PrincessClevage 175 Posted April 14, 2017 Posted April 14, 2017 I'm not seeing any problems here. What does your plugin configuration look like? "plugins\configuration\MiOsZWaveController.xml" I have blocked out i.p but it is correct for the vera unit C:\Users\username\AppData\Roaming\Emby-Server\plugins\configurations <?xml version="1.0"?> -<PluginConfiguration xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"xmlns:xsd="http://www.w3.org/2001/XMLSchema"> -<DeviceConfiguration> <Name>Windows 14.14393 - Emby Theater</Name> <Id>7ddfea0f9395f10c339540665d50697726039ec8</Id> </DeviceConfiguration> -<SavedDeviceProfiles> -<SavedDevice> <Name>Windows 14.14393 - Emby Theater</Name> <Id>7ddfea0f9395f10c339540665d50697726039ec8</Id> <MoviesPlaybackStarted>Dim Light Start Movie</MoviesPlaybackStarted> <MoviesPlaybackStopped>Lights Normal Movie stops</MoviesPlaybackStopped> <MoviesPlaybackPaused>Lights Normal Movie stops</MoviesPlaybackPaused> <MoviesPlaybackUnPaused>Dim Light Start Movie</MoviesPlaybackUnPaused> <SeriesPlaybackStarted/> <SeriesPlaybackStopped/> <SeriesPlaybackPaused/> <SeriesPlaybackUnPaused/> <MusicPlaybackStarted/> <MusicPlaybackStopped/> <MusicPlaybackPaused/> <MusicPlaybackUnPaused/> <SessionStarted/> <SessionEnded/> <SceneSchedule/> </SavedDevice> </SavedDeviceProfiles> -<EmbyReadyNetworkDevices> -<Device> <Name>Windows 14.14393 - Emby Theater</Name> <Id>7ddfea0f9395f10c339540665d50697726039ec8</Id> </Device> -<Device> <Name>Internet Explorer 11.0 - Emby Mobile</Name> <Id>2483074a3f7fc220eb2801b66358ab2bfc425b99</Id> </Device> -<Device> <Name>Internet Explorer 11.0 - Emby Mobile</Name> <Id>d3995064857112eaa64cf26bbd84210e93e63f3c</Id> </Device> -<Device> <Name> - Emby Theater</Name> <Id>ACE</Id> </Device> </EmbyReadyNetworkDevices> <InternalIp>xxxx</InternalIp> <SerialNumber>45200405</SerialNumber> <IsActive>false</IsActive> <Model>Sercomm NA301</Model> -<Scenes> <string>Dim Light Start Movie</string> <string>Lights Normal Movie stops</string> <string>Motion Light on Hall Night Home</string> <string>Motion None Lights off</string> <string>Pause Movie</string> <string>WakeAce</string> <string>WakeNas</string> <string>finished work</string> </Scenes> </PluginConfiguration>
PrincessClevage 175 Posted April 14, 2017 Posted April 14, 2017 (edited) If you remove and re add your mios app profile does it work? I have also tried uninstalling and re installing the app Edited April 14, 2017 by PrincessClevage
PrincessClevage 175 Posted April 15, 2017 Posted April 15, 2017 I'm not seeing any problems here. What does your plugin configuration look like? "plugins\configuration\MiOsZWaveController.xml" I have observed that from within the Mios app you can click on your detected Vera controller And it tries the following url Localhost:8096/web/configurationpage?name=VeraDashboardPage But returns the following: Exception of type "mediabrowser.common.extentions.resourcenotfoundexception" was thrown Should this display Vera dashboard?
