Luke 42154 Posted December 18, 2019 Posted December 18, 2019 Same problem here. How can i grab the debug logs? Episodes are detected by emby correctly as multi-episodes but are not always synced correctly to trakt. It sometimes seem to work. What exactly happens? What do you mean sometimes?
thereapman 0 Posted December 19, 2019 Posted December 19, 2019 not sure. as i said. emby detects the multi part episodes correctly. after a manual trigger of the scheduled sync task it seems that a single series/a single multipart eposide gets sycned correctly but all other are not and even get reset to missing the second part. If you can point me to the log that is written when enabling the plugins debug option i could provide it. Also where is the source code hosted? i can have a look as well.
Luke 42154 Posted December 19, 2019 Posted December 19, 2019 It writes to the main server log. Source code is here: https://github.com/MediaBrowser/trakt Thanks !
Luke 42154 Posted March 19, 2021 Posted March 19, 2021 5 hours ago, MarcelDoornbos said: Issue resurfaced in version 3.4.6.0 Hi there, please go over an example. Thanks.
Guest Posted April 3, 2021 Posted April 3, 2021 (edited) On 19/03/2021 at 19:07, Luke said: Hi there, please go over an example. Thanks. Hi Luke, Apologies for the delay getting back to you. Example: The Office US (IMDB tt0386676) Season 4 Episode 1+2 (IMDB tt1026035) (Current) Filename: The Office (US) - S04E01-E02 Fun Run.mkv When I change the name to say 'The Office (US) - S04E01-E02 - Fun Run.mkv' and run 'Scan Media Library' and 'Sync library to trakt.tv' both episodes show as 'Collected' on Trakt. The next time the task runs (manually or scheduled) the second episode will no longer have the 'Collected' status. Please note this is not limited to just this episode or TV show, but the same applies. I currently use the Trakt plugin version 3.4.8.0. Don't think it will be of any help but this is my Trakt profile (Collected, sorted by Least Completed), any shows with gaps in the middle are affected: https://trakt.tv/users/homotasje/progress/collected/least-completed Let me know if you need any further information. Edited April 3, 2021 by MarcelDoornbos Extra info
Luke 42154 Posted April 5, 2021 Posted April 5, 2021 On 4/3/2021 at 2:39 PM, MarcelDoornbos said: Hi Luke, Apologies for the delay getting back to you. Example: The Office US (IMDB tt0386676) Season 4 Episode 1+2 (IMDB tt1026035) (Current) Filename: The Office (US) - S04E01-E02 Fun Run.mkv When I change the name to say 'The Office (US) - S04E01-E02 - Fun Run.mkv' and run 'Scan Media Library' and 'Sync library to trakt.tv' both episodes show as 'Collected' on Trakt. The next time the task runs (manually or scheduled) the second episode will no longer have the 'Collected' status. Please note this is not limited to just this episode or TV show, but the same applies. I currently use the Trakt plugin version 3.4.8.0. Don't think it will be of any help but this is my Trakt profile (Collected, sorted by Least Completed), any shows with gaps in the middle are affected: https://trakt.tv/users/homotasje/progress/collected/least-completed Let me know if you need any further information. Hi, yes, please attach the emby server log from when this happened. Thanks !
Guest Posted April 5, 2021 Posted April 5, 2021 36 minutes ago, Luke said: Hi, yes, please attach the emby server log from when this happened. Thanks ! embyserver - sync s04e01 and s04e02.txtAttached the log taken after media scan + Trakt sync after name change of aforementioned episodes, result being both episodes shown as collected. 1/2
Guest Posted April 5, 2021 Posted April 5, 2021 Just now, MarcelDoornbos said: embyserver - sync s04e01 and s04e02.txtAttached the log taken after media scan + Trakt sync after name change of aforementioned episodes, result being both episodes shown as collected. 1/2 embyserver - sync s04e01 only.txt2/2 log taken after media scan + Trakt sync without name change
Luke 42154 Posted April 6, 2021 Posted April 6, 2021 Ok same error as another topic. Please follow along here: Thanks.
Guest Posted April 7, 2021 Posted April 7, 2021 14 hours ago, Luke said: Ok same error as another topic. Please follow along here: Thanks. I have no problem syncing though, it only concerns the second episode of a double episode. However, I'll follow any advice in the other topic.
