Erik 124 Posted January 7, 2017 Posted January 7, 2017 Was hoping someone could help. I have an HDhomerun unit and has been resetting when trying to record more than 1 show at a time. Emby shows it as recording, but its not and the tuners are all free (from the hdhomerun unit web interface) and the system log says application watchdog as the reason for the reset. Note: Emby must be restarted to have it realize the recording is not actually recording (clicking cancel doesnt do anything either) I opened trouble tickets with the HDhomerun manufacturer and they have replaced the units 3 times now with all the same result. So different power supplies/different units/updated firmware and still having issues. Could this be a problem with emby causing the unit to reset? (just throwing that out there, even though i doubt any DLNA commands should cause this) Any idea's would be greatly appreciated.
Guest asrequested Posted January 7, 2017 Posted January 7, 2017 I'm thinking one of two things. Your cabling (coax, terminations, corrosion) or something to do with your network (switch, patch cable, router)
Erik 124 Posted January 7, 2017 Author Posted January 7, 2017 (edited) Thanks @ I went and checked the coax (with a test tool) and its all perfect. The Unit plugs into a D-link 24 port Gigabit switch (i will replace the cable) and the server cable is plugged into the same switch. So ill see if that makes any difference. As the logs for the HDhomerun aren't available after a reset...i went through the emby logs and nothing really stands out, just both tuners being used. However, each time the reset doesn't occur randomly during the show, its always when one show ends and another begins with both tuners in use. That's why i wonder if a command from emby may be involved during the switch/or continous record (ending show and starting show on same channel with padding in use). I will keep testing, but @@Luke Do you have any idea from the emby side of things? The log is large so here is a section from the timeframe the reset occured: 2017-01-06 20:59:19.5865 Info HttpClient: Checking for cache file E:\Emby Server - Cache\Cache\cache\httpclient\e7b7a4b7ad461b55451ffbdac1655e50 2017-01-06 20:59:19.5865 Info HttpClient: HttpClientManager GET: http://192.168.123.145/lineup.json 2017-01-06 20:59:19.5865 Debug App: Channels from http://192.168.123.145: [{"Name":"WGRZ-HD","Number":"2.1","Id":"hdhr_2.1_5a66870c0a91dc9f001e12cd22994aaa","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WGRZ2-2","Number":"2.2","Id":"hdhr_2.2_79d19992d810ccd6c9cbd6b09ddf0adf","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WGRZ2-3","Number":"2.3","Id":"hdhr_2.3_b37caf11e993a6b916778db5e110892b","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WIVB-HD","Number":"4.1","Id":"hdhr_4.1_ed3fdcb0ba47e611b9ea97eaf976c361","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CBLT-DT","Number":"5.1","Id":"hdhr_5.1_d64ffa694146e2f0bbab7424cfafece9","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WKBW-HD","Number":"7.1","Id":"hdhr_7.1_577bd4328f2afbdcee14f43e9a05659d","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"LAFF","Number":"7.2","Id":"hdhr_7.2_1b9eb6e9b8cff5c14a269cb02bf70030","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"ESCAPE","Number":"7.3","Id":"hdhr_7.3_61b8969ff51159f76d8f0a017fa7e6cb","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CFTO","Number":"9.1","Id":"hdhr_9.1_e90ce46cf0ec35bb6e01fd200e19a3f2","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CHCH-DT","Number":"11.1","Id":"hdhr_11.1_a1fa2ba34cd46556ba7e5fd371c61439","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WNED-HD","Number":"17.1","Id":"hdhr_17.1_452a0669751e43c53914a329cf02fc6a","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Think","Number":"17.2","Id":"hdhr_17.2_ca97ab3df6c07e906bcf980f45801434","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Unknown","Number":"19.1","Id":"hdhr_19.1_0b11a4ae0ac8f6a3cb0c220eafbc7805","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WNLO-HD","Number":"23.1","Id":"hdhr_23.1_b8c764c0759f765dd7f114db192029f8","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Bounce","Number":"23.2","Id":"hdhr_23.2_20409eebf9c6b92fe90de6d751df8f88","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WUTV","Number":"29.1","Id":"hdhr_29.1_62c5db15a178bd1436883466050d9115","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Country","Number":"29.2","Id":"hdhr_29.2_644cfb4eed700a0f6c06f3089b9905a2","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Grit TV","Number":"29.3","Id":"hdhr_29.3_1318a340dcca2413b69fe93a53457c04","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CHCJ-DT","Number":"35.1","Id":"hdhr_35.1_219bd6d566dc0d0e549431d4d7221ae1","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CITS-HD","Number":"36.1","Id":"hdhr_36.1_1848ad8039409f7890aa38235a81677f","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CJMT","Number":"40.1","Id":"hdhr_40.1_45668130c64dd66381e881a8a7be5436","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CIII-HD","Number":"41.1","Id":"hdhr_41.1_caf7d7aa809b271da4706835d9af7312","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CKVP-DT","Number":"42.1","Id":"hdhr_42.1_0a13609abf0e585b7a6efdc02f740351","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CFMT","Number":"47.1","Id":"hdhr_47.1_504804b62db7051414b04185c593160a","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CITYTV","Number":"57.1","Id":"hdhr_57.1_7690f0ccea2c7ef8219df73cf289f4f4","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"}] 