TV Guide (EPG) without tv tuner / tv server
Go to solution Solved by maegibbons,
Is there a way to use the tv guide (EPG) view in Emby without tvtuner hardware and tv server software.?
Only load the content from an xmltv file and viewable in Emby?
  • Solution
maegibbons
Just add a m3u "dummy" tuner with a file with all the channels you want to look at and link to xmltv source.
Cannot really see the point as you wont be able to watch!!
Krs
Mark
Edited by maegibbons
  • Like 1
Krs
Mark
Thx, I will try this.
Just to confirm that this works: Just add a m3u "dummy" tuner with a file with all the channels you want to look at and link to xmltv source. ;)
