syplex 4 Posted January 15, 2017 Posted January 15, 2017 (edited) I am having playback problems with videos on Emby and my QNAP TS-251+. Specifically playing videos I am recording with my DVR (Channels App DVR). But Blu Ray MKV movies (created with MakeMKV) have problems too. When I try to watch in the browser, the video skips and cuts out frequently. When watching using the Apple TV app, the videos take a really long time to start (60+ seconds) and then cut out after awhile (maybe 1-3 minutes?). I've tried many combinations of versions and libraries on the QNAP and just tried upgrading the QTS firmware to 4.3.2 beta. But I have had the same problem every time. I've also tried changing the the settings in the Transcoding options section: Hardware Acceleration, Transcoding Thread Count, Enable Throttling, etc. without success. Log files attached. Emby Version: 3.1.2.0 x64 QTS Version: Tried 4.2.2 and 4.3.2 QMono Version: 4.6.2.7 x64 ffmpeg Version: 3.2.2 x64 ffmpeg-transcode-f0e267d2-b5d2-49a0-baa1-103ef0835bdb.txt.txt server-63620022299.txt.txt Edited January 15, 2017 by syplex
Luke 42239 Posted January 15, 2017 Posted January 15, 2017 Hi @@syplex, in this particular log you are just not getting fast enough transcoding. Browsers do not support mpeg2 therefore the server has to convert it, and this can be a very costly process. Here's a few suggestions I can offer: - Try using a different Emby app that can direct play those files, like the Emby Android apps for example can handle mpeg2 natively. - Use the Emby DVR which can convert your mpeg2 to h264 on the fly - Check out the Emby folder sync plugin which can pre-convert your files for easy watching later Let us know if this helps. thanks !
syplex 4 Posted January 15, 2017 Author Posted January 15, 2017 Thanks for your quick reply! I tried safari iOS browser, chrome browser, Apple TV emby app, and the iOS emby app. But everything has the same problem. Is this a problem with the QNAP model I have and if so is there a model fast enough to work properly with emby and my device types? I just bought it and could try another model or a synology if that's better. I looked at folder sync but I really don't want to make copies of everything for all of the different devices that will be connecting. If the qnap isn't fast enough for emby wouldn't Emby DVR have the same problem?
syplex 4 Posted January 16, 2017 Author Posted January 16, 2017 Will emby be able to transcode on the QNAP TS-x53A?
Luke 42239 Posted January 16, 2017 Posted January 16, 2017 Will emby be able to transcode on the QNAP TS-x53A? Yes, certainly.
syplex 4 Posted January 17, 2017 Author Posted January 17, 2017 (edited) Yes, certainly. Interesting, the CPU has the same number of cores but is actually slower frequency than the J1900 in the TS-251+. Can it take advantage of hardware acceleration? Also, I noticed I am able to play back the same DVR mpeg2 files via their web server in the browser on my iPad and via their Apple TV app. I wonder if there is a way to play natively without transcoding that their software is taking advantage of? The dvr software is Channels DVR. I have it running on the TS-251+. Edited January 17, 2017 by syplex
Luke 42239 Posted January 18, 2017 Posted January 18, 2017 In a web browser no, but they may have gpu accelerated transcoding enabled by default whereas for us it's off by default. In the server transcoding menu you can try the VA API option and see if that performs better than transcoding with cpu.
syplex 4 Posted January 20, 2017 Author Posted January 20, 2017 Tried VA API, but I didn't see any difference? Another question, will VA API affect performance on the apple TV emby app?
Luke 42239 Posted January 21, 2017 Posted January 21, 2017 @@syplex, if you didn't see a difference then perhaps it wasn't being used? please provide an ffmpeg log so that we can review, thanks !
raven-au 17 Posted February 13, 2017 Posted February 13, 2017 Will emby be able to transcode on the QNAP TS-x53A? Unlikely. Yes, certainly. I don't think that you are right about that Luke. Interesting, the CPU has the same number of cores but is actually slower frequency than the J1900 in the TS-251+. Can it take advantage of hardware acceleration? Also, I noticed I am able to play back the same DVR mpeg2 files via their web server in the browser on my iPad and via their Apple TV app. I wonder if there is a way to play natively without transcoding that their software is taking advantage of? The dvr software is Channels DVR. I have it running on the TS-251+. I happened to try and use the Web app. recently. A TS-253 Pro (Intel® Celeron® 2.0GHz quad-core processor, with 8GB RAM) can't transcode mpeg2 to a Firefox browser instance so the TS-253A probably isn't going to go very well either. At first I thought the problem was the CPU as I have often had problems when things need to transcode and the NAS CPU power is not quite sufficient but there is more going on than just that. For example I encoded some 480p shows just recently and tried to play one (from the TS-543 Pro) in the web app. using Firefox. That showed the same problem described here with the transcode using only about 50% of the available CPU and little else going on on the NAS so I think there's more going on with the transocode execution than just CPU limitations. Even stranger the AppleTV app transcodes quite a bit too (apparently due to limited video support in the iOS player) but it has somewhat less problems. I'm fairly sure that, overall, Emby transodes have worked better than they do now in the past but don't have specific evidence other than what I've described above. Ian
Luke 42239 Posted February 13, 2017 Posted February 13, 2017 mpeg2 is not really a good measuring stick. h264 is much more widely used and the qnap should have no problems with some light h264 transcoding.
mmartinez 0 Posted November 21, 2017 Posted November 21, 2017 Hi I am having similar issues, I have a QNAP TS-251 running Emby 3.2.36.0, it will play 3 home movies and it stops playing. I have Amazon Prime and I am able to see their movies without any issues. Could someone please give me some pointers that could alleviate this issue. Thank You Mario
Luke 42239 Posted November 21, 2017 Posted November 21, 2017 Hi I am having similar issues, I have a QNAP TS-251 running Emby 3.2.36.0, it will play 3 home movies and it stops playing. I have Amazon Prime and I am able to see their movies without any issues. Could someone please give me some pointers that could alleviate this issue. Thank You Mario hi there @@mmartinez, please discuss an example, and attach the information requested in how to report a media playback issue. thanks !
mmartinez 0 Posted November 22, 2017 Posted November 22, 2017 I am attaching 2 log files form Saturday November 18 when emby stopped playing the home movies. Thank you Mario emby.logs.mario.11.18.17.zip
Luke 42239 Posted November 22, 2017 Posted November 22, 2017 Can you also please attach the emby server log? thanks.
mmartinez 0 Posted November 22, 2017 Posted November 22, 2017 hi The earliest server log is from 11.19.17, This issue happens all the time but I used emby on 11.18.17, hopefully you can see what the issue is. thank you for your help Mario server11.19.17.embyLog.txt.zip
Luke 42239 Posted November 24, 2017 Posted November 24, 2017 As a test, would you like to try this new QNAP installation we are offering for testing? https://emby.media/community/index.php?/topic/51334-new-qnap-package-for-testing It will soon become our official QNAP package and will replace the community package you are using. Thanks !
