tomadam28 0 Posted January 20, 2017 Posted January 20, 2017 I want to set the best picture quality while watching a movie (on Philips TV i can adjust the picture in PIP mode and see the settings immediately with other apps). When i press the setting button on my Philips remote controller, the movie playback stop. And the biggest problem: after set everything and want to resume playback from actual position, i can only start the movie from beginning (No resume button available)
ebr 16337 Posted January 20, 2017 Posted January 20, 2017 It sounds like your TV has its settings implemented as an Android app so it suspends ours when you bring it up. However, that doesn't explain why there would be no resume. Does resume work in other situations (if you just stop the item half way through)? Can you reproduce this and send a log from the app?
