Happy2Play 9811 Posted January 26, 2016 Posted January 26, 2016 With the changes to Emby, not creating empty People named folders anymore, this plugin has been depreciated. It does work for the folders that contain metadata and no images, if a online image exits.
e123enitan 276 Posted January 26, 2016 Posted January 26, 2016 (edited) I am able to locate the path, how do one determine progress download? The file size remain as it were before and it appears is not growing Cheers! With the changes to Emby, not creating empty People named folders anymore, this plugin has been depreciated. It does work for the folders that contain metadata and no images, if a online image exits. I am totally lost, Are U saying the path should be as below without people? And what do you mean by depreciated? The essence of buying this app is to search are download missing people where emby failed to, and the process is tedious through manual download C:\Users\Media\AppData\Roaming\Emby-Server\metadata\ Edited January 26, 2016 by e123enitan
e123enitan 276 Posted January 26, 2016 Posted January 26, 2016 I am totally lost, Are U saying the path should be as below without people? And what do you mean by depreciated? The essence of buying this app is to search are download missing people where emby failed to, and the process is tedious through manual download C:\Users\Media\AppData\Roaming\Emby-Server\metadata\ when I launch the app this message appears so quickly, then program closed, according to this message this could not be possible coz I have several missing people photos, that are yet to download. Does this app have GUI? this is pissing off, I don't get frustrated this easy, I have high hope for this app, but it look I have make bad decision 2.0.0.7 Generating Persons Name List Please Wait... Searching for empty folders Complete.............................. Starting Downloads..............................
Happy2Play 9811 Posted January 26, 2016 Posted January 26, 2016 The plugin is looking for empty people folders to get images for. Since Emby no longer creates empty folders during its scans there is nothing for this plugin to attempt to download.
e123enitan 276 Posted January 26, 2016 Posted January 26, 2016 when I launch the app this message appears so quickly, then program closed, according to this message this could not be possible coz I have several missing people photos, that are yet to download. Does this app have GUI? this is pissing off, I don't get frustrated this easy, I have high hope for this app, but it look I have make bad decision 2.0.0.7 Generating Persons Name List Please Wait... Searching for empty folders Complete.............................. Starting Downloads.............................. I activities is showing in the event log folder
e123enitan 276 Posted January 26, 2016 Posted January 26, 2016 (edited) when I launch the app this message appears so quickly, then program closed, according to this message this could not be possible coz I have several missing people photos, that are yet to download. Does this app have GUI? this is pissing off, I don't get frustrated this easy, I have high hope for this app, but it look I have make bad decision 2.0.0.7 Generating Persons Name List Please Wait... Searching for empty folders Complete.............................. Starting Downloads.............................. I made change to Config txt as below the I see several activities running on the event log [tx_id] key=xxxxxxxxxxxx [iBNDIR] key=C:\Users\Media\AppData\Roaming\Emby-Server\metadata\ [RESUME] name= Edited January 26, 2016 by e123enitan 1
e123enitan 276 Posted January 26, 2016 Posted January 26, 2016 (edited) I activities is showing in the event log folder OK the scanning have completed and it appears missing actors photos are now downloading. Thanks for your supports Edited January 26, 2016 by e123enitan
AlwinHummels 134 Posted January 26, 2016 Posted January 26, 2016 and again your activation key has been exceeded and I don't know why this happes again and again.
radeon 757 Posted January 26, 2016 Author Posted January 26, 2016 Give is a punt now @@AlwinHummels. You should be good to go! :-) 1
AlwinHummels 134 Posted January 26, 2016 Posted January 26, 2016 Thx it works again, but still don't know why this happens over and over, it's still the same pc and the only pc I used this app.
