millsii 8 Posted March 25, 2017 Author Posted March 25, 2017 Wow, thanks @@pir8radio that info is great! Might give it a whirl over this weekend. Cheers mate!
millsii 8 Posted March 28, 2017 Author Posted March 28, 2017 Just a followup. I setup Cloudflare and seems to have done the trick! With normal CPU transcoding, my mate in Korea can now stream live TV at 3mbps without issue. Not sure if he tried higher bit rates as only using a 32" tv. Previously wasn't possible even on the lowest setting. Only way to cope with the high latency was with NVENC transcoding which seem to serve larger video segments of ~10secs. Thanks for the info and help! 2