2017-01-06 20:59:19.5865 Info App: Streaming Channel hdhr_35.1_219bd6d566dc0d0e549431d4d7221ae1 2017-01-06 20:59:19.5865 Info App: GetChannelStream: channel id: hdhr_35.1_219bd6d566dc0d0e549431d4d7221ae1. stream id: native_ce17fa8006bdeac8a15313aa988ef823 profile: native 2017-01-06 20:59:19.5865 Info App: Opening HDHR Live stream from http://192.168.123.145:5004/auto/v35.1 2017-01-06 20:59:19.5865 Info HttpClient: HttpClientManager GET: http://192.168.123.145:5004/auto/v35.1 2017-01-06 20:59:19.6021 Debug App: Channels from http://192.168.123.145: [{"Name":"WGRZ-HD","Number":"2.1","Id":"hdhr_2.1_5a66870c0a91dc9f001e12cd22994aaa","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WGRZ2-2","Number":"2.2","Id":"hdhr_2.2_79d19992d810ccd6c9cbd6b09ddf0adf","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WGRZ2-3","Number":"2.3","Id":"hdhr_2.3_b37caf11e993a6b916778db5e110892b","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WIVB-HD","Number":"4.1","Id":"hdhr_4.1_ed3fdcb0ba47e611b9ea97eaf976c361","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CBLT-DT","Number":"5.1","Id":"hdhr_5.1_d64ffa694146e2f0bbab7424cfafece9","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WKBW-HD","Number":"7.1","Id":"hdhr_7.1_577bd4328f2afbdcee14f43e9a05659d","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"LAFF","Number":"7.2","Id":"hdhr_7.2_1b9eb6e9b8cff5c14a269cb02bf70030","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"ESCAPE","Number":"7.3","Id":"hdhr_7.3_61b8969ff51159f76d8f0a017fa7e6cb","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CFTO","Number":"9.1","Id":"hdhr_9.1_e90ce46cf0ec35bb6e01fd200e19a3f2","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CHCH-DT","Number":"11.1","Id":"hdhr_11.1_a1fa2ba34cd46556ba7e5fd371c61439","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WNED-HD","Number":"17.1","Id":"hdhr_17.1_452a0669751e43c53914a329cf02fc6a","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Think","Number":"17.2","Id":"hdhr_17.2_ca97ab3df6c07e906bcf980f45801434","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Unknown","Number":"19.1","Id":"hdhr_19.1_0b11a4ae0ac8f6a3cb0c220eafbc7805","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WNLO-HD","Number":"23.1","Id":"hdhr_23.1_b8c764c0759f765dd7f114db192029f8","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Bounce","Number":"23.2","Id":"hdhr_23.2_20409eebf9c6b92fe90de6d751df8f88","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"WUTV","Number":"29.1","Id":"hdhr_29.1_62c5db15a178bd1436883466050d9115","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Country","Number":"29.2","Id":"hdhr_29.2_644cfb4eed700a0f6c06f3089b9905a2","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"Grit TV","Number":"29.3","Id":"hdhr_29.3_1318a340dcca2413b69fe93a53457c04","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":false,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CHCJ-DT","Number":"35.1","Id":"hdhr_35.1_219bd6d566dc0d0e549431d4d7221ae1","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CITS-HD","Number":"36.1","Id":"hdhr_36.1_1848ad8039409f7890aa38235a81677f","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CJMT","Number":"40.1","Id":"hdhr_40.1_45668130c64dd66381e881a8a7be5436","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CIII-HD","Number":"41.1","Id":"hdhr_41.1_caf7d7aa809b271da4706835d9af7312","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CKVP-DT","Number":"42.1","Id":"hdhr_42.1_0a13609abf0e585b7a6efdc02f740351","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CFMT","Number":"47.1","Id":"hdhr_47.1_504804b62db7051414b04185c593160a","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"},{"Name":"CITYTV","Number":"57.1","Id":"hdhr_57.1_7690f0ccea2c7ef8219df73cf289f4f4","TunerHostId":"39c47632c2a544129688218d14ef860c","ChannelType":"TV","IsFavorite":true,"IsHD":true,"AudioCodec":"AC3","VideoCodec":"MPEG2"}] 2017-01-06 20:59:19.6021 Info App: Streaming Channel hdhr_2.1_5a66870c0a91dc9f001e12cd22994aaa 2017-01-06 20:59:19.8379 Info App: Opened HDHR stream from http://192.168.123.145:5004/auto/v35.1 2017-01-06 20:59:19.8379 Info App: Beginning multicastStream.CopyUntilCancelled 2017-01-06 20:59:19.8379 Info App: Returning mediasource streamId 39c47632c2a544129688218d14ef860cnative_ce17fa8006bdeac8a15313aa988ef823, mediaSource.Id 8ff67a1cc3234abd9984ae889091fc71_native_ce17fa8006bdeac8a15313aa988ef823, mediaSource.LiveStreamId 2017-01-06 20:59:19.8379 Info App: Live stream 39c47632c2a544129688218d14ef860cnative_2676d53f54ee4184a09f1722be7b72cf consumer count is now 2 2017-01-06 20:59:19.8535 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow 2017-01-06 20:59:19.8535 Debug LibraryMonitor: New file refresher created for \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow 2017-01-06 20:59:19.8535 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 20:59:19.8535 Debug LibraryMonitor: Resetting file refresher from \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow to \\SERVER\Emby Server - TV Recordings$\Series 2017-01-06 20:59:19.8535 Info App: Beginning recording. Will record for 61.669107575 minutes. 