holdestmade 11 Posted January 22, 2017 Posted January 22, 2017 Been working fine for ages but just noticed the episode thumb is not being fetched and stored locally, everything else is, ie Series and Season images, NFOs etc If I look in the .NFO file it shows a path that is TVDB. If I open Metadata manager and select the episode and then Images, the image pops up in the folder and the .NFO file is amended to loacal image. In settings I have save local metadata set. Any ideas ? TIA Simon
Luke 42197 Posted January 22, 2017 Posted January 22, 2017 Hi, click on the library in server library setup and make sure you have enabled saving metadata to local media folders. Let us know if this helps. Thanks.
holdestmade 11 Posted January 24, 2017 Author Posted January 24, 2017 Thanks Luke, yes that is set. I enabled "Download images in advance" and that seems to have solved it. Don't know why it worked OK before Cheers Simon
ebr 16309 Posted January 24, 2017 Posted January 24, 2017 Thanks Luke, yes that is set. I enabled "Download images in advance" and that seems to have solved it. Don't know why it worked OK before Cheers Simon Why do you feel you need it to do that?
holdestmade 11 Posted January 26, 2017 Author Posted January 26, 2017 Not even sure what that's for but when I enabled it and added an episode, all worked OK. BUT, I have disabled it again and now it works fine without it so not that. Strange, not changed anything. Simon
Luke 42197 Posted January 26, 2017 Posted January 26, 2017 The most important thing is the per-library setting to save metadata into media folders. 1