e123enitan 276 Posted January 27, 2016 Posted January 27, 2016 the config.ini contains your licence key so as long as you have extracted the exe and dont move it, it should refer to the same ini and work fine. if you can't pick the path via the folder selector dialog, just edit the config.ini section below or create it. [iBNDIR] key=C:\Users\Media\AppData\Roaming\Emby-Server\metadata\ Hi This Apps is awesome, found about 10k missing actors picture, most appreciated. Cheers
Dodgy Bob 45 Posted February 24, 2016 Posted February 24, 2016 Hey Radeon, In light of Happy2Play's 2 posts below... With the changes to Emby, not creating empty People named folders anymore, this plugin has been depreciated. It does work for the folders that contain metadata and no images, if a online image exits. The plugin is looking for empty people folders to get images for. Since Emby no longer creates empty folders during its scans there is nothing for this plugin to attempt to download. ...will your app do anything for my collection? My Emby setup was done from scratch only just recently, so there are no legacy folders and/or local references to ye olde MediaBrowser. Does your app perchance simply auto download all IBN people or have toggle options to download specific IBN people types? i.e. only actors -or- only actors and directors -or- some other combination, etc. Thanks, Dodgy Bob. 1
radeon 757 Posted February 24, 2016 Author Posted February 24, 2016 Hey @@Dodgy Bob, I'm not really sure how it's Happy2Plays place to use the words depreciated on an app he hasn't had nor has any involvement in writing. It's not in the official emby catalog and he doesn't have any direct involvement in my projects to pass such comments. I can't speak for others but I just checked my people directory and I'm still getting the blank folders generated and my app is the only thing filling them with images. If emby has or does stop generating the empty folders then I can move to other methods to get them anyway. At the moment, the app literally scans your Metadata\People directory for folders missing images and uses that folder name (the name of the person) to go get one if available from imdb so it doesn't know what "type" it's looking for. I hope that helps! :-) 2
Dodgy Bob 45 Posted February 24, 2016 Posted February 24, 2016 Schweeet! That works for me I was after some clarification is all and that pretty much sums it up. Thanks heaps @@radeon
Happy2Play 9811 Posted February 24, 2016 Posted February 24, 2016 (edited) No offense intended but as a paid customer not sure how this can be different across the board but none of my three servers generate empty people folders, folder are only created if there is metadata or images. So if I have no empty folders how can I get images for missing actors? Here is a specific example no folder created for "Stan Roth" so no image can be created, if I create or if folder is created with metadata then IMDB IBN People Downloader can pull image. http://www.imdb.com/name/nm0745027/ Edited February 24, 2016 by Happy2Play
Dodgy Bob 45 Posted February 25, 2016 Posted February 25, 2016 (edited) Ahhh, I see what @@Happy2Play is saying now @@radeon... I just went and had a look at my directory structure and this is all I've got: That's it completely expanded out My install of Emby Server on Windows is not that old - like, maybe 3 to 6 months - and thus its not an upgrade from MediaBrowser either (if that has anything to do with anything!). I guess that explains why when I first fired up the app, it ran for a total of 10secs and then closed (see log below)! 2016-02-25 22:03:21 : 2.0.0.7 2016-02-25 22:04:25 : Generating Persons Name List Please Wait... 2016-02-25 22:04:25 : Searching for empty folders 2016-02-25 22:04:25 : Complete.............................. 2016-02-25 22:04:25 : Starting Downloads.............................. 2016-02-25 22:04:30 : Sleeping for: 1000ms 2016-02-25 22:04:31 : 0 of -1 - - Level 1: No Image Available 2016-02-25 22:04:31 : -------------------------------------------------------- 2016-02-25 22:04:31 : Process Complete 2016-02-25 22:04:31 : -------------------------------------------------------- 2016-02-25 22:04:31 : 0 directories checked for missing images 2016-02-25 22:04:31 : 1 images searched for 2016-02-25 22:04:31 : 0 images downloaded Thing is though, if I pop into the web client and bring up a movie, I do have some people images already loaded - from somewhere? Is it likely that a new path to the, or an alternate, ImagesByName directory needs to be set in your app now for newer versions of Emby? Kind regards, Dodgy Bob. Edited February 25, 2016 by Dodgy Bob
ebr 16332 Posted February 25, 2016 Posted February 25, 2016 Just below that "localization" folder, is there one called "metadata"? What's in there...? 1
Happy2Play 9811 Posted February 25, 2016 Posted February 25, 2016 Correct you have to point the downloader to the new location, see post #81. 1
