haernell 0 Posted January 5, 2017 Posted January 5, 2017 I have an issue with my Emby Server 3.1.2.0 running on Openmediavault 2 using Docker. I tried to add my music to it, but for some reason it merges many albums from an interpret to only one album. But when I only add the folder containing that band, the albumscrapping works.
Luke 42244 Posted January 5, 2017 Posted January 5, 2017 Hi there @@haernell, can you please discuss some specific examples? Can you also show us what the folder structure looks like? Screenshots would be very helpful. thanks !
haernell 0 Posted January 6, 2017 Author Posted January 6, 2017 My Folderstructure is Music Artist Album File.mp3 As you can see, this are all albums scrapped by Emby. But I have much more music from Linkin Park than this. So let's see where its gone: That album definetly doesn't have 1773 tracks, so all the missing albums get scrapped in there.
Luke 42244 Posted January 6, 2017 Posted January 6, 2017 Hi, are the tracks tagged with embedded metadata?
haernell 0 Posted January 6, 2017 Author Posted January 6, 2017 Yes the tracks have been tagged with Itunes. Selecting only the Linkin Park folders shows the album in the right order.
Luke 42244 Posted January 7, 2017 Posted January 7, 2017 can you show screenshots of the folder contents at various levels? thanks !
haernell 0 Posted January 8, 2017 Author Posted January 8, 2017 (edited) http://imgur.com/a/bvwpq This is only the View over smb from my Windows PC, as I don't have X Server on the NAS. The folder is mounted as /Musik to the docker image. Edited January 8, 2017 by haernell
Luke 42244 Posted January 12, 2017 Posted January 12, 2017 @@haernell, is it possible for you to zip up that munich album and put it somewhere i can download such as dropbox? I need to try and reproduce this in a debug environment. thanks !
haernell 0 Posted January 12, 2017 Author Posted January 12, 2017 I found the error. I had a folder called "linkinpark.2015-08-23.rocknheim.at853.mp3" only containing a .txt and .md5 file inside the Linkin Park folder. After deleting it the scrapping worked like a charm. Sorry for the inconvenience.
Luke 42244 Posted January 13, 2017 Posted January 13, 2017 @@haernell thanks for the info. can you elaborate a little more? I would like to understand what was happening. thanks !
haernell 0 Posted January 14, 2017 Author Posted January 14, 2017 http://www.file-upload.net/download-12242880/emby_error_folder.7z.html The folder in this archive was a subfolder of the Linkin Park folder. So it was at the album "layer". I think Emby got confused by it's ending and tried to read in mp3 tags, but failed obviously because it was a folder and not a file. Maybe adding a check for a folder will fix this error.
Luke 42244 Posted January 15, 2017 Posted January 15, 2017 @@haernell can you attach the zip to this forum post? or just show screenshots? i don't trust the site where you uploaded it to. thanks.
Luke 42244 Posted January 15, 2017 Posted January 15, 2017 @@haernell, thanks. I see the issue and it's resolved for the next release of Emby Server.
