tbkn 3 Posted January 6, 2017 Posted January 6, 2017 There used to be a tab in Libraries to setup path substitution, but now it's nowhere to be seen. Where did it go to? I can't find it anywhere and can't use external players without it. Previous: Now:
Solution mastrmind11 722 Posted January 6, 2017 Solution Posted January 6, 2017 They moved to per-library since 3.1. Click on a library, click on the path, and in there will be an optional network path. 1
tbkn 3 Posted January 6, 2017 Author Posted January 6, 2017 Thanks! Worth updating this wiki: https://github.com/MediaBrowser/Wiki/wiki/Path-Substitution 2
Luke 42213 Posted January 6, 2017 Posted January 6, 2017 @@tbkn yes you are right, thanks for the report. 1
djhifi 56 Posted January 17, 2017 Posted January 17, 2017 And btw, if we previously had set up path substitution, we will need to do it again, per library, right? I ask this because all my path subs. are blanked out and Im having errors on some HDDs when I try to play files from them, saying "not acessible". Not all tough...which is wierd!
Happy2Play 9802 Posted January 17, 2017 Posted January 17, 2017 And btw, if we previously had set up path substitution, we will need to do it again, per library, right? I ask this because all my path subs. are blanked out and Im having errors on some HDDs when I try to play files from them, saying "not acessible". Not all tough...which is wierd! Everything still should be backwards compatible, but if you are having issues you will have to manually remove the old way to add the new way. Shut down server open system.xml (C:\Users\username\AppData\Roaming\Emby-Server\config) find <PathSubstitution> section and delete the everything between the nodes <PathSubstitution> </PathSubstitution> Save start server go to each library and add the network path.
horizonbrave 1 Posted September 25, 2018 Posted September 25, 2018 I'm reading the same wiki and I'm also confused.. can't find that setting anywhere. Wiki says to use the Metadata Manager that to confirm everything is allright.. mine seems fine (I can see movie's data). Cheers
Happy2Play 9802 Posted September 25, 2018 Posted September 25, 2018 (edited) I'm reading the same wiki and I'm also confused.. can't find that setting anywhere. Wiki says to use the Metadata Manager that to confirm everything is allright.. mine seems fine (I can see movie's data). Cheers Well when you create the library and add your folder you can see the "(Optional) Shared network folder:" option, but you can click on your Folders and bring up the option again (not very intuitive). Edited September 25, 2018 by Happy2Play 1
horizonbrave 1 Posted September 25, 2018 Posted September 25, 2018 [...] but you can click on your Folders and bring up the option again (not very intuitive). Well I could have tried harder By the way I'm actually not understanding if I need to specify that path or not (sorry).. files and server are on a Synology NAS unit. Folder has been added and everything seems to work fine, please do I still need it and where I find it (the path itself)? Cheers!
ebr 16310 Posted September 25, 2018 Posted September 25, 2018 Well I could have tried harder By the way I'm actually not understanding if I need to specify that path or not (sorry).. files and server are on a Synology NAS unit. Folder has been added and everything seems to work fine, please do I still need it and where I find it (the path itself)? Cheers! You only need this if you use apps that can truly directly access the file system. This would be limited to Emby Theater Desktop for Windows, Emby for WMC and Kodi I believe. 1
horizonbrave 1 Posted September 26, 2018 Posted September 26, 2018 You only need this if you use apps that can truly directly access the file system. This would be limited to Emby Theater Desktop for Windows, Emby for WMC and Kodi I believe. Thanks, I had no idea! Maybe I ddin't read the wiki carefully...
Luke 42213 Posted September 26, 2018 Posted September 26, 2018 And even then you don't really need it. It's just that some people like it.
horizonbrave 1 Posted September 26, 2018 Posted September 26, 2018 I guess the wiki made me believe it could provide some performance improvements
