Z0m8ie 26 Posted January 4, 2017 Posted January 4, 2017 Hi guys, I noticed a few of my movie's metadata is in another language other than English. I'm sure theres a setting somewhere to only download English metadata but I can't seem to find it. Help much appreciated.
Happy2Play 9801 Posted January 4, 2017 Posted January 4, 2017 Is this metadata from Emby or another program? I have seen this issue before with MCM and Emby.
Z0m8ie 26 Posted January 4, 2017 Author Posted January 4, 2017 (edited) Is this metadata from Emby or another program? I have seen this issue before with MCM and Emby. Hi Again Happy, I was using MCM to fetch all my metadata for a long time but a couple of weeks ago I decided to delete all my metadata apart from the images/backgrounds/posters etc. I then let Emby fetch the metadata. I'm not sure if I did it correctly as I only deleted the metadata that was contained in each movie/series folder. Are there other places I should have deleted to make sure the metadata is being pulled by Emby and not cache files which was the old MCM metadata? Edited January 4, 2017 by Z0m8ie
the-dumb1 135 Posted January 4, 2017 Posted January 4, 2017 I've seen Emby "read" metadata from the video file itself in instances where it cannot find metadata from an online source. As far as I know, there isn't any way to tell Emby to not do that.
Luke 42186 Posted January 4, 2017 Posted January 4, 2017 With something like this it is always best to discuss detailed examples.
