waspsoton 0 Posted January 18, 2017 Posted January 18, 2017 i am a new user and i have my iptv setup via a m3u list. i have a epg xml but it doesn't seem to work with emby. so i am only looking to test this at the mo as i am a plex user. so what epg's work with emby?
Luke 42242 Posted January 18, 2017 Posted January 18, 2017 Hi @@waspsoton, welcome. Can you provide a little more information? Why don't you think that its' working?
waspsoton 0 Posted January 18, 2017 Author Posted January 18, 2017 I Am not seeing anything in the epg. Are there any free epg that work??
Luke 42242 Posted January 18, 2017 Posted January 18, 2017 Do the channels in your EPG match the channels in your m3u? That is the important question. If not, you can use the mapping feature to manually assign them. Please let us know if this helps. Thanks !
Luke 42242 Posted January 21, 2017 Posted January 21, 2017 @@waspsoton, in live tv setup, click the 3-dot menu next to the guide entry let us know if this helps, thanks !
waspsoton 0 Posted January 21, 2017 Author Posted January 21, 2017 Cheers Luke. That has helps and it's now working. Liking Emby so far.
