Morphello 2 Posted January 10, 2017 Posted January 10, 2017 Hi, I've got Emby Server Version 3.1.2.0 running on Windows 10 x64 (1511) and I've caught it 3 times in the past month or so using high cpu usage. Seems to completely max out 2 threads, which works out to be 46-53% of the CPU usage on my quad core. According to my system diagnostic logs it lasts indefinitely until I restart Emby. During the error, the system runs as normal (2 threads are just in use). I use Emby Server with the Emby Addon for Kodi. I run Emby Server portably (in its own non default folder). This issue has not been present for long and I haven't changed my settings since setting up the server, at least a year ago. I've attached a log of the most recent day, although the issue itself may have started more than a week ago. Thank you for your time. Log 1.txt After Restart.txt
Luke 42197 Posted January 10, 2017 Posted January 10, 2017 Hi, can you try removing all Emby plugins and seeing if the issue persists with just the core server? Thanks !
Morphello 2 Posted January 10, 2017 Author Posted January 10, 2017 Yes alright, I'll give that a go. Only two plugins installed. Pushbullet, which didn't get used and Emby for Kodi Sync Queue. Sadly removing the Sync Queue plugin dramatically increases the time it takes to do a resync of the database, should I need to do one soon. I'll uninstall both and report back if anything changes.