Guest Posted April 13, 2021 Posted April 13, 2021 (edited) Another attempt, see TraktResponse at the bottom of the attached logs embyserver first run after name change - collected.txtembyserver 2nd run no name change - uncollected.txt Screenshots from Trakt + systime. They seem to be in the wrong order in my comment, order is as follows: 1- embyserver first run aftername change -collected.txt 2- Screenshot @ 10:03 3- embyserver 2nd run no name change - uncollected.txt 4- Screenshot @ 10:05 Edited April 13, 2021 by MarcelDoornbos order by time asc
Luke 42154 Posted May 1, 2021 Posted May 1, 2021 On 4/13/2021 at 5:15 AM, MarcelDoornbos said: Another attempt, see TraktResponse at the bottom of the attached logs embyserver first run after name change - collected.txtembyserver 2nd run no name change - uncollected.txt Screenshots from Trakt + systime. They seem to be in the wrong order in my comment, order is as follows: 1- embyserver first run aftername change -collected.txt 2- Screenshot @ 10:03 3- embyserver 2nd run no name change - uncollected.txt 4- Screenshot @ 10:05 Hi, we'll take a look at it. Thanks for reporting.
Guest Posted May 26, 2021 Posted May 26, 2021 On 01/05/2021 at 01:38, Luke said: Hi, we'll take a look at it. Thanks for reporting. From the release notes I understood this may have been fixed, but just to let you know, this is still happening in 4.6.1.
vdatanet 1618 Posted May 26, 2021 Posted May 26, 2021 (edited) This is a multiepisode item 1x1, 1x2, 1x3. Only episode 1 and 2, are in sync with Trakt. I get this error: 2021-05-26 12:26:05.351 Error Trakt: Error sending scrobble *** Error Report *** Version: 4.6.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-73-generic (buildd@lcy01-amd64-019) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #82-Ubuntu SMP Wed Apr 14 17:39:42 UTC 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 6 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: TooManyRequests at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendEpisodeStatusUpdateAsync(Episode episode, MediaStatus status, TraktUser traktUser, Single progressPercent, CancellationToken cancellationToken) at Trakt.ServerMediator.KernelPlaybackStopped(Object sender, PlaybackStopEventArgs e) Source: Emby.Server.Implementations TargetSite: Void MoveNext() If I try later, there's no TooMany Requests error and: My conclusion is that the problem is on the Trakt side and I am assuming that based on the load it rejects simultaneous requests. Edited May 26, 2021 by vdatanet
Guest Posted June 6, 2021 Posted June 6, 2021 6 hours ago, Luke said: @MarcelDoornbos has this helped? Unfortunately not, identical behaviour. Emby Server 4.6.2.0 Trakt plugin 3.5.1.0 If I can do anything to help please let me know.
andcbii 12 Posted June 10, 2021 Posted June 10, 2021 Version 4.7.0.2 bet. and and Trakt plugin 3.5.1.0 Seeing similar issues. Removing the file, scanning the library, running the trakt sync THEN adding the file back, scanning the library and running the trakt sync temporally fixes the issue. I did this for a few shows thinking I was fixing the issue. Then I recheck my progress and several of the show I thought I had just fixed showed as issues again. So it looks to sync correct the first time the file is added, but then on subsequent sync it's being removed.
Luke 42154 Posted June 21, 2021 Posted June 21, 2021 OK we're looking into possible issues with syncing multi-episode files. Thanks.
Guest Posted September 13, 2021 Posted September 13, 2021 On 21/06/2021 at 17:40, Luke said: OK we're looking into possible issues with syncing multi-episode files. Thanks. Any luck with this?
Luke 42154 Posted September 17, 2021 Posted September 17, 2021 On 9/13/2021 at 12:01 PM, MarcelDoornbos said: Any luck with this? Hi @MarcelDoornbos please go over an example of what you're having an issue with. Thanks !
Guest Posted September 18, 2021 Posted September 18, 2021 On 17/09/2021 at 07:54, Luke said: Hi @MarcelDoornbos please go over an example of what you're having an issue with. Thanks ! Hi Luke, Still the same issue as discussed earlier on in this thread. When a double episode (eg. S05E01-02) is added, it will initially be marked as 'Collected' on Trakt. Any consecutive Library Scans+Syncs will only mark the first episode as collected, but not the second. I posted an example in this thread on the 3rd of April, and attached logs on the 5th of April. I was under the impression this was already looked into because of: On 21/06/2021 at 17:40, Luke said: OK we're looking into possible issues with syncing multi-episode files. Thanks. Happy to be of assistance if it would be helpful, as the issue is extremely frustrating.
Luke 42154 Posted October 18, 2021 Posted October 18, 2021 @MarcelDoornbos can you please try the 3.5.2 update of the Trakt plugin? Thanks !
Guest Posted October 23, 2021 Posted October 23, 2021 On 18/10/2021 at 20:10, Luke said: @MarcelDoornbos can you please try the 3.5.2 update of the Trakt plugin? Thanks ! First test looks promising, will do some further testing later today and let you know
