Tanamur 53 Posted May 5, 2016 Posted May 5, 2016 Give that a go now, all should be reset. :-) Yep, that's got it going again! Thx
Tanamur 53 Posted May 18, 2016 Posted May 18, 2016 @@radeon - Please fix it again. Perhaps some understanding on my part of why a paid app keeps doing this would assuage my frustration. Care to share?
radeon 757 Posted May 18, 2016 Author Posted May 18, 2016 @@radeon - Please fix it again. Perhaps some understanding on my part of why a paid app keeps doing this would assuage my frustration. Care to share? If someone else has been given your key and between you, you have been using on more that two machines, it will lock you out.
Tanamur 53 Posted May 18, 2016 Posted May 18, 2016 If someone else has been given your key and between you, you have been using on more that two machines, it will lock you out. Thanks for that info. There has been absolutely no key sharing. I don't do that to people. My config is that I have a headless server which I access via Remote Desktop (RDP) login. Originally, I (maybe we) thought the problem happened because I started the *.exe intermittently on the server and from the machine initiating the RDP session by clicking on the *.exe rather than from a command line on the server effectively running it on two machines. That was a year ago and not repeated since. As the server is rarely rebooted (1-2 weeks) I have just set it up to run on startup/reboot. That has certainly been the case since you corrected it a couple of weeks ago. I don't think this is my bad from an operational point. Would you suggest changing the key to see if it continues to happen?
Tanamur 53 Posted June 18, 2016 Posted June 18, 2016 Hi @@radeon - I am getting the "exceeded limit" error again. The only thing that has changed here is that my ISP had to replace my router this week since the last time I ran your application. The DHCP router is completely separate from the DSL modem which had to be rebooted so I assume a new WAN IP was assigned during the reboot. It is the same ISP provider, same DSL modem and the same LAN IP address assigned to my server running your application. Might I be so bold as to ask you to check your records and make certain that you have not inadvertently duplicated the key assigned to me to another person as well? I assure you there is no sharing of the key on my end because....well because I have no friends other than my virtual friends in the Emby community forum
radeon 757 Posted June 18, 2016 Author Posted June 18, 2016 Hi @@radeon - I am getting the "exceeded limit" error again. The only thing that has changed here is that my ISP had to replace my router this week since the last time I ran your application. The DHCP router is completely separate from the DSL modem which had to be rebooted so I assume a new WAN IP was assigned during the reboot. It is the same ISP provider, same DSL modem and the same LAN IP address assigned to my server running your application. Might I be so bold as to ask you to check your records and make certain that you have not inadvertently duplicated the key assigned to me to another person as well? I assure you there is no sharing of the key on my end because....well because I have no friends other than my virtual friends in the Emby community forum Give that a go now. Should be reset. I'll reissue a new key tomorrow. In bloody A&E at the min so a little preoccupied! :-/
Tanamur 53 Posted June 18, 2016 Posted June 18, 2016 Give that a go now. Should be reset. I'll reissue a new key tomorrow. In bloody A&E at the min so a little preoccupied! :-/ Hi @@radeon - That has it going again. Thanks for the help above and beyond the call of duty while in the A&E. You set the gold standard for support! Be well... 1
gillmacca 17 Posted July 5, 2016 Posted July 5, 2016 I've just moved this app from my laptop to my server, but I am now getting 'your activation limit has been exceeded' I will only be running it from my server. What info do you need to reset it?
radeon 757 Posted July 8, 2016 Author Posted July 8, 2016 I've just moved this app from my laptop to my server, but I am now getting 'your activation limit has been exceeded' I will only be running it from my server. What info do you need to reset it? hey! apologies, been away in Germany on business for the week. git it a go now. should be sorted. :-)
gillmacca 17 Posted July 8, 2016 Posted July 8, 2016 hey! apologies, been away in Germany on business for the week. git it a go now. should be sorted. :-) Thanks
gillmacca 17 Posted July 16, 2016 Posted July 16, 2016 For some reason it says today exceeded again. Nothing has changed on my system, except os updates
radeon 757 Posted July 17, 2016 Author Posted July 17, 2016 For some reason it says today exceeded again. Nothing has changed on my system, except os updates Sorry, been away for the weekend. I have it down as running up on two completely separate machines and this one being a third. I have reset it now anyways but it looks like that could have caused it.
