twinkybot 3 Posted January 23, 2017 Posted January 23, 2017 Hi there, I have an Ubuntu 16.04.1 system with Emby 3.1.2.0. my playback was working just fine when I had the Server connected via HDMI to the AV Receiver Marantz SR7007. I needed to re-locate the server so the only connection is now the LAN. Since moving the playback is broken and I am getting the following log entries: 2017-01-24 00:18:14.1834 Info HttpServer: HTTP POST http://localhost:8096/Sessions/ffb30e5672d6215cdd02a581d347b63e/Playing?ItemIds=e8d3fd110ff91e7955d6284c311dc590%2C1f57f2975503c7b2114437f6e416bbc1%2Ce09edee0f7f5fa62bf077b2746857bb8%2C8829bbb6b810be61ccf2ba15b32cceca%2Ca9ff155429d4d9650bf07907ad114df0%2Ca341912c2fe959f2d0412ee3e6731e74%2C439f54204324b06ef1d6f61771488f32%2C4a47ea3ca3a967a7316ba26ad2e600d9%2Cf45fd45a696c666d2f3679d81b304e08%2Caf8050e89c0e4d92baf6c4882a0fc126%2C201dde9afbf53cc83cf7f500275a9ea6%2C47c89e4dbe21d0b2f6e9f0209ea9c33c%2C5ea47f19ae8865fdc6670e28fa3cc596&PlayCommand=PlayNow. UserAgent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:50.0) Gecko/20100101 Firefox/50.0 2017-01-24 00:18:14.1981 Info Dlna: No matching device profile found. The default will need to be used. DeviceDescription: FriendlyName:Marantz Manufacturer:Marantz ManufacturerUrl:http://www.marantz.com ModelDescription:AV SURROUND RECEIVER ModelName:*SR7007 ModelNumber:7007 ModelUrl:http://www.marantz.com/ SerialNumber:000678141FFC 2017-01-24 00:18:14.2045 Error HttpServer: Error processing request *** Error Report *** Version: 3.1.2.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.4.0.59 64-Bit OS: True 64-Bit Process: True Mono: 4.6.2 (Stable 4.6.2.7/08fd525 Mon Nov 28 20:49:26 UTC 2016) Processor count: 3 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.AggregateException: One or more errors occurred. ---> System.ArgumentNullException: Value cannot be null. at MediaBrowser.Model.Dlna.StreamInfo.GetUrl (System.String baseUrl, System.String queryString) [0x0000b] in <0e4969644d9f4adf89a748b5e0a9958b>:0 at MediaBrowser.Model.Dlna.StreamInfo.ToDlnaUrl (System.String baseUrl, System.String accessToken) [0x00020] in <0e4969644d9f4adf89a748b5e0a9958b>:0 at Emby.Dlna.PlayTo.PlayToController.CreatePlaylistItem (MediaBrowser.Controller.Entities.BaseItem item, MediaBrowser.Controller.Entities.User user, System.Int64 startPostionTicks, System.String mediaSourceId, System.Nullable`1[T] audioStreamIndex, System.Nullable`1[T] subtitleStreamIndex) [0x0008d] in <31e5cd4b429a47d0a6e20229b25a8631>:0 at Emby.Dlna.PlayTo.PlayToController+<SendPlayCommand>c__async5.MoveNext () [0x001b9] in <31e5cd4b429a47d0a6e20229b25a8631>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.Session.SessionManager+<SendPlayCommand>c__asyncC.MoveNext () [0x005ff] in <94cb9849d4534920b1b6cc233e9f2dbd>:0 --- End of inner exception stack trace --- at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, System.Int32 millisecondsTimeout, System.Threading.CancellationToken cancellationToken) [0x00242] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, System.Int32 millisecondsTimeout) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at MediaBrowser.Api.Session.SessionsService.Post (MediaBrowser.Api.Session.Play request) [0x0006f] in <133ca9beab984800b26689b492cca831>:0 at (wrapper dynamic-method) System.Object:lambda_method (System.Runtime.CompilerServices.Closure,object,object) at ServiceStack.Host.ServiceExecGeneral+<CreateExecFn>c__AnonStorey2.