"Restore User Data" procedure help
Happy2Play
Since I don't really know databases, I don't understand this procedure.  Can someone break this down for someone who has no idea.  What do you enter when it ask "Please specify the database name under which you want to access the attached database"?  Where does that command go?
Restore User Data
Your user data is stored in our old library.db file, and we'll need to run some sql queries to import this into the new library.db in the new Emby Server installation. You'll need a Sqlite database editor such as DB Browser for Sqlite.
You'll need to open the old library.db file, then attach the new library.db file. You can then migrate the data using:
REPLACE INTO NewDB.userdata SELECT * FROM userdata
Happy2Play
Anyone?
Hi @@Happy2Play
I am a database guy and that message is confusing to me as well. Where does it show up? Is it in the "Backup Plugin"?
Hi @@Happy2Play
Oh sure then it is easy , :P
Based on your posts and what I have. still one question
Quote from the wiki
Shutdown the old server instance and backup the following files and directories:
/ProgramData/config
/ProgramData/plugins
/ProgramData/data/collections
/ProgramData/data/playlists
/ProgramData/data/displaypreferences.db  /ProgramData/data/userdata_v2.db (if present)
/ProgramData/data/users.db
@@Luke  userdata_v2.db isn't being updated any longer and was not auto deleted (which is fine) , if it is copied over it will import again right? If so you may want to add  it as an optional step to the wiki with a warning that unless the replace is run, users and watched state etc will only be current  as the date on the file.
As this really isn't for the casual user.. another thought would be to add up front... That some basic familiarity with sql and SQLite tools is required to successfully complete this manually.
@@Happy2Play the steps to run the replace will vary based on the tool (I am most familiar with SQLite Studio). Maybe we could put together a script ?
Restore User Data
SqliteBrowser is pretty good as well.
  • 2 months later...
I have followed the process and opened the old library and attached the new one, using DB Browser for SQLIte.
What do I do now with "REPLACE INTO NewDB.userdata SELECT * FROM userdata"
Where exactly do I place that text? I never used this program before.
THanks in advance
Also when I attach the new library database, Db Browser asks me to type a database name: "Please specify the database name under which you want to access the attached database".
What name should I type?
When I run the SQL by placing the text in the EXECUTE SQL tab, I get the following
no such table: NewDB.userdata: REPLACE INTO NewDB.userdata SELECT * FROM userdata
BTW I have a premiere account, but my motherboard died so I had to do a clean reinstall of windows on a different hard-disk. So no way to create a backup for me..
So I started again and this time typed NewDB when DB Browser asks me to type a database name.
It reports: "Query executed successfully: REPLACE INTO NewDB.userdata SELECT * FROM userdata (took 423ms)"
Do I need to save anything now for it to work? I clicked on Write Changes as well. I restarted emby and no favourites or watched items or even names of useres have migrated across
Has the scan completely finished on the new setup and everything is properly identified?
yep that happened weeks ago all my movies are listed, it took days before the scan picked up everything.
What if I deleted the userdata table and imported the old one?
I exported and opened the old userdata table, it runs to TTK column in the spreadsheet, and the data is unintelligible to me
It only contains 59 rows. Is that right?
Same number of rows (59) on the new table, but it runs only to SGZ columns.
Deleted the table and tried importing the old one: Error importing table unrecognized token etc etc massive list error box
Tried to plainly replace the new library file with the older one. None of the old favourites or watched movies are retained. Put the new one back in and i can see the new favorites and played items since I rebuilt the database. I am out of ideas here guys.
I discovered that you can use Macrium Reflect to build a Windows PE bootable disc to repair any boot issues. I will build one now and switch the old hard disk back and try to repair the windows 10 installation. If that works I can install the backup plugin and fix it that way.
  • 1 year later...
CaptainSandwich
I'm also  new to all this SQL stuff and have reached this point as well. My new database didn't have a 'userdata' table, so the replace command didn't intially work. After creating a userdata table in the new database, the replace command successfully ran. But, could someone please describe how this change is saved permanently to the database? After exiting dbviewer and opening the new database, the userdata table is still empty.
Thanks muchly.
Happy2Play
Thanks muchly.
What program are you using to view the database?
In DB Browser for SQLite when I make changes it ask me if I want to save when database is closed/exit.  You can click "File" and select write changes (CTRL+s) also.
Happy2Play
Ideally you should use the "Server Configuration Backup" plugin for this .
CaptainSandwich
I'm using DB Browser for SQLite. Ah, looks like that did the trick. It threw me a little bit by asking if I wanted to save changes to the old database file.
Yeah, after the above the results weren't quite as expected. Tried the plugin and it looks to have worked a treat.
Thanks!
The new database I was importing into had a "UserDatas" table, but even after merging it didn't work (syncing up my view history). I used the plugin to restore a backup and it's the same thing, view history isn't synced. :(
Edit - I stand corrected! The new install created a user 'emby' - I had to switch to the user that I backed up and imported to see the view history.
Edited by bradford
