Ben Z 86 Posted January 9, 2017 Posted January 9, 2017 (edited) I'm using an ODROID C1+ with OpenELEC as a client device. This device is listed as 'Device X' and connected with the user 'A' with Emby. I'm also using different computers as clients. Everything is fine. I recently added a new client device, an ODROID C2 with LibreELEC. Let's say I call it 'Device Y' and I connect it with the emby user 'B'. The problem is that 'Device Y' doesn't list in emby devices and is not active. Even worst, when I reboot the server, it says that 'Device X' is connected with user 'B'. I can use both devices just fine but it's a mess since it changes the viewed contents of both users randomly. 'Device X' is local and 'Device Y' is outside homenetwork though. How to restart all the device ID's or what's the problem? I tried to change the MAC addresses but it doesn't work. Deleting the visible device in the list doesn't seem to work also. server-63619576295.txt Edited January 17, 2017 by Ben Z
Luke 42244 Posted January 14, 2017 Posted January 14, 2017 If the device is running an Emby app it will only show when it is actively connected. Does this help?
Solution Ben Z 86 Posted January 17, 2017 Author Solution Posted January 17, 2017 (edited) I'm not sure what caused the problem but I found the solution... I just had to reset the devices ID from Kodi under Emby plugin's advanced settings. lol Edited January 17, 2017 by Ben Z
