chef 3811 Posted February 3, 2014 Posted February 3, 2014 Hello, just to recap: You had k-lite installed. You had 64bit OS Now you have 32bit OS installed. What codecs are you currently using? Is it LAV? I had recently put a new AMD GUI in my PC. I was having major problems with bad video playback due to CCC. I realize you can not get any playback of MKV files. If you haven't done so yet, try and install the media browser theatre. This will install a version if LAV automatically that will work. If problems playing MKV persist (like no playback at all) then the issue is somewhere other than codecs. But, if the MKV files play, but are shakey and unwatchable, then there could be a resolution issue with your graphic drivers. Like I say, I had major issues with CCC, and had to edit the registry to get a full 1920x1080 resolution at 60hz. I would like to help you get things working, if I can.
