ariznaf 1 Posted January 18, 2017 Posted January 18, 2017 I have installed Emby 3.1.2 in my QNAP TS-451+ running QTS 4.2.2 I have tried to activate hardware accelerated transcoding I have tried to use the "Inter Quick sync" option (as my NAS has an Intel processor and GPU) with no success, when I activate it, the film simply does not play (accessing emby through web interface). If I use VA API option, the video plays. But the acceleration does not seem to be in effect, as the CPU load is quite big (70%) with no difference when I deactivate HW transcoding. What am I doing wrong? Is another different version of ffmeg needed? I have read something about it. But a ffmpeg (static libs) distribution seems to come with the QPKG as the ffmpeg directory points under the qpkg directory of emby. Thank you for your help
Luke 42240 Posted January 19, 2017 Posted January 19, 2017 Hi, VA API will be your best bet. Not all videos will show a major improvement. Try to test a large number of videos before drawing any conclusions. Thanks.
ariznaf 1 Posted January 19, 2017 Author Posted January 19, 2017 Hi Luke, thanks a lot for your answer. I have been doing some tests. When I made the question, I had installed Emby QNAP_Stephan distribution from the QNAP forum: https://forum.qnap.com/viewtopic.php?f=320&t=109476 It seem to integrate a ffmpeg distribution, as there is a custom ffmpeg path that points inside the package distribution. With that distro, I could activate VA API and see the videos, but it did not work when I activate Intel QSync. Then I have installed the Emby distro from QNAP Club. I have installed ffmpeg package from QNAP club too and configure it as the ffmep library to use with the custom path. Here it is the opposite way: I can activate Intel QSync but not VA API. How may I know if the HW acceleration engine is being used by Emby? Using it, does not seem to have any impact in the CPU load. Most of my files are in mkv or mp4 containers, coded using H.264 1080P or 720p or 480p
Gabbe222 0 Posted January 28, 2017 Posted January 28, 2017 @@ariznaf did u get the hardware transcode to work? thinking of buying this nas
ariznaf 1 Posted January 31, 2017 Author Posted January 31, 2017 @@Gabbe222. No, sorry, I did not get it to work and received no answer, here or in the QNAP forum. I have tried the two versions of the community QNAP ports of EMBY, the one in the QNAP forum and the one downloaded from QNAP club. Now I have reverted to the EMBY 3.0 version distributed officially in the QNAP app store, hoping they will upgrade the app soon. It has no option for hardware transcoding. My experience with QNAP has mixed feeling, the hardware i good, but they promise more than they really offer. Most of their apps have important limitations that make them quite useless. 1
Gabbe222 0 Posted February 1, 2017 Posted February 1, 2017 then its setteld, im buyin regular nas for storage and intel NUC for server.. I thought i could get 2in1 but after 2 weeks of reading online it dosnt seem so.
ariznaf 1 Posted February 1, 2017 Author Posted February 1, 2017 (edited) I'm a bit off with QNAP due to their software not working as expected. But how is the NUC going to be better than the NAS? We are talking of hardware transcoding here, not hardware decoding. If the playing device is a capable one, you don't need hardware decoding. I can play a movie in my PC using Emby with not need of hardware decoding in the NAS, as the NAS only serves de files, and the PC decodes and adapts the video to the resoluction of the screen. The NAS itself, plays correctly the movies connected to the TV via HDMI using HDStation and Emby, and it plays them smoothly and with no CPU load, so I gess hardware decoding works correctly in the NAS (even with 3.0 of Emby). You only need hardware transcoding (decoding/encoding) in the NAS if you are using less capable devices, not able by themself of doing hardware decoding (like PlayStation devices, some android phones...) or to save bandwith if you want to play a movie via internet in your phone device connected to you home using a 4G connection, for example. I would prefer emby and QNAP being able of doing hardware transcoding for the times I would need it, but it is not a must have for me. May be your NUC can do the transcoding and get the movies from the NAS, but you will need one more device up and running, consuming power and with a need of maintanance. Edited February 1, 2017 by ariznaf
sedony23 0 Posted February 6, 2017 Posted February 6, 2017 Hi there, After fiddling around for a couple of days, I finally got hardware accelerated transcoding to work on my QNAP TS-253A. For a "how to" see my post on the QNAP forum: https://forum.qnap.com/viewtopic.php?f=134&t=129879&p=596148#p596148 However, if we could get a static ffmpeg build with VA-API enabled, we could also run Emby as a qpkg package. Does anyone know if such a build exists and where to find it? Or could somebody compile such a build? I failed compiling a completely static build on QNAP Linux Station (ubuntu). Best Daniel
Luke 42240 Posted February 7, 2017 Posted February 7, 2017 What about these builds? https://www.johnvansickle.com/ffmpeg/
ariznaf 1 Posted February 8, 2017 Author Posted February 8, 2017 I will try the new versión of emby and that ffmep static lobraries... but how do you instalo that lobraries in qnap without a qnap package?