aspdend 177 Posted August 25, 2016 Posted August 25, 2016 (edited) @@radeon Hi John, not used this tool for a while, but definitely need it now to fill in all the blank people on my system. Tried my old key from 2014 and it's not working - do I need another one or is it just out of date now? Edited August 26, 2016 by aspdend
kkhan 16 Posted October 25, 2016 Posted October 25, 2016 Hi Radeon I migrated my Emby server to new hardware a week ago which unfortunately coinciding with Emby support for ImagesByName being removed. Thus when I migrated as per guidelines (installed Emby on new hardware and then overwrote Emby-Server\* folders with versions from old hardware); the ImagesByName\People content was not migrated to the new Emby-Server\Metadata\People folder. I thought of copying \ImagesByName\People to Metadata\People manually but cannot do that as the target metadata folder is organised by alphabetically by sub-folder, e.g Metdata\People\A\<Name>\.... Alternatively I though of running IBN Downloader against the Metdata folder but will that work with the new metadata\People\A\<Name> ... format? If not will you bring a new version with support for the new metadata\people folder? Any other ideas welcome
aspdend 177 Posted October 25, 2016 Posted October 25, 2016 @@radeon Hi John, not used this tool for a while, but definitely need it now to fill in all the blank people on my system. Tried my old key from 2014 and it's not working - do I need another one or is it just out of date now? @@radeon just a nudge for this item mate - could do with an update please
Happy2Play 9811 Posted October 25, 2016 Posted October 25, 2016 Hi John, not used this tool for a while, but definitely need it now to fill in all the blank people on my system. Tried my old key from 2014 and it's not working - do I need another one or is it just out of date now? What do you mean not working? You shouldn't need a new key my key from 2014 still works. 1
Happy2Play 9811 Posted October 25, 2016 Posted October 25, 2016 (edited) Hi Radeon I migrated my Emby server to new hardware a week ago which unfortunately coinciding with Emby support for ImagesByName being removed. Thus when I migrated as per guidelines (installed Emby on new hardware and then overwrote Emby-Server\* folders with versions from old hardware); the ImagesByName\People content was not migrated to the new Emby-Server\Metadata\People folder. I thought of copying \ImagesByName\People to Metadata\People manually but cannot do that as the target metadata folder is organised by alphabetically by sub-folder, e.g Metdata\People\A\<Name>\.... Alternatively I though of running IBN Downloader against the Metdata folder but will that work with the new metadata\People\A\<Name> ... format? If not will you bring a new version with support for the new metadata\people folder? Any other ideas welcome Personally I would just take the couple minutes and move my existing people to their alphabetical sub-folders, as it would take many more hours if not days to attempt redownload them. Edited October 25, 2016 by Happy2Play 1
radeon 757 Posted October 26, 2016 Author Posted October 26, 2016 @@radeon just a nudge for this item mate - could do with an update please Yo @@aspdend! sorry i missed this! Been a busy busy bast**d recently!! @@Happy2Play is right tho, your key should be working fine assuming it was bought for this version of mediabrowser3/emby Just drop me a PM with ya key and details and I'll look into for ya! :-)
radeon 757 Posted October 26, 2016 Author Posted October 26, 2016 Hi Radeon I migrated my Emby server to new hardware a week ago which unfortunately coinciding with Emby support for ImagesByName being removed. Thus when I migrated as per guidelines (installed Emby on new hardware and then overwrote Emby-Server\* folders with versions from old hardware); the ImagesByName\People content was not migrated to the new Emby-Server\Metadata\People folder. I thought of copying \ImagesByName\People to Metadata\People manually but cannot do that as the target metadata folder is organised by alphabetically by sub-folder, e.g Metdata\People\A\<Name>\.... Alternatively I though of running IBN Downloader against the Metdata folder but will that work with the new metadata\People\A\<Name> ... format? If not will you bring a new version with support for the new metadata\people folder? Any other ideas welcome I can't honestly remember if the new version supports the old type but it definitely supports the new metadata\People\A\<Name>
aspdend 177 Posted October 27, 2016 Posted October 27, 2016 Yo @@aspdend! sorry i missed this! Been a busy busy bast**d recently!! @@Happy2Play is right tho, your key should be working fine assuming it was bought for this version of mediabrowser3/emby Just drop me a PM with ya key and details and I'll look into for ya! :-) @@radeon @@Happy2Play Thanks for the input - I bought it in 2014 so I'm sure that's for MB3? - either way I will ping you a PM with the key and see what you think. I bought all your plugins and this is the only one that states the key is invalid (I think that's the warning message).
blue65 2 Posted November 13, 2016 Posted November 13, 2016 With Emby downloading as "poster.jpg" and this app downloading as "folder.jpg", is Emby recognising both formats or can I force the app to download as "poster.jpg"? Thanks
Happy2Play 9811 Posted November 13, 2016 Posted November 13, 2016 With Emby downloading as "poster.jpg" and this app downloading as "folder.jpg", is Emby recognising both formats or can I force the app to download as "poster.jpg"? Thanks Emby recognizes either naming convention. But you could run it conflicts if both are present, not positive on which one takes priority.
Johnny Sideburnz 5 Posted August 7, 2017 Posted August 7, 2017 (edited) Has anybody had any conflicts having both the "poster.jpg" and "folder.jpg" located in the same folder? If so how is this issue rectified? Edited August 7, 2017 by Johnny Sideburnz
Luke 42239 Posted August 7, 2017 Posted August 7, 2017 There is no conflict. For people it will pick folder.jpg first.
majorhi 0 Posted October 11, 2017 Posted October 11, 2017 I've purchased this several times media browser 2, 3 and now with Emby. I have followed instructions for setting images by name folder and the app runs and then closes and nothing changed. I've tried several directories, C:\Users\NAME\AppData\Roaming\Emby-Server\ImagesByName as well as C:\ProgramData\MediaBrowser\ImagesByName to no avail. Please advise.
