Catsrules 17 Posted January 20, 2017 Posted January 20, 2017 (edited) It would be really helpful if the user interface would remember where I was when I click the back button.For example lets say I am in a season looking at episodes within the season, there are 12 episodes total. I start at the top of the page and scroll down, to episode 6, click on 6 and find out I really wanted 7 so I tap the back button the page starts at the top again and I need to scroll back down to find episode 7. It would be nice if the app remember the scroll location was at episode 6 so when I click the back button it would take me back to the exact spot I was looking on the page and I could go to episode 7 or 8 easily. This also happens when I am looking though movies and TV series, although it is a little different because it some times works. But it stops after 1 or 2 time and then gets stuck at the last location it worked at. Edited January 21, 2017 by Catsrules 2
Luke 42243 Posted January 20, 2017 Posted January 20, 2017 Thanks for the report, yes this can be improved in a future update.
arrbee99 1836 Posted January 21, 2017 Posted January 21, 2017 And also when looking at Movies, clicking refresh takes you back to Suggestions. Same for TV shows. ...unless that's what you meant in your last sentence.
