bennymac 47 Posted January 16, 2017 Posted January 16, 2017 Hi, Firstly and MOST importantly loving the new preview, it's a welcomed fresh. - Only real issue I've seen is when navigating down from "continue watching" to latest movies it jumps to the 2nd movie position, instead of the 1st. The below is just feedback, not sure if you're after any at this point... - With the home page view I really like the small buttons view available in the web client (shown below) I think these would really suit the roku app having the same colours from the web client carried over, just as an option..wish all apps did. Though the dynamic images look real good, they tend to make the screen busy. - When moving from row to row the current effect when scrolling is a little jarring, it almost gives off a lagging appearance. The current Roku when moving between rows has a smoother effect like it's dipped in a warm coating of chocolate Thanks heaps.
Guest Grace1313 Posted January 16, 2017 Posted January 16, 2017 I think Ebr mentioned in the future the app will give you an option to either start with the home screen as it is now or start with a screen where you can go directly into "all movies", "all tv shows", etc. and bypass the "latest", "next up", etc. I like the idea of these small buttons on the top of that other screen that will be added later.
ebr 16335 Posted January 16, 2017 Posted January 16, 2017 I think Ebr mentioned in the future the app will give you an option to either start with the home screen as it is now or start with a screen where you can go directly into "all movies", "all tv shows", etc. and bypass the "latest", "next up", etc. I like the idea of these small buttons on the top of that other screen that will be added later. Not exactly... What I was referring to was at the second level - once you enter a movie or TV library, you could have the option to show either the smart library screen (with latest, favorites, next up, etc.) or a grid view of just all the raw content. The Android TV app has this setup now so this would be the same thing (when implemented).
Guest Grace1313 Posted January 16, 2017 Posted January 16, 2017 Ok, still an option just not a home screen option. That actually makes more sense since you would need to click on the library you wanted before a grid screen could be shown.