Dodgy Bob 45 Posted February 25, 2016 Posted February 25, 2016 (edited) Ah ha! Yeah @@ebr, after the ImagesByName folder, it goes "localization" folder, then "logs" folder, then the "metadata" folder and as you pointed out @@Happy2Play, I changed the config file to point to this location and off it went: 2016-02-26 06:14:32 : 2.0.0.7 2016-02-26 06:14:32 : Generating Persons Name List Please Wait... 2016-02-26 06:14:32 : Searching for empty folders 2016-02-26 06:14:32 : Checking: 5 2016-02-26 06:14:32 : Checking: A 2016-02-26 06:14:32 : 100 Folders Checked for no image. 102 found so far 2016-02-26 06:14:32 : 200 Folders Checked for no image. 202 found so far 2016-02-26 06:14:32 : 300 Folders Checked for no image. 302 found so far 2016-02-26 06:14:32 : 400 Folders Checked for no image. 402 found so far 2016-02-26 06:14:32 : 500 Folders Checked for no image. 502 found so far 2016-02-26 06:14:32 : 600 Folders Checked for no image. 602 found so far 2016-02-26 06:14:32 : 700 Folders Checked for no image. 702 found so far 2016-02-26 06:14:32 : 800 Folders Checked for no image. 802 found so far 2016-02-26 06:14:32 : 900 Folders Checked for no image. 902 found so far 2016-02-26 06:14:32 : 1000 Folders Checked for no image. 1002 found so far 2016-02-26 06:14:33 : 1100 Folders Checked for no image. 1102 found so far 2016-02-26 06:14:33 : 1200 Folders Checked for no image. 1202 found so far So we'll see how that goes. I didn't even think to go looking for the folder and/or having to change a config file, let alone looking for a post where someone else has already had the same issue, sorry, my bad! I was just thinking follow the app's doco and with the info from these last couple of posts between @@Happy2Play and @@radeon and I, thought, oh ok, so perhaps something is a little out of whack. Sorry again. OK, well, the app is running and finding the folders and grabbing images now, so yeah, we'll see what we end up with: 2016-02-26 06:23:05 : Sleeping for: 1000ms 2016-02-26 06:23:06 : 24 of 41057 - Aaron Auch - Level 1: No Image Available 2016-02-26 06:23:07 : 25 of 41057 - Downloading: Aaron B. Koontz - 0kb 2016-02-26 06:23:07 : 25 of 41057 - Downloading: Aaron B. Koontz - 61.44kb 2016-02-26 06:23:08 : 25 of 41057 - Downloading: Aaron B. Koontz - 136.192kb 2016-02-26 06:23:08 : 25 of 41057 - Downloading: Aaron B. Koontz - 143.88kb 2016-02-26 06:23:08 : 25 of 41057 - Download Complete: Aaron B. Koontz - 143.88kb 2016-02-26 06:23:08 : 8 images downloaded so far 2016-02-26 06:23:10 : Sleeping for: 1000ms 2016-02-26 06:23:11 : 26 of 41057 - Aaron Barnes - Level 1: No Image Available 2016-02-26 06:23:14 : Sleeping for: 1000ms 2016-02-26 06:23:15 : 27 of 41057 - Aaron Barr - Level 1: No Image Available 2016-02-26 06:23:17 : Sleeping for: 1000ms 2016-02-26 06:23:18 : 28 of 41057 - Aaron Beck - Level 1: No Image Available 2016-02-26 06:23:20 : Sleeping for: 1000ms 2016-02-26 06:23:21 : 29 of 41057 - Aaron Becker - Level 1: No Image Available 2016-02-26 06:23:24 : 30 of 41057 - Downloading: Aaron Berg - 0kb 2016-02-26 06:23:25 : 30 of 41057 - Downloading: Aaron Berg - 69.632kb 2016-02-26 06:23:25 : 30 of 41057 - Downloading: Aaron Berg - 161.792kb 2016-02-26 06:23:25 : 30 of 41057 - Downloading: Aaron Berg - 256kb Thanks @@ebr and @@Happy2Play - perhaps the doco for the app could be / should be updated to tell people to point to this location if the other does not work? Well, for those of us having a blonde moment and being stuck and unable to move on from the already set directions! Regards, Dodgy Bob. Edited February 25, 2016 by Dodgy Bob
gillmacca 17 Posted March 21, 2016 Posted March 21, 2016 Need a little advice setting this up. Had it working on my old server, but now I have a QNAP with the QNAP version of Emby installed. According to 'paths' in Emby. my people folder is in /share/CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/metadata (default location). I tried this, and also /QNAP/CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/metadata, but it says 0 directories checked in both cases. The downloader is on a laptop, connected wireless to the server Can anyone advise me on the correct location I should be using? Many thanks
Tanamur 53 Posted May 5, 2016 Posted May 5, 2016 Hi @radeon - I am getting the error stating my Activation Limit has been reached. I haven't even used the application in 5 months and was keen to update. Could you reset the limit or whatever is required? I have sent the key to the designated email address. Thanks in advance, Tanamur
gillmacca 17 Posted May 5, 2016 Posted May 5, 2016 Need a little advice setting this up. Had it working on my old server, but now I have a QNAP with the QNAP version of Emby installed. According to 'paths' in Emby. my people folder is in /share/CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/metadata (default location). I tried this, and also /QNAP/CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server/metadata, but it says 0 directories checked in both cases. The downloader is on a laptop, connected wireless to the server Can anyone advise me on the correct location I should be using? Many thanks @@radeon, Any idea where I am going wrong?
radeon 757 Posted May 5, 2016 Author Posted May 5, 2016 Hi @radeon - I am getting the error stating my Activation Limit has been reached. I haven't even used the application in 5 months and was keen to update. Could you reset the limit or whatever is required? I have sent the key to the designated email address. Thanks in advance, Tanamur Give that a go now, all should be reset. :-)
radeon 757 Posted May 5, 2016 Author Posted May 5, 2016 @@radeon, Any idea where I am going wrong? I couldn't honestly say. You need to be in the directory above the People directory and as long as that people directory is generate the folders like in windows then you should be fine. Sorry i can't be of much help, i only use emby on windows and the tool works fine for me. I tend to run it weekly and it still picks up new images. Sorry buddy.
