problem with emby kodi plugin on retropi
im having problem with emby plugin on retropi. here are my logs.
20:50:20 275.794373 T:1944437312  NOTICE: special://profile/ is mapped to: special://masterprofile/
20:50:20 275.794525 T:1944437312  NOTICE: -----------------------------------------------------------------------
20:50:20 275.794556 T:1944437312  NOTICE: Starting Kodi (16.1 Git:2016-04-24-b08ce71-dirty). Platform: Linux ARM 32-bit
20:50:20 275.794617 T:1944437312  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
20:50:20 275.794647 T:1944437312  NOTICE: Kodi compiled Apr 24 2016 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
20:50:20 275.794830 T:1944437312  NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.4.38-v7+
20:50:20 275.794891 T:1944437312  NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-release/2.8-xbmc
20:50:20 275.794922 T:1944437312  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
20:50:20 275.794952 T:1944437312  NOTICE: ARM Features: Neon enabled
20:50:20 275.795013 T:1944437312  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
20:50:20 275.795044 T:1944437312  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
20:50:20 275.795074 T:1944437312  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
20:50:20 275.795135 T:1944437312  NOTICE: special://home/ is mapped to: /home/pi/.kodi
20:50:20 275.795166 T:1944437312  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
20:50:20 275.795227 T:1944437312  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
20:50:20 275.795319 T:1944437312  NOTICE: Local hostname: retropie
20:50:20 275.795349 T:1944437312  NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
20:50:20 275.795441 T:1944437312  NOTICE: -----------------------------------------------------------------------
20:50:20 276.348663 T:1944437312   ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanSuspend
20:50:20 276.349426 T:1944437312   ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanHibernate
20:50:20 276.361694 T:1944437312  NOTICE: load settings...
20:50:21 276.503326 T:1944437312  NOTICE: Found 2 Lists of Devices
20:50:21 276.503418 T:1944437312  NOTICE: Enumerated PI devices:
20:50:21 276.503448 T:1944437312  NOTICE:     Device 1
20:50:21 276.503693 T:1944437312  NOTICE:         m_deviceName      : HDMI
20:50:21 276.503723 T:1944437312  NOTICE:         m_displayName     : HDMI
20:50:21 276.503784 T:1944437312  NOTICE:         m_displayNameExtra:
20:50:21 276.503815 T:1944437312  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
20:50:21 276.503845 T:1944437312  NOTICE:         m_channels        : FL,FR
20:50:21 276.503876 T:1944437312  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
20:50:21 276.503906 T:1944437312  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
20:50:21 276.503967 T:1944437312  NOTICE:     Device 2
20:50:21 276.504028 T:1944437312  NOTICE:         m_deviceName      : Analogue
20:50:21 276.504059 T:1944437312  NOTICE:         m_displayName     : Analogue
20:50:21 276.504120 T:1944437312  NOTICE:         m_displayNameExtra:
20:50:21 276.504150 T:1944437312  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
20:50:21 276.504181 T:1944437312  NOTICE:         m_channels        : FL,FR
20:50:21 276.504211 T:1944437312  NOTICE:         m_sampleRates     : 48000
20:50:21 276.504242 T:1944437312  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
20:50:21 276.504272 T:1944437312  NOTICE:     Device 3
20:50:21 276.504333 T:1944437312  NOTICE:         m_deviceName      : Both
20:50:21 276.504395 T:1944437312  NOTICE:         m_displayName     : HDMI and Analogue
20:50:21 276.504425 T:1944437312  NOTICE:         m_displayNameExtra:
20:50:21 276.504456 T:1944437312  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
20:50:21 276.504486 T:1944437312  NOTICE:         m_channels        : FL,FR
20:50:21 276.504547 T:1944437312  NOTICE:         m_sampleRates     : 48000
20:50:21 276.504608 T:1944437312  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
20:50:21 276.504639 T:1944437312  NOTICE: Enumerated ALSA devices:
20:50:21 276.504669 T:1944437312  NOTICE:     Device 1
20:50:21 276.504730 T:1944437312  NOTICE:         m_deviceName      : @
20:50:21 276.504761 T:1944437312  NOTICE:         m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
20:50:21 276.504791 T:1944437312  NOTICE:         m_displayNameExtra:
20:50:21 276.504852 T:1944437312  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
20:50:21 276.504883 T:1944437312  NOTICE:         m_channels        : FL,FR
20:50:21 276.504913 T:1944437312  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000
20:50:21 276.504944 T:1944437312  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
20:50:21 276.566467 T:1944437312  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
20:50:21 276.566772 T:1944437312  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <?xml version="1.0" encoding="UTF-8" ?>
                                            <advancedsettings>
                                              <video>
                                                <defaultplayer>dvdplayer</defaultplayer>
                                                <defaultdvdplayer>dvdplayer</defaultdvdplayer>
                                                <subsdelayrange>120</subsdelayrange>
                                                <busydialogdelayms>750</busydialogdelayms>
                                              </video>
                                              <fanartres>720</fanartres>
                                              <imageres>540</imageres>
                                              <samba>
                                                <clienttimeout>30</clienttimeout>
                                              </samba>
                                              <network>
                                                <readbufferfactor>4.0</readbufferfactor>
                                                <cachemembuffersize>31457280</cachemembuffersize>
                                              </network>
                                              <gui>
                                                <algorithmdirtyregions>3</algorithmdirtyregions>
                                                <nofliptimeout>0</nofliptimeout>
                                              </gui>
                                              <splash>false</splash>
                                            </advancedsettings>
