sh0rty 727 Posted January 6, 2017 Posted January 6, 2017 When I change the network path of library folders (e.g. \\MEDIACENTER\Movies to \\EMBY\MOVIES), do I just need to do a library scan or do I need to manually refresh all libraries in metadata manager to get the new network paths inside the nfo?
Luke 42197 Posted January 6, 2017 Posted January 6, 2017 in general you don't need to do anything, unless you've enabled saving image paths to nfos, and have enabled path substitution with nfos, then in that case, you'll need to refresh titles. we can probably look to handle it automatically in the future. 1
sh0rty 727 Posted January 6, 2017 Author Posted January 6, 2017 in general you don't need to do anything, unless you've enabled saving image paths to nfos, and have enabled path substitution with nfos, then in that case, you'll need to refresh titles. we can probably look to handle it automatically in the future. Just wanted to be sure that my installation is not broken. Thanks. Then I will refresh the titles.
