chef 3811 Posted June 18, 2017 Posted June 18, 2017 Thanks Chef this fixed the issue. I did have some problems with ET display only a back screen after adding the mios .dll but I don't think it was not related and coincidental (had to uninstall re-install ET2.7.9) I'm going to release another version with some really intense logging added. I'm still not entirely sure why the plugin configuration XML became corrupted. 1
PrincessClevage 175 Posted December 9, 2017 Posted December 9, 2017 I'm going to release another version with some really intense logging added. I'm still not entirely sure why the plugin configuration XML became corrupted. Hi Chef,I can only assume that .net core has now made it to public mainstream for emby server and your Vera plugin is no longer available in the catalog. Will you be porting this to be available in the catalog?
GTerplan 0 Posted June 22, 2019 Posted June 22, 2019 I installed this plugin, but the only device it will not create a profile for is the amazon fire tv cube. All the other fire tv's are able to be added. Is there any reason for this?