20:50:21 276.569763 T:1944437312  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
20:50:21 276.569946 T:1944437312  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <nodvdrom>true</nodvdrom>
                                              <network>
                                                <buffermode>1</buffermode>
                                                <cachemembuffersize>20971520</cachemembuffersize>
                                                <readbufferfactor>10</readbufferfactor>
                                              </network>
                                              <video>
                                                <timeseekforward>15</timeseekforward>
                                                <timeseekbackward>-15</timeseekbackward>
                                              </video>
                                              <gui>
                                                <algorithmdirtyregions>1</algorithmdirtyregions>
                                                <nofliptimeout>1000</nofliptimeout>
                                              </gui>
                                              <myvideos>
                                                <extractthumb>false</extractthumb>
                                              </myvideos>
                                              <videolibrary>
                                                <hideallitems>false</hideallitems>
                                                <hiderecentlyaddeditems>false</hiderecentlyaddeditems>
                                                <recentlyaddeditems>10</recentlyaddeditems>
                                                <importwatchedstate>false</importwatchedstate>
                                                <hideemptyseries>true</hideemptyseries>
                                                <importresumepoint>false</importresumepoint>
                                              </videolibrary>
                                              <videoscanner>
                                                <ignoreerrors>true</ignoreerrors>
                                              </videoscanner>
                                              <lookandfeel>
                                                <enablerssfeeds>false</enablerssfeeds>
                                              </lookandfeel>
                                              <imageres>512</imageres>
                                              <useddsfanart>false</useddsfanart>
                                              <fanartres>540</fanartres>
                                              <videoplayer>
                                                <stretch43>4</stretch43>
                                              </videoplayer>
                                            </advancedsettings>
20:50:21 276.571289 T:1944437312  NOTICE: Default DVD Player: dvdplayer
20:50:21 276.571320 T:1944437312  NOTICE: Default Video Player: dvdplayer
20:50:21 276.571381 T:1944437312  NOTICE: Default Audio Player: paplayer
20:50:21 276.571411 T:1944437312  NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:50:21 276.571442 T:1944437312  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:50:21 276.571686 T:1944437312  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:50:21 276.573181 T:1944437312  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:50:21 276.583374 T:1944437312  NOTICE: Loaded playercorefactory configuration
20:50:21 276.583679 T:1944437312  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:50:21 276.583832 T:1944437312  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:50:22 277.495392 T:1944437312  NOTICE: Running database version Addons20
20:50:22 277.710297 T:1944437312  NOTICE: ADDONS: Using repository repository.xbmc.org
20:50:22 277.710388 T:1944437312  NOTICE: ADDONS: Using repository repository.emby.kodi
20:50:22 277.710419 T:1944437312  NOTICE: ADDONS: Using repository repository.popcornmix
20:50:22 277.789551 T:1944437312  NOTICE: Raspberry PI firmware version: Dec  9 2016 15:11:26
                                            Copyright © 2012 Broadcom
                                            version 2e557d8dac70add28597c3b449cb52c34588d818 (clean) (release)
20:50:22 277.789642 T:1944437312  NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
20:50:22 277.789673 T:1944437312  NOTICE: cacheMemBufferSize: 20MB
20:50:22 277.789978 T:1944437312  NOTICE: Config:
                                            arm_freq=1100
                                            audio_pwm_mode=1
                                            avoid_warnings=2
                                            boot_delay=3
                                            config_hdmi_boost=5
                                            core_freq=500
                                            desired_osc_freq=0x36ee80
                                            disable_audio_dither=1
                                            disable_commandline_tags=2
                                            disable_l2cache=1
                                            disable_splash=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            force_turbo=1
                                            framebuffer_ignore_alpha=1
                                            framebuffer_swap=1
                                            gpu_freq=500
                                            h264_freq=300
                                            hdmi_channel_map=8
                                            hdmi_drive=2
                                            hdmi_force_cec_address=65535
                                            hdmi_force_edid_audio=1
                                            hdmi_force_hotplug=1
                                            hdmi_group=1
                                            hdmi_ignore_edid_audio=1
                                            hdmi_mode=4
                                            init_uart_clock=0x2dc6c00
                                            lcd_framerate=60
                                            over_voltage=3
                                            over_voltage_avs=0x1cfde
                                            overscan_scale=1
                                            pause_burst_frames=1
                                            program_serial_random=1
                                            sdram_freq=450