<>m__0 (System.Object service, System.Object request) [0x00000] in <eaf6c545840d4e8a8d2971c7a6b76dd0>:0 at ServiceStack.Host.ServiceExecGeneral+<Execute>c__async0.MoveNext () [0x0010a] in <eaf6c545840d4e8a8d2971c7a6b76dd0>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at ServiceStack.Host.ServiceController+<Execute>c__async0.MoveNext () [0x00142] in <eaf6c545840d4e8a8d2971c7a6b76dd0>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at ServiceStack.Host.RestHandler+<ProcessRequestAsync>c__async1.MoveNext () [0x00167] in <eaf6c545840d4e8a8d2971c7a6b76dd0>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>c__async0.MoveNext () [0x00668] in <94cb9849d4534920b1b6cc233e9f2dbd>:0 ---> (Inner Exception #0) System.ArgumentNullException: Value cannot be null. at MediaBrowser.Model.Dlna.StreamInfo.GetUrl (System.String baseUrl, System.String queryString) [0x0000b] in <0e4969644d9f4adf89a748b5e0a9958b>:0 at MediaBrowser.Model.Dlna.StreamInfo.ToDlnaUrl (System.String baseUrl, System.String accessToken) [0x00020] in <0e4969644d9f4adf89a748b5e0a9958b>:0 at Emby.Dlna.PlayTo.PlayToController.CreatePlaylistItem (MediaBrowser.Controller.Entities.BaseItem item, MediaBrowser.Controller.Entities.User user, System.Int64 startPostionTicks, System.String mediaSourceId, System.Nullable`1[T] audioStreamIndex, System.Nullable`1[T] subtitleStreamIndex) [0x0008d] in <31e5cd4b429a47d0a6e20229b25a8631>:0 at Emby.Dlna.PlayTo.PlayToController+<SendPlayCommand>c__async5.MoveNext () [0x001b9] in <31e5cd4b429a47d0a6e20229b25a8631>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.Session.SessionManager+<SendPlayCommand>c__asyncC.MoveNext () [0x005ff] in <94cb9849d4534920b1b6cc233e9f2dbd>:0 <--- System.AggregateException at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, System.Int32 millisecondsTimeout, System.Threading.CancellationToken cancellationToken) [0x00242] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, System.Int32 millisecondsTimeout) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at MediaBrowser.Api.Session.SessionsService.Post (MediaBrowser.Api.Session.Play request) [0x0006f] in <133ca9beab984800b26689b492cca831>:0 at (wrapper dynamic-method) System.Object:lambda_method (System.Runtime.CompilerServices.Closure,object,object) at ServiceStack.Host.ServiceExecGeneral+<CreateExecFn>c__AnonStorey2.<>m__0 (System.Object service, System.Object request) [0x00000] in <eaf6c545840d4e8a8d2971c7a6b76dd0>:0 at ServiceStack.Host.ServiceExecGeneral+<Execute>c__async0.MoveNext () [0x0010a] in <eaf6c545840d4e8a8d2971c7a6b76dd0>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at ServiceStack.Host.ServiceController+<Execute>c__async0.MoveNext () [0x00142] in <eaf6c545840d4e8a8d2971c7a6b76dd0>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at ServiceStack.Host.RestHandler+<ProcessRequestAsync>c__async1.MoveNext () [0x00167] in <eaf6c545840d4e8a8d2971c7a6b76dd0>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>c__async0.MoveNext () [0x00668] in <94cb9849d4534920b1b6cc233e9f2dbd>:0 InnerException: System.ArgumentNullException System.ArgumentNullException: Value cannot be null. at MediaBrowser.Model.Dlna.StreamInfo.GetUrl (System.String baseUrl, System.String queryString) [0x0000b] in <0e4969644d9f4adf89a748b5e0a9958b>:0 at MediaBrowser.Model.Dlna.StreamInfo.ToDlnaUrl (System.String baseUrl, System.String accessToken) [0x00020] in <0e4969644d9f4adf89a748b5e0a9958b>:0 at Emby.Dlna.PlayTo.PlayToController.CreatePlaylistItem (MediaBrowser.Controller.Entities.BaseItem item, MediaBrowser.Controller.Entities.User user, System.Int64 startPostionTicks, System.String mediaSourceId, System.Nullable`1[T] audioStreamIndex, System.Nullable`1[T] subtitleStreamIndex) [0x0008d] in <31e5cd4b429a47d0a6e20229b25a8631>:0 at Emby.Dlna.PlayTo.PlayToController+<SendPlayCommand>c__async5.MoveNext () [0x001b9] in <31e5cd4b429a47d0a6e20229b25a8631>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.Session.SessionManager+<SendPlayCommand>c__asyncC.MoveNext () [0x005ff] in <94cb9849d4534920b1b6cc233e9f2dbd>:0 at MediaBrowser.Model.Dlna.StreamInfo.GetUrl (System.String baseUrl, System.String queryString) [0x0000b] in <0e4969644d9f4adf89a748b5e0a9958b>:0 at MediaBrowser.Model.Dlna.StreamInfo.ToDlnaUrl (System.String baseUrl, System.String accessToken) [0x00020] in <0e4969644d9f4adf89a748b5e0a9958b>:0 at Emby.Dlna.PlayTo.PlayToController.CreatePlaylistItem (MediaBrowser.Controller.Entities.BaseItem item, MediaBrowser.Controller.Entities.User user, System.Int64 startPostionTicks, System.String mediaSourceId, System.Nullable`1[T] audioStreamIndex, System.Nullable`1[T] subtitleStreamIndex) [0x0008d] in <31e5cd4b429a47d0a6e20229b25a8631>:0 at Emby.Dlna.PlayTo.PlayToController+<SendPlayCommand>c__async5.MoveNext () [0x001b9] in <31e5cd4b429a47d0a6e20229b25a8631>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.Session.SessionManager+<SendPlayCommand>c__asyncC.MoveNext () [0x005ff] in <94cb9849d4534920b1b6cc233e9f2dbd>:0
Luke 42239 Posted January 24, 2017 Posted January 24, 2017 Hi @@twinkybot can you please attach the complete emby server log? thanks !
twinkybot 3 Posted January 24, 2017 Author Posted January 24, 2017 (edited) Sorry. I simply do not find it. How can I upload an attachment? Ha, hidden on the full editor emby today.log emby yesterday.log Edited January 24, 2017 by twinkybot
twinkybot 3 Posted January 24, 2017 Author Posted January 24, 2017 And BTW nice piece of Software. Thanks
twinkybot 3 Posted January 24, 2017 Author Posted January 24, 2017 (edited) I forgot to mention. I tried the command which is mentioned in the log and got the following output. I do not know if this is related or not. And this attached log has some output in it when I try to show videos on a lan connected Samsung TV. /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Unhandled Exception: System.DllNotFoundException: libembysqlite3.so.0 at (wrapper managed-to-native) SQLitePCL.SQLite3Provider_sqlite3+NativeMethods:sqlite3_libversion_number () at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_libversion_number () [0x00000] in <52410a2b1f7d462f906372c31f57e9ab>:0 at SQLitePCL.raw.SetProvider (SQLitePCL.ISQLite3Provider imp) [0x00000] in <27978e3674a44db399cf097c8ed0098b>:0 at MediaBrowser.Server.Mono.MainClass.SetSqliteProvider () [0x00005] in <1a33f11670cc47eb926a52318aa0f419>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00018] in <1a33f11670cc47eb926a52318aa0f419>:0 [ERROR] FATAL UNHANDLED EXCEPTION: System.DllNotFoundException: libembysqlite3.so.0 at (wrapper managed-to-native) SQLitePCL.SQLite3Provider_sqlite3+NativeMethods:sqlite3_libversion_number () at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_libversion_number () [0x00000] in <52410a2b1f7d462f906372c31f57e9ab>:0 at SQLitePCL.raw.SetProvider (SQLitePCL.ISQLite3Provider imp) [0x00000] in <27978e3674a44db399cf097c8ed0098b>:0 at MediaBrowser.Server.Mono.MainClass.SetSqliteProvider () [0x00005] in <1a33f11670cc47eb926a52318aa0f419>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00018] in <1a33f11670cc47eb926a52318aa0f419>:0 LogWithVideosPlayback_FlashGordon.log Edited January 24, 2017 by twinkybot
Luke 42239 Posted January 24, 2017 Posted January 24, 2017 I think its not detecting your local ip address, however there are improvements for this for the next server release, thanks.
twinkybot 3 Posted January 26, 2017 Author Posted January 26, 2017 Yes with the new version it is working! Great. Although it looked at first like it didn't but I just had to wait for the alive message to be sent it seemed. At first I had no DLNA players available. Cool.