2017-01-06 20:59:19.8535 Info App: Writing file to path: \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4\Sleepy Hollow S04E01 Columbia.ts 2017-01-06 20:59:19.8535 Info App: Opening recording stream from tuner provider 2017-01-06 20:59:19.8535 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4 2017-01-06 20:59:19.8535 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4 2017-01-06 20:59:19.8535 Info HttpClient: HttpClientManager GET: http://127.0.0.1:8096/LiveTv/LiveStreamFiles/1a47bea2965c4b529a9349c12a0c50bd/stream.ts 2017-01-06 20:59:19.8535 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 2017-01-06 20:59:19.8535 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 2017-01-06 20:59:19.8535 Info HttpServer: HTTP GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/1a47bea2965c4b529a9349c12a0c50bd/stream.ts. UserAgent: Emby/3.0 2017-01-06 20:59:19.8535 Info App: Beginning recording. Will record for 121.669107575 minutes. 2017-01-06 20:59:19.8535 Info App: Writing file to path: \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\Emerald City S01E01 The Beast Forever; Prison of the Abject.ts 2017-01-06 20:59:19.8535 Info App: Opening recording stream from tuner provider 2017-01-06 20:59:19.8535 Info HttpClient: HttpClientManager GET: http://127.0.0.1:8096/LiveTv/LiveStreamFiles/a17b9f6ecd5147c58bed2573db81baac/stream.ts 2017-01-06 20:59:19.8535 Info HttpServer: HTTP GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/a17b9f6ecd5147c58bed2573db81baac/stream.ts. UserAgent: Emby/3.0 2017-01-06 20:59:19.9785 Info App: Opened recording stream from tuner provider 2017-01-06 20:59:19.9785 Info App: Opened recording stream from tuner provider 2017-01-06 20:59:19.9785 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\Emerald City S01E01 The Beast Forever; Prison of the Abject.ts 2017-01-06 20:59:19.9785 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\Emerald City S01E01 The Beast Forever; Prison of the Abject.ts 2017-01-06 20:59:19.9785 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4\Sleepy Hollow S04E01 Columbia.ts 2017-01-06 20:59:19.9785 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4\Sleepy Hollow S04E01 Columbia.ts 2017-01-06 20:59:20.0879 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 20:59:20.1035 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 20:59:20.1035 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\Emerald City S01E01 The Beast Forever; Prison of the Abject.nfo 2017-01-06 20:59:20.1347 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\tvshow.nfo 2017-01-06 20:59:20.1347 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\tvshow.nfo 2017-01-06 20:59:20.1347 Info App: Copying recording stream to file \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\Emerald City S01E01 The Beast Forever; Prison of the Abject.ts 2017-01-06 20:59:20.1347 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\Emerald City S01E01 The Beast Forever; Prison of the Abject.nfo 2017-01-06 20:59:20.1347 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4\Sleepy Hollow S04E01 Columbia.nfo 2017-01-06 20:59:20.1660 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4\Sleepy Hollow S04E01 Columbia.nfo 2017-01-06 20:59:20.1660 Info App: Copying recording stream to file \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4\Sleepy Hollow S04E01 Columbia.ts 2017-01-06 20:59:20.9814 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\Emerald City S01E01 The Beast Forever; Prison of the Abject.ts 2017-01-06 20:59:20.9814 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\Emerald City S01E01 The Beast Forever; Prison of the Abject.ts 2017-01-06 20:59:44.8230 Debug Dlna: Search Request Received From 192.168.123.50:62955, Target = ssdp:all 2017-01-06 20:59:44.8230 Debug Dlna: Search Request Received From 192.168.123.50:62956, Target = ssdp:all 2017-01-06 20:59:44.9323 Debug Dlna: Search Request Received From 192.168.123.50:62955, Target = ssdp:all 2017-01-06 20:59:44.9323 Debug Dlna: Search Request Received From 192.168.123.50:62956, Target = ssdp:all 2017-01-06 20:59:45.0418 Debug Dlna: Search Request Received From 192.168.123.50:62955, Target = ssdp:all 2017-01-06 20:59:45.0418 Debug Dlna: Search Request Received From 192.168.123.50:62956, Target = ssdp:all 2017-01-06 21:00:18.0594 Debug Dlna: Search Request Received From 192.168.123.134:61192, Target = urn:dial-multiscreen-org:service:dial:1 2017-01-06 21:00:19.0594 Debug Dlna: Search Request Received From 192.168.123.134:61192, Target = urn:dial-multiscreen-org:service:dial:1 2017-01-06 21:00:20.0594 Debug Dlna: Search Request Received From 192.168.123.134:61192, Target = urn:dial-multiscreen-org:service:dial:1 2017-01-06 21:00:20.1687 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow 2017-01-06 21:00:20.1687 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:20.1843 Debug LibraryMonitor: Timer stopped. 2017-01-06 21:00:20.2000 Info LibraryMonitor: \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow reports change. 2017-01-06 21:00:20.2000 Info LibraryMonitor: \\SERVER\Emby Server - TV Recordings$\Series reports change. 2017-01-06 21:00:20.2000 Info LibraryMonitor: \\SERVER\Emby Server - TV Recordings$\Series\Emerald City reports change. 2017-01-06 21:00:20.2000 Info LibraryMonitor: \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo reports change. 2017-01-06 21:00:20.2000 Info LibraryMonitor: \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\Emerald City S01E01 The Beast Forever; Prison of the Abject.nfo reports change. 2017-01-06 21:00:20.2000 Info LibraryMonitor: \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\tvshow.nfo reports change. 