PhyberApex 16 Posted January 21, 2017 Posted January 21, 2017 Hi, there seems to be a problem in the syncing process if the season of tvshows are split up in multiple folders in the main library path (which is pretty common for anime as they are often no "seasons" but sequels instead). e.g. I have these two folders in my library - Kore wa Zombie Desu ka? // This is "season 1" - Kore wa Zombie Desu ka? of the Dead // This is "season 2" I then use the metadata manager to tag it acordingly and everything is fine in emby. But in kodi only season 1 shows up for this show. This used to work previously. I do not know which update (kodi/emby) resulted in this behaviour as I had to redo my setup (due to hardware failure). But right now I am using the current Kodi for Android (16.1 "Jarvis") and the up to date version of Emby (3.1.2.0) as well as the up to date stable plugins. Any clue why this behavior changed / how to fix this isue? ~Cheers
Solution Angelblue05 4132 Posted January 21, 2017 Solution Posted January 21, 2017 Run a manual sync (launch the emby for kodi addon). See if it helps. Sent from my iPhone using Tapatalk 1
PhyberApex 16 Posted January 22, 2017 Author Posted January 22, 2017 (edited) Thanks for your suggestion. But it did not help. Still missing seasons.If log files are needed for further analysis I'll gladly provide them.~Cheers UPDATE: I just did check the log files and there was something wrong in my config files apparently. I reinstalled kodi and after having the same behaviour a manual sync did fix the issue. So thank you! Edited January 22, 2017 by PhyberApex
