nicco82 1 Posted January 8, 2017 Posted January 8, 2017 Hi, I'm noticing that when watching livetv in emby the same 720p video stream is not as smooth as it is in Live channels with CumulusTV. I Also noticed that if I disable direct stream the FPS increase but still the video is not fluid. If I watch the same stream in my mac from the Emby Web Client the video looks fine. I was wondering if there is any way to switch from VLC to ExoPlayer (used by cumulus) or if there is any way to tweak VLC. Thanks!
ebr 16339 Posted January 8, 2017 Posted January 8, 2017 There is an option in the settings under "Live TV" of whether or not to try to use VLC. If that isn't enabled, it is going to use Exo.
nicco82 1 Posted January 8, 2017 Author Posted January 8, 2017 Thanks I've tried it but then it's probably due to the lack of hardware acceleration because it's still not fluid. Do you know if it's enabled by default or how to enable it?
