edwin777 0 Posted January 11, 2018 Posted January 11, 2018 different arguments would be good, the ones that work and the ones that wont. I'm setting this up tonight, so thanks for the post guys very helpful Thanks
Natilus13 14 Posted January 11, 2018 Author Posted January 11, 2018 @@edwin777 Check out this post towards the bottom for a good list of arguments that @@funwithmedia uses https://emby.media/community/index.php?/topic/43054-considering-emby/?p=402646
Luke 42243 Posted January 11, 2018 Posted January 11, 2018 @@edwin777 what external player are you planning to use?
Natilus13 14 Posted January 11, 2018 Author Posted January 11, 2018 True, the arguments are for VLC (which is what I was setting up when I originally created this post).
edwin777 0 Posted January 11, 2018 Posted January 11, 2018 VLC, working well. I like the fact I can tap "C" to zoom
Natilus13 14 Posted January 11, 2018 Author Posted January 11, 2018 @@edwin777 Yes, VLC has been working quite well for me. I am planning to do some more testing with emby theather as the player instead of VLC though. I am hoping one day to just be able to use the one application instead of having to call an external one for file playback. Glad you got things working on your end :-) Cheers!
