HaraldBluetooth 22 Posted January 7, 2017 Posted January 7, 2017 Hi I've tried Emby Theater and I've 7,000+ movies in my database and ET only shows movies up to the letter L.This issue has been there since the first release of ET. There is no problem, when I'm scrolling through the movies in my browser.
Koleckai Silvestri 1154 Posted January 7, 2017 Posted January 7, 2017 It was 1500 but i think they increased it. Don't know the new limit. If you choose L on the alphabet selection tool, it should show more.
HaraldBluetooth 22 Posted January 9, 2017 Author Posted January 9, 2017 (edited) Thanks for your answer, allthough I think this limit should be higher or at best non-existent Edited January 9, 2017 by HaraldBluetooth
Jobber8742 9 Posted January 9, 2017 Posted January 9, 2017 Thanks for your answer, allthough I think this limit should be higher or at best non-existent It's a flaw, not a set limit they put in place. You'd think it'd be on top of their list to fix but there must be some issues preventing that.