2017-01-06 21:00:20.2000 Info LibraryMonitor: \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4\Sleepy Hollow S04E01 Columbia.nfo reports change. 2017-01-06 21:00:20.2000 Info LibraryMonitor: Series (\\SERVER\Emby Server - TV Recordings$\Series) will be refreshed. 2017-01-06 21:00:20.9656 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 2017-01-06 21:00:20.9656 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 2017-01-06 21:00:20.9812 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4 2017-01-06 21:00:20.9812 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow\Season 4 2017-01-06 21:00:21.0593 Debug Dlna: Search Request Received From 192.168.123.134:61192, Target = urn:dial-multiscreen-org:service:dial:1 2017-01-06 21:00:22.4832 Debug App: Running SeriesNfoProvider for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:22.4832 Debug App: Running TvdbSeriesProvider for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:22.4832 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/GetSeries.php?seriesname=Emerald+City&language=en 2017-01-06 21:00:22.8269 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/B89CE93890E9419B/series/295779/all/en.zip 2017-01-06 21:00:23.3269 Debug App: Running OmdbItemProvider for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:23.3269 Info HttpClient: HttpClientManager GET: https://www.omdbapi.com/?plot=full&r=json&t=Emerald+City&type=series 2017-01-06 21:00:23.4050 Info HttpClient: HttpClientManager GET: https://www.omdbapi.com/?i=tt2051142&tomatoes=true 2017-01-06 21:00:26.0456 Info HttpServer: HTTP GET http://192.168.123.50:8096/emby/Users/824f711b49784825b017e884dec877b2/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=e3b8acd519c173555dd756da2ae43dce%2C892f81852e90a67d8f336f398ce2c87a%2Cfc82b4680f8f1bf79efd66543362dc90%2Cb5e02a0fbaa273027bb79884bab82b6b&MediaTypes=Audio%2CVideo. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/2.5.34 Chrome/53.0.2785.143 Electron/1.4.13 Safari/537.36 2017-01-06 21:00:26.0612 Info HttpServer: HTTP Response 200 to 192.168.123.108. Time: 16ms. http://192.168.123.50:8096/emby/Users/824f711b49784825b017e884dec877b2/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=e3b8acd519c173555dd756da2ae43dce%2C892f81852e90a67d8f336f398ce2c87a%2Cfc82b4680f8f1bf79efd66543362dc90%2Cb5e02a0fbaa273027bb79884bab82b6b&MediaTypes=Audio%2CVideo 2017-01-06 21:00:35.3423 Debug App: Running MovieDbSeriesProvider for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:35.3423 Info HttpClient: HttpClientManager GET: https://api.themoviedb.org/3/tv/find/295779?api_key=f6bd687ffa63cd282b6ff2c6877f2669&external_source=tvdb_id 2017-01-06 21:00:35.5767 Debug App: Throttling Tmdb by 65 ms 2017-01-06 21:00:35.6548 Info HttpClient: HttpClientManager GET: https://api.themoviedb.org/3/tv/62417?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=credits,images,keywords,external_ids,videos,content_ratings&language=en&include_image_language=en,null 2017-01-06 21:00:35.8892 Debug App: Running TvdbSeriesImageProvider for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:35.8892 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/posters/295779-2.jpg 2017-01-06 21:00:35.9829 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\poster.jpg 2017-01-06 21:00:35.9829 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\poster.jpg 2017-01-06 21:00:35.9829 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\poster.jpg 2017-01-06 21:00:35.9829 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\poster.jpg 2017-01-06 21:00:35.9829 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\poster.jpg 2017-01-06 21:00:35.9829 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\poster.jpg 2017-01-06 21:00:35.9829 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\poster.jpg 2017-01-06 21:00:35.9986 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\poster.jpg 2017-01-06 21:00:35.9986 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\poster.jpg 2017-01-06 21:00:35.9986 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/graphical/295779-g.jpg 2017-01-06 21:00:36.0298 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\banner.jpg 2017-01-06 21:00:36.0298 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:36.0298 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:36.0298 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\banner.jpg 2017-01-06 21:00:36.0298 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\banner.jpg 2017-01-06 21:00:36.0455 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\banner.jpg 2017-01-06 21:00:36.0455 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\banner.jpg 2017-01-06 21:00:36.0455 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/295779-8.jpg 2017-01-06 21:00:36.2173 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2173 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:36.2173 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2330 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2486 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2486 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\fanart.jpg 2017-01-06 21:00:36.2486 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/295779-7.jpg 2017-01-06 21:00:36.3585 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart1.jpg 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart1.jpg 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart1.jpg 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart1.jpg 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart1.jpg 