Emby for Kodi Buffering Problems-Please Help
Hi All,
Since 2010, I had WMC running on Windows 7 PC and old MediaSmart x280n extenders.  I have switched over to Emby backend and  Kodi Jarvis 16.1 frontend and am currently an Emby Premier subscriber.  I have a Beelink GT1 DDR3 2G Android Box connected to my network by Ethernet, the Emby backend is running on Windows 7 PC.  Initially, I downloaded the Emby app from Google Play and ran that as a front end.  It streamed the live TV and PVR recordings perfectly—no buffering at all.
I then installed the Kodi add-on as per instructions in the kodi.wiki Add-on: Emby.  I installed the Stable Version.  The Emby Kodi add-on then suffered severe (constant) buffering (but no stuttering) while watching live TV.  The Live TV PVR recordings, however, streamed perfectly.
I then created and edited the advancedsettings.xml file and added the following settings:
curllowspeedtime: 300
cachemembuffersize: 262144000
buffermode (1)
realbufferfactor (80)
minvideocachelevel (60)
Nothing changed, the Kodi add-on for Emby still constantly buffered.
I also downloaded and installed the Emby-Kodi add-on (beta) and there was no change, the live TV streams constantly buffered.
Can you please help me troubleshoot this?  I have exhausted all that I know to do.
Thanks!
Guest
