lifespeed 42 Posted January 10, 2017 Posted January 10, 2017 I was watching some OTA HDTV programming, and noticed bad de-interlacing video artifacts. So I went and checked the renderer in Emby Theater. It was set to auto, so I switched to MadVR. It did a great job at deinterlacing the HDTV 1080i video. Unfortunately, I have noticed that MadVR often breaks the audio sync to video, which can make it unwatchable. So I resort to watching in Windows Media Player, which does not have this issue, or use MadVR. I use analog output from an Asus D2X PCIe sound card. Are others experiencing this issue?
SikSlayer 254 Posted January 10, 2017 Posted January 10, 2017 I think your CPU must not be able to handle MadVR.
lifespeed 42 Posted January 10, 2017 Author Posted January 10, 2017 I think your CPU must not be able to handle MadVR. CPU is an i7-6800K, should be fine.
SikSlayer 254 Posted January 10, 2017 Posted January 10, 2017 CPU is an i7-6800K, should be fine. Yikes, nevermind that then...
Marc_G 95 Posted January 10, 2017 Posted January 10, 2017 I have seen the MadVR audiosync problem on my i5-6600, an i5-4670, and a tiny little TV box. The content was DVD rip of Japanese movie, bad comb effects so I tried MadVR. Switched back to Auto or EVR+ due to bad sync. Didn't think much of it at the time but figured to chime in here.