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart1.jpg 2017-01-06 21:00:36.3585 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart1.jpg 2017-01-06 21:00:36.3742 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb1.jpg 2017-01-06 21:00:36.3742 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart1.jpg 2017-01-06 21:00:36.3742 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart1.jpg 2017-01-06 21:00:36.3742 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:36.3742 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:36.3742 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs 2017-01-06 21:00:36.3742 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs 2017-01-06 21:00:36.3742 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb1.jpg 2017-01-06 21:00:36.3742 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb1.jpg 2017-01-06 21:00:36.3898 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb1.jpg 2017-01-06 21:00:36.3898 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb1.jpg 2017-01-06 21:00:36.3898 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb1.jpg 2017-01-06 21:00:36.3898 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb1.jpg 2017-01-06 21:00:36.3898 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb1.jpg 2017-01-06 21:00:36.3898 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb1.jpg 2017-01-06 21:00:36.3898 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/295779-5.jpg 2017-01-06 21:00:36.4679 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart2.jpg 2017-01-06 21:00:36.4679 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart 2017-01-06 21:00:36.4679 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart2.jpg 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart2.jpg 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart2.jpg 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart2.jpg 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart2.jpg 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart2.jpg 2017-01-06 21:00:36.4835 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb2.jpg 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart2.jpg 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart2.jpg 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb2.jpg 2017-01-06 21:00:36.4835 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb2.jpg 2017-01-06 21:00:36.4992 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb2.jpg 2017-01-06 21:00:36.4992 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb2.jpg 2017-01-06 21:00:36.4992 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb2.jpg 2017-01-06 21:00:36.4992 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb2.jpg 2017-01-06 21:00:36.4992 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb2.jpg 2017-01-06 21:00:36.4992 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb2.jpg 2017-01-06 21:00:36.4992 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/295779-2.jpg 2017-01-06 21:00:37.3128 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart3.jpg 2017-01-06 21:00:37.3128 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart 2017-01-06 21:00:37.3128 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart 2017-01-06 21:00:37.3128 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart3.jpg 2017-01-06 21:00:37.3128 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart3.jpg 2017-01-06 21:00:37.3128 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart3.jpg 2017-01-06 21:00:37.3128 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart3.jpg 2017-01-06 21:00:37.3128 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart3.jpg 2017-01-06 21:00:37.3128 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart3.jpg 2017-01-06 21:00:37.3285 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb3.jpg 2017-01-06 21:00:37.3285 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart3.jpg 2017-01-06 21:00:37.3285 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart3.jpg 2017-01-06 21:00:37.3285 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs 2017-01-06 21:00:37.3285 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs 2017-01-06 21:00:37.3441 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb3.jpg 2017-01-06 21:00:37.3441 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb3.jpg 2017-01-06 21:00:37.3441 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb3.jpg 2017-01-06 21:00:37.3441 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb3.jpg 2017-01-06 21:00:37.3441 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb3.jpg 2017-01-06 21:00:37.3441 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb3.jpg 2017-01-06 21:00:37.3597 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb3.jpg 2017-01-06 21:00:37.3597 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb3.jpg 2017-01-06 21:00:37.3597 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/fanart/original/295779-1.jpg 2017-01-06 21:00:38.1566 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart4.jpg 2017-01-06 21:00:38.1566 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart 2017-01-06 21:00:38.1566 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart 2017-01-06 21:00:38.1566 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart4.jpg 2017-01-06 21:00:38.1566 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart4.jpg 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart4.jpg 