saraconnor 2 Posted January 22, 2017 Posted January 22, 2017 (edited) Good mornig, i'm new in this forum , but i'm lover of emby app. My tv samsung ue55es6100 is connected via lan to internet, and everything work fine , youtube, browser, iptv , netflix . yestarday emby disappared , and i can't log in develop mode for reinstall EMBY, when i try to login my tv show "the server is not reachable try later" . I tried to hard factory reset but log in is impossible. what can i do for install emby wich way you recommended me? Via usb is possible? Edited January 22, 2017 by saraconnor
SamES 1084 Posted January 22, 2017 Posted January 22, 2017 Try again to login is develop, follow this guide. but use 82.27.106.58 as the Setting Server IP https://emby.media/community/index.php?/topic/9869-samsung-smart-tv-app-install-instructions/&do=findComment&comment=277346
saraconnor 2 Posted January 22, 2017 Author Posted January 22, 2017 thank you very much but i can't login in develop, because smart hub server is not reachable, i don't now.
SamES 1084 Posted January 22, 2017 Posted January 22, 2017 Oh, so you can't even connect to Smarthub? Does that mean Netflix, etc doesn't work as well?
saraconnor 2 Posted January 22, 2017 Author Posted January 22, 2017 smart hub , netflix , ecc connect to internet, but when i try to login with letter A , i insert user : develop , password : 000000 , press ok , and it show me " server is not reachable, try later" , why? samsung smart app show app etc , but when i try to login , the server is not reachable.
SamES 1084 Posted January 22, 2017 Posted January 22, 2017 That sounds like an issue with the Samsung server. You can wait a while and see if that resolves it. You could try resetting the smart hub (not the TV, just smarthub). This will reset all the apps so you will need to reinstall and configure the ones and you need (which is a bit painful). This may or may not fix the problem, but it might be worth trying.
FrostByte 5453 Posted January 22, 2017 Posted January 22, 2017 Not that this helps much, but I just logged in with develop on my F-series HTS.
saraconnor 2 Posted January 24, 2017 Author Posted January 24, 2017 samsung block the login . only way for resolve is via usb, can you help me for this ? i've 3 samsung tv , in 2 eh5300 the login is ok , on es6100 is not possible , that tv are in one lan. sigh.
SamES 1084 Posted January 24, 2017 Posted January 24, 2017 (edited) Can you try develop again and leave password blank Open SmartHub, A, login as "develop" with no password, Tools, Settings (bottom one), Development (bottom one), Accept, Set IP to your web server/PC, then sync. Edited January 24, 2017 by SamES
saraconnor 2 Posted January 24, 2017 Author Posted January 24, 2017 i try that but the problem is connection to samsung smart hub log ip . thank you for support i must resolve for install emby .
SamES 1084 Posted January 24, 2017 Posted January 24, 2017 So can you get it to log in with "develop" in the bottom corner, or not even this far?
saraconnor 2 Posted January 24, 2017 Author Posted January 24, 2017 yes i press smart on remote , press red letter A , pop up windows were insert user "develop" and pass"000000" , press ok and it show me " server is not reachable, try later". i have 3 samsung tv , in only one lan . 2 tv are logged in develop , the 3th not connect to server for develop. there is a method to backup to another tv and put emby in what does not work?
FrostByte 5453 Posted January 24, 2017 Posted January 24, 2017 (edited) yes i press smart on remote , press red letter A , pop up windows were insert user "develop" and pass"000000" , press ok and it show me " server is not reachable, try later". i have 3 samsung tv , in only one lan . 2 tv are logged in develop , the 3th not connect to server for develop. there is a method to backup to another tv and put emby in what does not work? Have you tried logging on with "develop" but using a blank password as SamES mentioned? I see no reason why this isn't working on just one device in your house, but there really is only one other option and that is to side-load it from USB and then that really isn't ideal because it never really gets installed, just loads in memory and you need to keep the usb plugged in at all times Edited January 24, 2017 by FrostByte
saraconnor 2 Posted January 25, 2017 Author Posted January 25, 2017 thank you so much for support,. i think the problem is in the samsung server , that had banned my mac address for same reason, i don't now. have good day. sigh.
SamES 1084 Posted January 25, 2017 Posted January 25, 2017 I think you should try resetting the smart hub. Not sure why Samsung would block your mac address. I don't know if side-loading by USB with e-series is possible 1
saraconnor 2 Posted January 25, 2017 Author Posted January 25, 2017 i 've read notice about sdk for create samsung smart hub app , i should study wether possible a manual install via this samsung tools.
SamES 1084 Posted January 25, 2017 Posted January 25, 2017 Easiest way is to set up your own web-server and install from there. Basically this is what that version of the SDK does, but in a very long round-about way.
FrostByte 5453 Posted January 25, 2017 Posted January 25, 2017 I believe you still have to log on as develop when using your own web server else the option to enter the IP never shows. 1
saraconnor 2 Posted January 26, 2017 Author Posted January 26, 2017 yes if i can't insert ip in develop mode i'm stalled. Sunday I'll try again to make develop mode, if i will not do well will buy an Android external box.
saraconnor 2 Posted February 1, 2017 Author Posted February 1, 2017 update , i have turn off my tv for 1 day , i do factory reset , i have switch nation usa (>>289<<) for install iptv ecc ecc . but no login and samsung server for login in develop is down it show me " server .....try later........", sigh at this time i must install another app for share my media. thank you for support.goodbye.
saraconnor 2 Posted February 4, 2017 Author Posted February 4, 2017 there is a way for instal emby via usb , same user do another install mode ? Please i need this app on my samsung tv with blocked login.
FrostByte 5453 Posted February 4, 2017 Posted February 4, 2017 (edited) You can sideload it from USB. I have not done it in a long time, but found these instructions posted by someone else 1. Go here: http://173.230.139.54/widgetlist.xml 2. Get the link under the download section 3. Download the file 4. Extract the content on a subfolder of your USB key (like "x:\emby") 5. Plug the key to your TV 6. The app should appear in the app list. As SamES said though that option may not be available on all models. Edited February 4, 2017 by FrostByte 2
saraconnor 2 Posted February 6, 2017 Author Posted February 6, 2017 alpha thank you very much. just yesterday I did a factory reset, Info+Menu+Mute+On...(SWU - Reset , SmartHub Reset ), the TV did the firmware upgrade, by magic everything is back to work. very good support thank you. 2
