Kiroha 1 Posted January 3, 2017 Posted January 3, 2017 (edited) Hello, Is there a way to have advanced option for chose the Hardware decoder that the app use ? For 2017 I decided to use only Emby and uninstall SPMC on my Beelink GT1. But i'm experiencing some lag/freez during playing x264 or HEVC film. In SPMC i'm able to disable some hardware decoder and chose the right. My Beelink is on a Gigabit lan connection and no transcode are operating by my Synology Thanks a lot for answer Edited January 3, 2017 by Kiroha
ebr 16337 Posted January 4, 2017 Posted January 4, 2017 No, there is no configuration of this at this time. We are using two different playback engines and each of them are using a combination of software and hardware decoding as they are designed.
Kiroha 1 Posted January 5, 2017 Author Posted January 5, 2017 Is there a plan to integrate this option ? I'm actually use SPMC as external player for more smooth play. I'm not be able to view movies with only Emby app there are lots of lag/freez Thanks
Luke 42244 Posted January 5, 2017 Posted January 5, 2017 Is there a plan to integrate this option ? I'm actually use SPMC as external player for more smooth play. I'm not be able to view movies with only Emby app there are lots of lag/freez Thanks Hi there @@Kiroha, we're sorry to hear about this. In order for us to best help you, please provide the information requested in how to report a media playback issue. thanks !
Kiroha 1 Posted January 5, 2017 Author Posted January 5, 2017 Hi there @@Kiroha, we're sorry to hear about this. In order for us to best help you, please provide the information requested in how to report a media playback issue. thanks ! I'm doing better this Week end I will put here a video to explain clearly the lag/freez and of course send a log