ariznaf 1 Posted February 9, 2017 Author Posted February 9, 2017 Let me update my tries... I have installed the ffmpeg library from the link you have provided, Luke. I have installed it in my system disk under the .qpkg directory (/share/CACHEDEV1_DATA/.qpkg/ffmpegStatic) no sure if it is the best place to install an external library. Then I have configured Emby to use ffmpeg from that directory. I have selected VA-API as hardware transcoding engine. When I play a film using a web browser from emby, the CPU load scales to 91-97%. Emby says it is transcoding 1.5MBps 480p, and when I stop the playbackup cpu load goes down to 4%. When i select nothing as the hardware acceleration engine, the CPU load is about the same: 94%. I have tried Intel quick sync as the HW ACC engine with the same results. I have even tried another ffmpeg 3.3.2 built installing the ffmpeg package from QNAP club (http://qnapclub.eu/index.php?act=detail&qpkg_id=379) with identical results. What may be going on? Why does it not work if it seems that this static libraries implement HW ACC transcoding?
Luke 42240 Posted February 9, 2017 Posted February 9, 2017 I will try the new versión of emby and that ffmep static lobraries... but how do you instalo that lobraries in qnap without a qnap package? I will have to discuss with Stephan from QNAP. Thanks !
GibsonXXI 0 Posted April 6, 2017 Posted April 6, 2017 The Emby releases from the forum (by QNAP_Stephane) and the ones from QNAPClub are one and the same thing. QNAPClub are hosting QNAP_Stephane's packages, so you'll probably gain very little using one over the other. The packages posted in the forum may be updated slightly quicker than they appear on QNAPClub, that's about it. QNAP_Stephane also has an FFMpeg static build addon, and he uses John Van Sickle's builds to make that addon. Again, downloading from the forum will get you a slightly newer release (3.2.4 vs 3.2.0 on QNAPClub). However Stephane's version includes ffprobe, but does not correctly symlink the library in the system path as he has done with ffmpeg (/usr/bin/ffmpeg -> /share/CACHEDEV1_DATA/.qpkg/ffmpeg). Might be irrelevent anyway, as I could not get Emby to 'recognise' the ffmpeg install when pointing it at the symlink, even after manually creating a symlink for ffprobe in the same folder via SSH (/usr/bin/ffmpeg and /usr/bin/ffprobe) so I just pointed Emby at the native ffmpeg addon install folder (/share/CACHEDEV1_DATA/.qpkg/ffmpeg) and that seemed to work.
viceversa 0 Posted May 15, 2017 Posted May 15, 2017 Also struggling to get HW transcoding to work via VA API with qnap ts-451+ 4.3.3, Emby 3.2.16.0 (qnapclub) and static ffmpeg 3.3.0 (qnapclub). I've called out the path for the static ffmpeg installation which is being recognized but the problem I'm having is: fmpeg version 3.3-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2017 the FFmpeg developers built with gcc 5.4.1 (Debian 5.4.1-8) 20170304 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc-5 --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gray --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libzimg libavutil 55. 58.100 / 55. 58.100 libavcodec 57. 89.100 / 57. 89.100 libavformat 57. 71.100 / 57. 71.100 libavdevice 57. 6.100 / 57. 6.100 libavfilter 6. 82.100 / 6. 82.100 libswscale 4. 6.100 / 4. 6.100 libswresample 2. 7.100 / 2. 7.100 libpostproc 54. 5.100 / 54. 5.100 [AVHWDeviceContext @ 0x3bb41c0] No VA display found for device: /dev/dri/card0. [vaapi @ 0x31531e0] Failed to create a VAAPI device I've tried calling out both "card0" and "renderD128" and even though not necessary, set additional permissions: [/dev/dri] # ls -lah total 0 drwxr-xr-x 2 admin administ 100 May 15 08:42 ./ drwxr-xr-x 15 admin administ 19.9K May 15 15:48 ../ crwxrwx--- 1 admin administ 226, 0 May 15 08:42 card0 crwxrwx--- 1 admin administ 226, 64 May 15 08:42 controlD64 crwxrwx--- 1 admin administ 226, 128 May 15 08:42 renderD128 Anyone able to get past this point?