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart4.jpg 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart4.jpg 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart4.jpg 2017-01-06 21:00:38.1722 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb4.jpg 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart4.jpg 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrafanart\fanart4.jpg 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb4.jpg 2017-01-06 21:00:38.1722 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb4.jpg 2017-01-06 21:00:38.1879 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb4.jpg 2017-01-06 21:00:38.1879 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb4.jpg 2017-01-06 21:00:38.1879 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb4.jpg 2017-01-06 21:00:38.1879 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb4.jpg 2017-01-06 21:00:38.1879 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb4.jpg 2017-01-06 21:00:38.1879 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\extrathumbs\thumb4.jpg 2017-01-06 21:00:38.1879 Debug App: Running FanartSeriesProvider for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:38.1879 Info HttpClient: HttpClientManager GET: https://webservice.fanart.tv/v3/tv/295779?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2017-01-06 21:00:38.4691 Error HttpClient: Error getting response from https://webservice.fanart.tv/v3/tv/295779?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 *** Error Report *** Version: 3.1.2.0 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\System System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (520) Origin Error. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__20.MoveNext() ---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (520) Origin Error. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)<--- System.AggregateException at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__20.MoveNext() InnerException: System.Net.WebException System.Net.WebException: The remote server returned an error: (520) Origin Error. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2017-01-06 21:00:38.6960 Error ProviderManager: FanartSeriesProvider failed in GetImageInfos for type Series *** Error Report *** Version: 3.1.2.0 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\System MediaBrowser.Model.Net.HttpException: One or more errors occurred. ---> System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (520) Origin Error. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of inner exception stack trace --- at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<Get>d__14.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.TV.FanartSeriesProvider.<DownloadSeriesJson>d__31.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.TV.FanartSeriesProvider.<EnsureSeriesJson>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.TV.FanartSeriesProvider.<GetImages>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.ProviderManager.<GetImages>d__27.MoveNext() MediaBrowser.Model.Net.HttpException at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<Get>d__14.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.TV.FanartSeriesProvider.<DownloadSeriesJson>d__31.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.TV.FanartSeriesProvider.<EnsureSeriesJson>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.TV.FanartSeriesProvider.<GetImages>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.ProviderManager.<GetImages>d__27.MoveNext() InnerException: System.AggregateException System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (520) Origin Error. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__20.MoveNext() ---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (520) Origin Error. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)<--- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__20.MoveNext() InnerException: System.Net.WebException System.Net.WebException: The remote server returned an error: (520) Origin Error. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2017-01-06 21:00:38.6960 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:38.6960 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City 2017-01-06 21:00:38.7116 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/364711.jpg 2017-01-06 21:00:38.7429 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\A\Adria Arjona\poster.jpg 2017-01-06 21:00:38.7585 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\A\Adria Arjona to database. 2017-01-06 21:00:39.3679 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City to Nfo. 2017-01-06 21:00:39.3991 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:39.3991 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:39.3991 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:39.3991 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:39.3991 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/380290.jpg 2017-01-06 21:00:39.4304 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\J\Jordan Loughran\poster.jpg 2017-01-06 21:00:39.4460 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\J\Jordan Loughran to database. 