maegibbons 1287 Posted January 6, 2017 Posted January 6, 2017 Hi @ebr Can you have a look at this post https://emby.media/community/index.php?/topic/42324-music-channels-in-hdhomerun-cause-errors/&do=findComment&comment=404961 and see if we can get "freeview" radio channels from HDHomerun playing on Amazon/Fire TV! Luke has got it to work on other platforms now. My wife will be very grateful! Many thanks Krs Mark
ebr 16337 Posted January 6, 2017 Posted January 6, 2017 Can you please follow the instructions under Android TV here to send me a log from the app?
maegibbons 1287 Posted January 6, 2017 Author Posted January 6, 2017 Hi @ebr I have done that - log sent around 20:28 - Tests started at approx 20:26 GMT - user was emby. I pressed magic "!" a few times until "too many errors" - no joy. Server log for time period attached herewith Many thanks for looking. KR's Mark server-radio-ftv.txt
CBers 7554 Posted January 6, 2017 Posted January 6, 2017 I didn't realise that the Freeview radio channels didn't work, but I've just confirmed it here. Just get a spinning circle. Also just submitted logs from with the app, user = Master. Just tried in the HDHomeRun app and it plays straight away. 1
ebr 16337 Posted January 7, 2017 Posted January 7, 2017 Okay, thanks. The app is getting tripped up by the lack of a video stream. I'll have to look at it.
ebr 16337 Posted January 7, 2017 Posted January 7, 2017 Since I don't have any channels like this, it may take some trial and error to get this fully solved but a new beta (.16) is heading up as the first attempt. CBers, you will probably have easiest access to it with one of your Google boxes so let me know if you get a chance to try it. Thanks.
Latchmor 584 Posted January 7, 2017 Posted January 7, 2017 Since I don't have any channels like this, it may take some trial and error to get this fully solved but a new beta (.16) is heading up as the first attempt. CBers, you will probably have easiest access to it with one of your Google boxes so let me know if you get a chance to try it. Thanks. I'm giving it a whirl just now. Spinning circle so far... (I have got .16) Cheers
Latchmor 584 Posted January 7, 2017 Posted January 7, 2017 Actually, they are not working in web client either. I'll go and get a clean log...
Latchmor 584 Posted January 7, 2017 Posted January 7, 2017 Mmm, restarted to get clean log and it actually played for about 5 seconds then stopped (still web client)
CBers 7554 Posted January 7, 2017 Posted January 7, 2017 Getting transcoded/VLC playback. Sent you internal app logs, user = Master.
CBers 7554 Posted January 7, 2017 Posted January 7, 2017 Transcoding log. http://192.168.1.140:8096/emby/videos/2c58b38d6a7e1ed42ff31174ea34d77b/stream.ts?DeviceId=c52890e176bbb811&MediaSourceId=ac1b4dab702744b4be1c3a1dc14eb52d_native_3139284676dcd4ae7d3fbe8bac8fa14e&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=0&VideoBitrate=109522286&AudioBitrate=192000&MaxAudioChannels=8&MaxFramerate=60&Level=51&Profile=high&PlaySessionId=eef222b8007c4ff19ab0d10f111129c3&api_key=47a32199a7ec42f1be0ba27593d4b439&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_ac1b4dab702744b4be1c3a1dc14eb52d_native_3139284676dcd4ae7d3fbe8bac8fa14e&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&RequireAvc=false {"Protocol":"Http","Id":"ac1b4dab702744b4be1c3a1dc14eb52d_native_3139284676dcd4ae7d3fbe8bac8fa14e","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/708dc2a0d70e449bb88e4d9e370589a9/stream.ts","Type":"Default","Container":"mpegts","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"SupportsProbing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_ac1b4dab702744b4be1c3a1dc14eb52d_native_3139284676dcd4ae7d3fbe8bac8fa14e","BufferMs":0,"MediaStreams":[{"Codec":"mp2","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Eng MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":192000,"RequiredHttpHeaders":{},"DefaultAudioStreamIndex":0} C:\Users\Media\AppData\Roaming\MediaBrowser-Server\ffmpeg\20160410\ffmpeg.exe -fflags +genpts -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/708dc2a0d70e449bb88e4d9e370589a9/stream.ts" -vn -map 0:0 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -pix_fmt yuv420p -preset medium -crf 23 -maxrate 109522286 -bufsize 219044572 -vsync -1 -profile:v high -level 4.1 -x264opts:0 subme=0:rc_lookahead=10:me_range=4:me=dia:no_chroma_me:8x8dct=0:partitions=none -flags -global_header -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -af "aresample=async=1" -y "C:\Users\Media\AppData\Roaming\MediaBrowser-Server\transcoding-temp\6283cb68115a10cd9b377f015f15e162.ts" ffmpeg version