sstt671 1 Posted May 16, 2017 Posted May 16, 2017 Also struggling to get HW transcoding to work via VA API with qnap ts-451+ 4.3.3, Emby 3.2.16.0 (qnapclub) and static ffmpeg 3.3.0 (qnapclub). I've called out the path for the static ffmpeg installation which is being recognized but the problem I'm having is: fmpeg version 3.3-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2017 the FFmpeg developers built with gcc 5.4.1 (Debian 5.4.1-8) 20170304 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc-5 --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gray --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libzimg libavutil 55. 58.100 / 55. 58.100 libavcodec 57. 89.100 / 57. 89.100 libavformat 57. 71.100 / 57. 71.100 libavdevice 57. 6.100 / 57. 6.100 libavfilter 6. 82.100 / 6. 82.100 libswscale 4. 6.100 / 4. 6.100 libswresample 2. 7.100 / 2. 7.100 libpostproc 54. 5.100 / 54. 5.100 [AVHWDeviceContext @ 0x3bb41c0] No VA display found for device: /dev/dri/card0. [vaapi @ 0x31531e0] Failed to create a VAAPI device I've tried calling out both "card0" and "renderD128" and even though not necessary, set additional permissions: [/dev/dri] # ls -lah total 0 drwxr-xr-x 2 admin administ 100 May 15 08:42 ./ drwxr-xr-x 15 admin administ 19.9K May 15 15:48 ../ crwxrwx--- 1 admin administ 226, 0 May 15 08:42 card0 crwxrwx--- 1 admin administ 226, 64 May 15 08:42 controlD64 crwxrwx--- 1 admin administ 226, 128 May 15 08:42 renderD128 Anyone able to get past this point? I have exactly same problem with similar setup on my TS-251+.
sstt671 1 Posted May 16, 2017 Posted May 16, 2017 One more test I did today Look at the trancode log file when: (1) using Emby's in built ffmpeg 2017-05-16 15:04:28.9080 Info MediaEncoder: Attempting to update encoder path to /share/CE_CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/ffmpeg/20160215/. pathType: Custom 2017-05-16 15:04:28.9097 Info MediaEncoder: Running /share/CE_CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/ffmpeg/20160215/ffmpeg -version 2017-05-16 15:04:28.9322 Info MediaEncoder: ffmpeg info: ffmpeg version N-52954-g295de3e-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.1 (Debian 5.3.1-8) 20160205 configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --cc=gcc libavutil 55. 17.103 / 55. 17.103 libavcodec 57. 24.102 / 57. 24.102 libavformat 57. 25.100 / 57. 25.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 31.100 / 6. 31.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 2017-05-16 15:04:28.9338 Debug XmlSerializer: Serializing to file /share/CE_CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/config/encoding.xml 2017-05-16 15:04:28.9338 Info MediaEncoder: FFMpeg: /share/CE_CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/ffmpeg/20160215/ffmpeg 2017-05-16 15:04:28.9338 Info MediaEncoder: FFProbe: /share/CE_CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/ffmpeg/20160215/ffprobe 2017-05-16 15:04:28.9338 Info MediaEncoder: Validating media encoder at /share/CE_CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/ffmpeg/20160215/ffmpeg 2017-05-16 15:04:28.9338 Info MediaEncoder: Running /share/CE_CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/ffmpeg/20160215/ffmpeg -decoders 2017-05-16 15:04:29.0109 Info MediaEncoder: Decoder available: mpeg2video 2017-05-16 15:04:29.0142 Info MediaEncoder: Decoder available: h264_qsv 2017-05-16 15:04:29.0178 Info MediaEncoder: Decoder available: hevc_qsv 2017-05-16 15:04:29.0228 Info MediaEncoder: Decoder available: mpeg2_qsv 2017-05-16 15:04:29.0319 Info MediaEncoder: Decoder available: vc1_qsv 2017-05-16 15:04:29.0319 Info MediaEncoder: Running /share/CE_CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/ffmpeg/20160215/ffmpeg -encoders 2017-05-16 15:04:29.0600 Info MediaEncoder: Encoder available: libx264 2017-05-16 15:04:29.0616 Info MediaEncoder: Encoder available: libx265 2017-05-16 15:04:29.0637 Info MediaEncoder: Encoder available: mpeg4 2017-05-16 15:04:29.0659 Info MediaEncoder: Encoder available: msmpeg4 2017-05-16 15:04:29.0696 Info MediaEncoder: Encoder available: libvpx 2017-05-16 15:04:29.0733 Info MediaEncoder: Encoder available: libvpx-vp9 2017-05-16 15:04:29.0776 Info MediaEncoder: Encoder available: aac 2017-05-16 