2017-01-06 21:00:40.0710 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City to Nfo. 2017-01-06 21:00:40.0866 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:40.0866 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:40.0866 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:40.0866 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:40.0866 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/380266.jpg 2017-01-06 21:00:40.1335 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\O\Oliver Jackson-Cohen\poster.jpg 2017-01-06 21:00:40.1335 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\O\Oliver Jackson-Cohen to database. 2017-01-06 21:00:40.9929 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City to Nfo. 2017-01-06 21:00:41.0085 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:41.0085 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:41.0085 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:41.0085 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:41.0085 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/380265.jpg 2017-01-06 21:00:41.0553 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\G\Gerran Howell\poster.jpg 2017-01-06 21:00:41.0712 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\G\Gerran Howell to database. 2017-01-06 21:00:41.8681 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City to Nfo. 2017-01-06 21:00:41.8681 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:41.8681 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:41.8837 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:41.8837 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:41.8837 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/364713.jpg 2017-01-06 21:00:41.9150 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\V\Vincent D’Onofrio\poster.jpg 2017-01-06 21:00:41.9306 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\V\Vincent D’Onofrio to database. 2017-01-06 21:00:42.7431 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City to Nfo. 2017-01-06 21:00:42.7587 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:42.7587 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:42.7587 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:42.7587 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:42.7587 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/380269.jpg 2017-01-06 21:00:42.7915 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\A\Ana Ularu\poster.jpg 2017-01-06 21:00:42.8072 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\A\Ana Ularu to database. 2017-01-06 21:00:43.5259 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City to Nfo. 2017-01-06 21:00:43.5416 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:43.5416 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:43.5572 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:43.5572 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:43.5572 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/380268.jpg 2017-01-06 21:00:43.6040 Debug ProviderManager: Saving image to E:\Emby Server - Cache\Metadata\metadata\People\S\Stefanie Martini\poster.jpg 2017-01-06 21:00:43.6197 Debug App: Saving E:\Emby Server - Cache\Metadata\metadata\People\S\Stefanie Martini to database. 2017-01-06 21:00:44.3697 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City to Nfo. 2017-01-06 21:00:44.3853 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:44.3853 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:44.4009 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:44.4009 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:44.4009 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City to Nfo. 2017-01-06 21:00:44.4165 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:44.4165 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:44.4322 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:44.4322 Debug App: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City to database. 2017-01-06 21:00:44.4322 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\tvshow.nfo 2017-01-06 21:00:44.4322 Debug App: Running SeasonNfoProvider for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 2017-01-06 21:00:44.4322 Debug App: SeasonNfoProvider returned no metadata for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 2017-01-06 21:00:44.4322 Debug App: Running TvdbSeasonImageProvider for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 2017-01-06 21:00:44.4478 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/seasons/295779-1.jpg 2017-01-06 21:00:44.4790 Debug ProviderManager: Saving image to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\season01-poster.jpg 2017-01-06 21:00:44.4790 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\season01-poster.jpg 2017-01-06 21:00:44.4790 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\season01-poster.jpg 2017-01-06 21:00:44.4790 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\season01-poster.jpg 2017-01-06 21:00:44.4790 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\season01-poster.jpg 2017-01-06 21:00:44.4946 Debug App: Running FanArtSeasonProvider for \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 2017-01-06 21:00:44.4946 Info HttpClient: HttpClientManager GET: https://webservice.fanart.tv/v3/tv/295779?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2017-01-06 21:00:44.8228 Debug JsonSerializer: Deserializing file E:\Emby Server - Cache\Cache\cache\fanart-tv\295779\fanart.json 2017-01-06 21:00:44.8228 Debug ProviderManager: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 to Nfo. 2017-01-06 21:00:44.8228 Debug LibraryMonitor: Changed detected of type Created to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\season.nfo 2017-01-06 21:00:44.8228 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\season.nfo 2017-01-06 21:00:44.8384 Debug LibraryMonitor: Changed detected of type Changed to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\season.nfo 2017-01-06 21:00:44.8384 Debug App: Saving \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1 to database. 