NemesisZeRo 7 Posted January 12, 2017 Author Posted January 12, 2017 I looked, thru the settings like a million times.. Well, that proves that the eyes are the first place you get blind on.. I'll fix that, and do a rescan, hopefully that would do the trick.. otherwise I'll be back [emoji4] Thanks for helping a lame as!
NemesisZeRo 7 Posted January 12, 2017 Author Posted January 12, 2017 Quick update; I created a new user called jobe, because just changing the info don't work. Now it "works", but there are things missing, but I just have to fill them.. Skickat från min SM-J500FN via Tapatalk
Happy2Play 9802 Posted January 12, 2017 Posted January 12, 2017 That would mean there is a config somewhere that is still pointing there. So the question would be what is being written to "c:/users/jobe/desktop/mediaserver"
NemesisZeRo 7 Posted January 13, 2017 Author Posted January 13, 2017 That would mean there is a config somewhere that is still pointing there. So the question would be what is being written to "c:/users/jobe/desktop/mediaserver"It was there I Had the server standalone. I have however now created a new user called jobe and are moving the standalone installation to that one too see if it solves the issue..
NemesisZeRo 7 Posted January 13, 2017 Author Posted January 13, 2017 Well, it solved the issue with them metadata, almost, now I finds all the movies, however it needed a total new rescan of all movies. Which is strange, since I this time I took a straight copy of the working old directory, to the new installation of Windows, the same username and everything, same path,.. so I still find it strange that I needed to do a full rescan, but never mind, it works, but it takes a while due the scan.. And again thx for the support. I Skickat från min SM-J500FN via Tapatalk
x88dually 9 Posted January 16, 2017 Posted January 16, 2017 When i moved my install, i rebooted pc before i double clicked exe to run setup and everything worked fine that way. emby 3.0.7200 on Win7 ult.
Luke 42197 Posted January 16, 2017 Posted January 16, 2017 When i moved my install, i rebooted pc before i double clicked exe to run setup and everything worked fine that way. emby 3.0.7200 on Win7 ult. Hi @@x88dually, thanks for the feedback. As always, we recommend updating to the latest version of Emby Server.
x88dually 9 Posted January 16, 2017 Posted January 16, 2017 (edited) main emby is on 3.1.2.0 backup is on 3.0.7200 Edited January 16, 2017 by x88dually
Luke 42197 Posted January 16, 2017 Posted January 16, 2017 main emby is on 3.1.2.0 backup is on 3.0.7200 Thanks for the feedback !
x88dually 9 Posted January 19, 2017 Posted January 19, 2017 (edited) i play with 3.0.7200 before anything goes to 3.1.2.0 who cares its the backup, i've reloaded a few times from messing it up....lol I'm really loving the program though Edited January 19, 2017 by x88dually