                                            temp_limit=85
                                            v3d_freq=500
20:50:22 277.790161 T:1944437312  NOTICE: Config:
                                            device_tree=-
20:50:22 277.790253 T:1944437312  NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
20:50:22 277.791779 T:1944437312  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
20:50:22 277.791870 T:1944437312  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
20:50:22 277.791931 T:1944437312  NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
20:50:22 277.791962 T:1944437312  NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
20:50:22 277.791992 T:1944437312  NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
20:50:22 277.792053 T:1944437312  NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
20:50:22 277.792084 T:1944437312  NOTICE: Found resolution 1280 x 960 for display 0 with 1280 x 960 @ 60.000000 Hz
20:50:22 277.792145 T:1944437312  NOTICE: Found resolution 1280 x 960 for display 0 with 1280 x 960 @ 59.940063 Hz
20:50:22 277.792175 T:1944437312  NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
20:50:22 277.792206 T:1944437312  NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
20:50:22 277.792267 T:1944437312  NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 60.000000 Hz
20:50:22 277.792297 T:1944437312  NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 59.940063 Hz
20:50:22 277.792358 T:1944437312  NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 60.000000 Hz
20:50:22 277.792389 T:1944437312  NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 59.940063 Hz
20:50:22 277.792419 T:1944437312  NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 60.000000 Hz
20:50:22 277.792480 T:1944437312  NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 59.940063 Hz
20:50:22 277.792511 T:1944437312  NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
20:50:22 277.792572 T:1944437312  NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
20:50:22 277.792603 T:1944437312  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
20:50:22 277.792664 T:1944437312  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
20:50:22 277.792725 T:1944437312  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
20:50:22 277.792755 T:1944437312  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
20:50:22 277.792816 T:1944437312  NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
20:50:22 277.792847 T:1944437312  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
20:50:22 277.792877 T:1944437312  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
20:50:22 277.792938 T:1944437312  NOTICE: Found (1280x720@60.000000) at 34, setting to RES_DESKTOP at 16
20:50:22 277.792969 T:1944437312  NOTICE: Checking resolution 16
20:50:22 277.957855 T:1944437312  NOTICE: GL_VENDOR = Broadcom
20:50:22 277.957947 T:1944437312  NOTICE: GL_RENDERER = VideoCore IV HW
20:50:22 277.958008 T:1944437312  NOTICE: GL_VERSION = OpenGL ES 2.0
20:50:22 277.958038 T:1944437312  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
20:50:22 277.958069 T:1944437312  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
20:50:23 278.487732 T:1944437312  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
20:50:23 278.539673 T:1944437312  NOTICE: Running database version Addons20
20:50:23 278.548584 T:1944437312  NOTICE: Running database version ViewModes6
20:50:23 278.554352 T:1944437312  NOTICE: Running database version Textures13
20:50:23 278.573975 T:1944437312  NOTICE: Running database version MyMusic56
20:50:23 278.591949 T:1944437312  NOTICE: Running database version MyVideos99
20:50:23 278.597076 T:1944437312  NOTICE: Running database version TV29
20:50:23 278.608490 T:1944437312  NOTICE: Running database version Epg11
20:50:23 278.612640 T:1944437312  NOTICE: start dvd mediatype detection
20:50:24 279.800446 T:1944437312 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:50:24 279.884216 T:1944437312  NOTICE: ActiveAE DSP - starting
20:50:24 279.892395 T:1944437312  NOTICE: initialize done
20:50:24 279.980896 T:1944437312  NOTICE: Running the application...
20:50:25 280.491028 T:1944437312  NOTICE: starting zeroconf publishing
20:50:25 280.530365 T:1944437312  NOTICE: WebServer: Started the webserver
20:50:25 280.530609 T:1944437312  NOTICE: starting upnp client
20:50:26 281.657410 T:1695949744  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
20:50:26 281.677032 T:1944437312  NOTICE: Found a joystick : use it as a joystick input device - /dev/input/event0
20:50:26 281.677124 T:1695949744  NOTICE: UDP: Listening on port 9777
20:50:26 281.711761 T:1678910384  NOTICE: Found a joystick : use it as a joystick input device - /dev/input/event0
20:50:27 282.506683 T:1944437312  NOTICE: Enabled Joystick: PLAYSTATION®3 Controller
20:50:27 282.506958 T:1944437312  NOTICE: Details: Total Axis: 29 Total Hats: 0 Total Buttons: 17
20:50:30 285.832123 T:1788994480   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                             - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                            Error Type: <type 'exceptions.ValueError'>
                                            Error Contents: bad marshal data (unknown type code)
                                            Traceback (most recent call last):
                                              File "/home/pi/.kodi/addons/plugin.video.emby/service.py", line 22, in <module>
                                                from service_entry import Service
                                              File "/home/pi/.kodi/addons/plugin.video.emby/resources/lib/service_entry.py", line 14, in <module>
                                                import userclient
                                              File "/home/pi/.kodi/addons/plugin.video.emby/resources/lib/userclient.py", line 12, in <module>
                                                import artwork
                                              File "/home/pi/.kodi/addons/plugin.video.emby/resources/lib/artwork.py", line 13, in <module>
                                                import requests
                                            ValueError: bad marshal data (unknown type code)
                                            -->End of Python script error report<--
20:50:36 291.774139 T:1678910384  NOTICE: Found a joystick : use it as a joystick input device - /dev/input/event0
it worked before i did a recent apt-get upgrade
Guest