2017-01-06 21:00:44.8384 Debug LibraryMonitor: Ignoring change to \\SERVER\Emby Server - TV Recordings$\Series\Emerald City\Season 1\season.nfo 2017-01-06 21:00:44.8540 Debug App: Running SeriesNfoProvider for \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow 2017-01-06 21:00:44.8696 Debug App: Running TvdbSeriesProvider for \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow 2017-01-06 21:00:44.8696 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/GetSeries.php?seriesname=Sleepy+Hollow&language=en 2017-01-06 21:00:45.1509 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/B89CE93890E9419B/series/269578/all/en.zip 2017-01-06 21:00:46.3696 Debug App: Running OmdbItemProvider for \\SERVER\Emby Server - TV Recordings$\Series\Sleepy Hollow 2017-01-06 21:00:46.3696 Info HttpClient: HttpClientManager GET: https://www.omdbapi.com/?plot=full&r=json&t=Sleepy+Hollow&type=series 2017-01-06 21:00:49.1665 Debug Dlna: Search Request Received From 192.168.123.50:62957, Target = ssdp:all 2017-01-06 21:00:49.1665 Debug Dlna: Search Request Received From 192.168.123.50:62958, Target = ssdp:all 2017-01-06 21:00:49.2758 Debug Dlna: Search Request Received From 192.168.123.50:62957, Target = ssdp:all 2017-01-06 21:00:49.2758 Debug Dlna: Search Request Received From 192.168.123.50:62958, Target = ssdp:all 2017-01-06 21:00:49.3852 Debug Dlna: Search Request Received From 192.168.123.50:62957, Target = ssdp:all 2017-01-06 21:00:49.3852 Debug Dlna: Search Request Received From 192.168.123.50:62958, Target = ssdp:all 2017-01-06 21:01:02.2913 Info HttpClient: HttpClientManager GET: https://www.omdbapi.com/?i=tt2647544&tomatoes=true Erik Edited January 7, 2017 by Erik
Erik 124 Posted January 7, 2017 Author Posted January 7, 2017 Ok. Update, I can still consistently get the reset to occur even after testing and changing cables. However, I have turned off all padding and through multiple recording tests over half the day it will not fail the Hdhomerun unit. So maybe something is causing the reset from Emby?
Luke 42243 Posted January 7, 2017 Posted January 7, 2017 I really don't know, I mean all we are doing is calling their dlna api.
Erik 124 Posted January 7, 2017 Author Posted January 7, 2017 Thanks luke. I'll see if I can catch logging with it ok and when it fails and see anything. Otherwise I'll have to ask the company if they see anything (I enabled the Hdhomerun logging for them to see). I'll update if I get anything.
Erik 124 Posted March 19, 2017 Author Posted March 19, 2017 (edited) Follow up for other who may read this topic, It seems there is a bug in the Ethernet driver/programming for the HDhomerun units that only present under certain circumstances. In my case, with the unit getting a DHCP address (like all extends) and plugged into a gigabit witch (mine being a dlink 24 port gigabit switch). With that combination the HDhomerun units (and I have gone through 5 of them being RMA'd and replaced/tested by the manufacturer) I would get application watchdog resets as described above randomly. The manufacturer verified unit temperature and other items remotely and couldn't determine the issue. After finding a couple of threads on HDhomerun's support forum (especially for prime units) it seems that the combination of DHCP and certain gigabit switches causes this reset. Emby does not handle this well when the unit resets and you get stuck active recordings. So...I purchased a 100mb 6 port switch and plugged the 2x HDhomerun extend units into it (with heavy transcode each stream takes a max of 10mb so I'm nowhere near the connection limit that connects to the gigabit main switch). I have been running like this for almost a month now without any HDhomerun unit resets and flawless recording through Emby. I'll leave this setup until some firmware update fixes the issue, but hopefully this will help someone else in the meantime if they also have a similar problem. Erik Edited March 19, 2017 by Erik
Erik 124 Posted April 7, 2017 Author Posted April 7, 2017 SiliconDust has the BETA out today. I just installed it and will post back after testing for a couple days. Here is the link if others want to give it a go. https://forum.silicondust.com/forum/viewtopic.php?f=119&t=20613
lifespeed 42 Posted April 14, 2017 Posted April 14, 2017 SiliconDust has the BETA out today. I just installed it and will post back after testing for a couple days. Here is the link if others want to give it a go. https://forum.silicondust.com/forum/viewtopic.php?f=119&t=20613 Interesting. Did you experience the DHCP bug with current firmware? It would cause the tuner to not be reachable over the network.
Erik 124 Posted April 15, 2017 Author Posted April 15, 2017 @@lifespeed I did not have it unreachable, the unit would reset constantly and a fault (with no way of knowing what he fault was) I sent silicondust the love logging and said all my parameters where ok. I have tested all the units fairly hard since installing he beta and have had no issue with the HDhomerun unit at all. Emby is having problems for me anything past .9 stable reslease so I downgraded to that and have had 95% recording success.