N-79277-g0c90b2e Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [mpegts @ 00000000004ba5c0] Could not find codec parameters for stream 1 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000004ba5c0] Could not find codec parameters for stream 2 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000004ba5c0] Could not find codec parameters for stream 3 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000004ba5c0] Could not find codec parameters for stream 4 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/708dc2a0d70e449bb88e4d9e370589a9/stream.ts': Duration: N/A, start: 63691.255911, bitrate: 192 kb/s Program 6784 Stream #0:0[0x44e](eng): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s Stream #0:1[0x1c2a]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:2[0x1c21]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:3[0x1c24]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:4[0x1ce9]: Unknown: none ([11][0][0][0] / 0x000B) Codec AVOption preset (Configuration preset) specified for output file #0 (C:\Users\Media\AppData\Roaming\MediaBrowser-Server\transcoding-temp\6283cb68115a10cd9b377f015f15e162.ts) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some encoder which was not actually used for any stream. Codec AVOption crf (Select the quality for constant quality mode) specified for output file #0 (C:\Users\Media\AppData\Roaming\MediaBrowser-Server\transcoding-temp\6283cb68115a10cd9b377f015f15e162.ts) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some encoder which was not actually used for any stream. Codec AVOption x264opts (x264 options) specified for output file #0 (C:\Users\Media\AppData\Roaming\MediaBrowser-Server\transcoding-temp\6283cb68115a10cd9b377f015f15e162.ts) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some encoder which was not actually used for any stream. Codec AVOption profile () specified for output file #0 (C:\Users\Media\AppData\Roaming\MediaBrowser-Server\transcoding-temp\6283cb68115a10cd9b377f015f15e162.ts) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some encoder which was not actually used for any stream. Output #0, mpegts, to 'C:\Users\Media\AppData\Roaming\MediaBrowser-Server\transcoding-temp\6283cb68115a10cd9b377f015f15e162.ts': Metadata: encoder : Lavf57.32.100 Stream #0:0: Audio: aac (LC), 48000 Hz, stereo, fltp, 192 kb/s Metadata: encoder : Lavc57.34.100 aac Stream mapping: Stream #0:0 -> #0:0 (mp2 (native) -> aac (native)) Press [q] to stop, [?] for help size= 81kB time=00:00:03.11 bitrate= 213.4kbits/s speed=6.22x size= 216kB time=00:00:08.14 bitrate= 217.6kbits/s speed= 7.5x size= 234kB time=00:00:08.74 bitrate= 219.4kbits/s speed=5.31x size= 249kB time=00:00:09.25 bitrate= 220.3kbits/s speed=4.31x size= 263kB time=00:00:09.77 bitrate= 220.6kbits/s speed=3.69x 1
ebr 16337 Posted January 7, 2017 Posted January 7, 2017 Getting transcoded/VLC playback. Sent you internal app logs, user = Master. So it is working...?
maegibbons 1287 Posted January 7, 2017 Author Posted January 7, 2017 Mmm, restarted to get clean log and it actually played for about 5 seconds then stopped (still web client) Hmm, with the work Luke did earlier in the week I do not (or more precisecl "did" not) have a problem with web client. Cannot test at moment as both Tuners are in use by the family!! Will double check later. Thanks for testing Krs Mark
maegibbons 1287 Posted January 7, 2017 Author Posted January 7, 2017 (edited) So it is working...? You beat me to ask the same question by a minute!! I cannot check at the moment as both Tuners are in use and I would be killed if i interrupt Saturday night viewing. I will do my own tests Later. Thanks for working on this it is really appreciated. Krs Mark Edited January 7, 2017 by maegibbons
maegibbons 1287 Posted January 7, 2017 Author Posted January 7, 2017 I have caused WAR but Ive just kicked everybody off the system and tested on Fire TV and it works. Thank You. I am just going to check my other clients now. Krs Mark
maegibbons 1287 Posted January 7, 2017 Author Posted January 7, 2017 Ok Fire TV - Looking good Qbox - Looking good MIBOX - Not sure initial test failed - unable to test further at the moment - will do later when there is a cease fire. Jane, the wife, says thank you very much for getting it working. She uses the Qbox currently so shes very happy. I will do more exhaustive testing tomorrow. THANKS! kRs Mark 1
maegibbons 1287 Posted January 8, 2017 Author Posted January 8, 2017 Ok The MIBOX works too! So looks like 100% success here! Seeing a few channels coming up as mono which is strange. However let me investigate that. In the meantime, consider this issue resolved. Many thanks once again Krs Mark 1
