optimalt 10 Posted January 17, 2017 Posted January 17, 2017 Hi, I can not get HD-audio and subtitles to work at the same time. Is this a known limitation or should I provide logs? I use the new Nvidia shield.
Solution ebr 16337 Posted January 17, 2017 Solution Posted January 17, 2017 If your subtitles require transcoding, then there will be no way to pass HD audio. Graphic (PGS) subs would require transcoding.
optimalt 10 Posted January 18, 2017 Author Posted January 18, 2017 FYI: There seems to be a way after all. I get HD-audio passthrough and PGSSUB with SPMC.
ebr 16337 Posted August 9, 2017 Posted August 9, 2017 You can try out better PGS support with the latest beta (1.4.37) of the app (on Google only right now).
