weeks. Even tho there is a imdb id for Sienna Nanue when i input to identify with id and name it does not work and image stays blank?
Koleckai Silvestri 1154 Posted January 25, 2017 Posted January 25, 2017 Emby doesnt pull information from IMDB. Entering the id only allows cross reference with its metadata providers. It doesn't guarantee updated information or images.
Luke 42241 Posted January 25, 2017 Posted January 25, 2017 Try using the identify feature and fill in the MovieDb id.
Happy2Play 9811 Posted January 25, 2017 Posted January 25, 2017 You have to remember no information or images ever comes directly from IMDB.
Blueeyiz702 223 Posted January 25, 2017 Author Posted January 25, 2017 You have to remember no information or images ever comes directly from IMDB. So then is there a way to fix the problem,so i don't have to go through and manually do the one's that do not so up. And Luke i tried that to same issue.
Happy2Play 9811 Posted January 26, 2017 Posted January 26, 2017 (edited) There is no image for "Sennia Nanue" on TMDB so you would have to upload one directly to your server or help the community and upload one at TMDB. People image sources Edited January 26, 2017 by Happy2Play
Happy2Play 9811 Posted January 26, 2017 Posted January 26, 2017 (edited) @@Luke When you search for a Person via IMDB id we get a error (422) from TMDB. 422 Invalid date range: Should be a range no longer than 14 days. 2017-01-25 16:43:08.4918 Error HttpClient: Error getting response from https://api.themoviedb.org/3/search/person?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query= *** Error Report *** Version: 3.1.285.0 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\System System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (422). at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__20.MoveNext() ---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (422). at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)<--- System.AggregateException at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__20.MoveNext() InnerException: System.Net.WebException System.Net.WebException: The remote server returned an error: (422). at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) Was going to ask why IMDB ids returned no results from TMDB (when results are available) but saw the error in the log when searching, note there is no query info. Edited January 26, 2017 by Happy2Play
Happy2Play 9811 Posted January 26, 2017 Posted January 26, 2017 Updated most of the missing images for that movie. 1
Luke 42241 Posted January 26, 2017 Posted January 26, 2017 We should just remove Imdb from the person Identify form altogether. I tested person identify via MovieDB Id and it worked just fine. 1
Happy2Play 9811 Posted January 26, 2017 Posted January 26, 2017 We should just remove Imdb from the person Identify form altogether. I tested person identify via MovieDB Id and it worked just fine. What is the purpose of the TV.com ID also?
Luke 42241 Posted January 26, 2017 Posted January 26, 2017 To be able to show the link on the detail screen. I'm not really sure if anyone cares about tv.com anymore.
Happy2Play 9811 Posted January 26, 2017 Posted January 26, 2017 I don't see who would provide it TMDB or TVDB. Don't see external options at either unless I am just blind.
Blueeyiz702 223 Posted January 27, 2017 Author Posted January 27, 2017 Updated most of the missing images for that movie. I added images to the database,and it still won't update them? So there must be something going wrong
Happy2Play 9811 Posted January 27, 2017 Posted January 27, 2017 (edited) Sometimes it take awhile for them to be processed and be available via the API. They are always immediately visible on the website. I have 4 images that still haven't updated. Not sure of TMDB's policy but I know Fanart has a 7 day wait for new images unless you have a api key or are a vip member. Requests to fanart without a personal API key return images that were approved over 7 days ago. With a personal API key that drops to 48 hours and if you are also a fanart VIP member that will further drop to around 10 minutes. Edited January 27, 2017 by Happy2Play
Luke 42241 Posted January 27, 2017 Posted January 27, 2017 In addition to that there is a caching layer in emby server that will last for up to 3 days.
Happy2Play 9811 Posted January 27, 2017 Posted January 27, 2017 In addition to that there is a caching layer in emby server that will last for up to 3 days. Even if you use Refresh or Identify?