15:04:29.0830 Info MediaEncoder: Encoder available: libmp3lame 2017-05-16 15:04:29.0884 Info MediaEncoder: Encoder available: libopus 2017-05-16 15:04:29.0950 Info MediaEncoder: Encoder available: libvorbis 2017-05-16 15:04:29.1023 Info MediaEncoder: Encoder available: srt 2017-05-16 15:04:29.1184 Info MediaEncoder: Encoder available: h264_qsv 2017-05-16 15:04:29.1202 Info MediaEncoder: Encoder available: hevc_qsv 2017-05-16 15:04:29.1547 Info MediaEncoder: Encoder validation complete 2017-05-16 15:04:29.1553 Info HttpServer: HTTP Response 204 to 172.56.3.36. Time: 250ms. http://<<My DDNS Address>>:8096/emby/System/MediaEncoder/Path 2017-05-16 15:04:32.3901 Info HttpServer: HTTP GET http://<<My DDNS Address>>:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/58.0.3029.110 Safari/537.36 (2) Intel Quick Sync selected - see attached log file for detail. Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x808, SAR 1:1 DAR 240:101, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Metadata: BPS : 9012426 BPS-eng : 9012426 DURATION : 01:44:05.082000000 DURATION-eng : 01:44:05.082000000 NUMBER_OF_FRAMES: 149732 NUMBER_OF_FRAMES-eng: 149732 NUMBER_OF_BYTES : 7035418193 NUMBER_OF_BYTES-eng: 7035418193 _STATISTICS_WRITING_APP: mkvmerge v8.3.0 ('Over the Horizon') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.3.0 ('Over the Horizon') 64bit _STATISTICS_WRITING_DATE_UTC: 2017-05-11 01:28:38 _STATISTICS_WRITING_DATE_UTC-eng: 2017-05-11 01:28:38 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default) Metadata: BPS : 1508999 BPS-eng : 1508999 DURATION : 01:44:05.163000000 DURATION-eng : 01:44:05.163000000 NUMBER_OF_FRAMES: 585484 NUMBER_OF_FRAMES-eng: 585484 NUMBER_OF_BYTES : 1177993808 NUMBER_OF_BYTES-eng: 1177993808 _STATISTICS_WRITING_APP: mkvmerge v8.3.0 ('Over the Horizon') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.3.0 ('Over the Horizon') 64bit _STATISTICS_WRITING_DATE_UTC: 2017-05-11 01:28:38 _STATISTICS_WRITING_DATE_UTC-eng: 2017-05-11 01:28:38 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES [h264_qsv @ 0x3f09260] Error initializing an internal MFX session Output #0, matroska, to '/share/CE_CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/transcoding-temp/c0b5f35c7b1fc2b4ba53142a08cff5cf.mkv': Stream #0:0: Video: h264, none, q=2-31, 128 kb/s, SAR 1:1 DAR 0:0, 23.98 fps (default) Metadata: encoder : Lavc57.24.102 h264_qsv Stream #0:1: Audio: mp3, 0 channels, 128 kb/s (default) Metadata: encoder : Lavc57.24.102 libmp3lame Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_qsv)) Stream #0:1 -> #0:1 (dts (dca) -> mp3 (libmp3lame)) Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height qsv_trancode error.txt
Luke 42240 Posted May 18, 2017 Posted May 18, 2017 For QNAP, VA API is our recommended approach. We're going to be soon taking over the development of the QNAP Emby package and then we'll work through all of this. 1
viceversa 0 Posted May 18, 2017 Posted May 18, 2017 For QNAP, VA API is our recommended approach. We're going to be soon taking over the development of the QNAP Emby package and then we'll work through all of this. Great news and thank you very much for the update. I'm more than happy to help out with testing.
sstt671 1 Posted May 18, 2017 Posted May 18, 2017 For QNAP, VA API is our recommended approach. We're going to be soon taking over the development of the QNAP Emby package and then we'll work through all of this. Great! Looking forward to this.
sectune 9 Posted May 30, 2017 Posted May 30, 2017 (edited) Please make it happen, a happy qnap emby user here cheering and praying to the holy spaghetti monster to make it happen For QNAP, VA API is our recommended approach. We're going to be soon taking over the development of the QNAP Emby package and then we'll work through all of this. Edited May 30, 2017 by sectune
joelang6126 10 Posted June 18, 2017 Posted June 18, 2017 I have a TS-EC1080 and am struggling with this. Transcoding always uses ridiculous amounts of CPU power!
Luke 42240 Posted June 25, 2017 Posted June 25, 2017 In the near future we are planning on taking over packaging of the QNAP package, and at that point we will have official guidance on GPU acceleration. In the meantime, VA API should work. Thanks.
