joaorsfonseca 1 Posted January 17, 2017 Posted January 17, 2017 Hi there, i've searched the forum and didn't found any answer I'm having some problems syncing my entire library to trakt. I've changed from a standalone Kodi installation to Emby Server + Kodi emby add-on. But now, i'm facing some issue regarding multi episodes files. For instance. \Prison Break\Season 04\Prison.Break.S04E01E02.Scylla.Breaking.&.Entering.avi has generated the correct info on Emby Server, but i'm missing ep 2 on trakt.tv Any suggestions? Thanks
Luke 42252 Posted January 18, 2017 Posted January 18, 2017 Hi @@joaorsfonseca, looking at the plugin code, it does already support this. But I do have a guess about the issue. We are supplying the tvdb id of the first episode and I'm guessing trakt sees this and then replaces our episode numbers with the actual number from trakt. What we can do is try omitting the tvdb altogether and we'll see if that resolves it. thanks.
joaorsfonseca 1 Posted January 18, 2017 Author Posted January 18, 2017 Thanks for your answer @@Luke. I'll wait for an update/upgrade. Kodi handle it pretty well.
joaorsfonseca 1 Posted April 11, 2017 Author Posted April 11, 2017 Hi Luke.. Any news on this?I'm still missing some "seconds" episodes on trakt
Luke 42252 Posted December 5, 2017 Posted December 5, 2017 @@joaorsfonseca Our Trakt plugin has been updated to 3.1.2. Due to Trakt API changes, you will need to install the update, and then re-authenticate using the trakt plugin configuration screen. In addition, there are improvements to the Trakt syncing process. Please let us know if this helps. Thanks !
joaorsfonseca 1 Posted December 8, 2017 Author Posted December 8, 2017 @@Luke The issue remains, even with version 3.1.3 of trakt plugin.
paulsalter 84 Posted December 8, 2017 Posted December 8, 2017 Not sure if this is anything, for my double/triple episodes i use the format of SxxExx-Exx instead of SxxExxExx As far as i can see my collection has everything
joaorsfonseca 1 Posted December 8, 2017 Author Posted December 8, 2017 (edited) @@paulsalter I've tried it but it only worked for one case.. Don't know why... EDIT I found why.. I need to delete media on emby Thanks mate Edited December 8, 2017 by joaorsfonseca
joaorsfonseca 1 Posted December 11, 2017 Author Posted December 11, 2017 @@Luke it's fixed.. I can't explain why but i had to rename the files (just adding an _ at the end), wait for Emby refreshs library and then rename previous name.. I sync the library to Trakt and i have now my collection fully updated. Thanks for your help also @@paulsalter
joaorsfonseca 1 Posted May 1, 2019 Author Posted May 1, 2019 (edited) Dear all.. This issue has return. All my "multi" episodes aren't being synced correctly with Trakt. I've already try what i've did in the past but no success there. Edited May 1, 2019 by joaorsfonseca
Luke 42252 Posted May 1, 2019 Posted May 1, 2019 Dear all.. This issue has return. All my "multi" episodes aren't being synced correctly with Trakt. I've already try what i've did in the past but no success there. Hi there, can you please go over an example? thanks.
joaorsfonseca 1 Posted May 2, 2019 Author Posted May 2, 2019 @@Luke just look the first post in this thread.. It's the same.
joaorsfonseca 1 Posted May 5, 2019 Author Posted May 5, 2019 I must say that this starts happening a few days ago.. New version perhaps? Also, i've notice something weird. To fix the episodes sync with trakt, i have to rename the file, update emby library (for that specific season) and then, sync it back to trakt. It works. But, when i try to fix all the episodes in the same state it broke the ones that were already fixed.
J2ghz 11 Posted May 27, 2019 Posted May 27, 2019 Hi, @@joaorsfonseca Can you send your logs with debug logging turned on in emby and in the trakt plugin?
joaorsfonseca 1 Posted June 1, 2019 Author Posted June 1, 2019 @@J2ghz i see this line "Info Trakt: 1 Episode Deletes to Process" and in fact.. The episode is removed from trakt. Also notice that i've two users configured but only one has trakt integrated. Thanks in advance
Luke 42252 Posted November 23, 2019 Posted November 23, 2019 Please try the Trakt plugin 3.3.6 and report your experience. Thanks.
joaorsfonseca 1 Posted November 30, 2019 Author Posted November 30, 2019 Hi @@Luke it still doesn't work It seems that the info is being added to and removed from trakt. I'm attaching the log. After 10am. TRAKTV.txt
Luke 42252 Posted December 7, 2019 Posted December 7, 2019 Please try the Trakt plugin version 3.3.9 and see how that compares. Thanks.
thereapman 0 Posted December 18, 2019 Posted December 18, 2019 Same problem here. How can i grab the debug logs? Episodes are detected by emby correctly as multi-episodes but are not always synced correctly to trakt. It sometimes seem to work.