chef 3811 Posted April 15, 2017 Posted April 15, 2017 (edited) I have observed that from within the Mios app you can click on your detected Vera controller And it tries the following url Localhost:8096/web/configurationpage?name=VeraDashboardPage But returns the following: Exception of type "mediabrowser.common.extentions.resourcenotfoundexception" was thrown Should this display Vera dashboard? At one point it did show the dashboard, but it didn't seem relivant to open the other dash, so it was removed. I'll make sure that link gets fix. But your vera device is getting detected? The config looks fine. So you are saying that the scenes aren't triggered during playback event? Edited April 15, 2017 by chef
PrincessClevage 175 Posted April 15, 2017 Posted April 15, 2017 At one point it did show the dashboard, but it didn't seem relivant to open the other dash, so it was removed. I'll make sure that link gets fix. But your vera device is getting detected? The config looks fine. So you are saying that the scenes aren't triggered during playback event? correct, nothing happens. I can manually trigger the scenes and they work as expected
chef 3811 Posted April 15, 2017 Posted April 15, 2017 correct, nothing happens. I can manually trigger the scenes and they work as expected Sorry just a another question. Is it the theater app which usually triggers scenes which is not now?
PrincessClevage 175 Posted April 15, 2017 Posted April 15, 2017 (edited) Sorry just a another question. Is it the theater app which usually triggers scenes which is not now? correct, but I have also tried the web browser and same issue. Correction, I just tested the browser and it triggered the scene correctly(I forgot to add edge browser action in mios app)I have now installed the latest version and edge browser triggers scenes correctly but ET for windows desktop does not trigger scenes I had version 1.0.6239.36421 installed and now Testing 1.0.6229.13542 Edited April 15, 2017 by PrincessClevage
chef 3811 Posted April 15, 2017 Posted April 15, 2017 Okay, I think I know the issue. I'm gonna put together a fix and release it shortly. We'll have to test it first and see if the fix works. One moment... 1
chef 3811 Posted April 15, 2017 Posted April 15, 2017 Do you notice how emby theater is now called "Chrome-Emby Theater" in the device list? I think the device name has changed? Let me know if you are seeing the same thing as me?
chef 3811 Posted April 15, 2017 Posted April 15, 2017 Alright, Here is a newer version. I apologize, but I think you'll have to delete the configuration XML and start from scratch. Then it will work. https://www.dropbox.com/s/s8tmynea2qk9b4n/MiOSEmbyZWaveControllerCS.zip?dl=0 If it fixes things for you I'll put in the catalog.
PrincessClevage 175 Posted April 15, 2017 Posted April 15, 2017 Alright, Here is a newer version. I apologize, but I think you'll have to delete the configuration XML and start from scratch. Then it will work. https://www.dropbox.com/s/s8tmynea2qk9b4n/MiOSEmbyZWaveControllerCS.zip?dl=0 If it fixes things for you I'll put in the catalog. Thanks Chef, that did the trick! 1
PrincessClevage 175 Posted May 8, 2017 Posted May 8, 2017 I'll check it out @@PrincessClevage All my scenes have been set to the Xbox theater so I haven't used them lately... Ahhrrmmmm.... Hi ChefWith the latest version of ET I am getting lights on 10mins into the movie, are you having similar experience ?
PrincessClevage 175 Posted May 14, 2017 Posted May 14, 2017 Hi Chef With the latest version of ET I am getting lights on 10mins into the movie, are you having similar experience ? I have re-installed the app and seems to of fixed the light on 10mims into movie but now I can not get the Un-pause action to trigger. I have tried several versions and different scenes:-/
PrincessClevage 175 Posted May 21, 2017 Posted May 21, 2017 This is working correctly again with the latest stable server and ET versions
chef 3811 Posted May 22, 2017 Posted May 22, 2017 This is working correctly again with the latest stable server and ET versions @PrincessCleavage Yeah, the pause/unpause events maybe unstable if the media is being transcoded. Because, transcoding splits the item into blocks, when a block finishes and and a new one starts... Technically playback stopped and started, so the lights may... Not always... flash. I need to do some work on the plugin because it needs to: 1. Exit gracefully if no vera device is found on a network. Right now it crashes the entire emby server {cringe}... 2. Do a separate checkin while transcoding to see if the media item did indeed stop playing or is indeed paused. I plan on working it out this week. 1
PrincessClevage 175 Posted June 17, 2017 Posted June 17, 2017 Hi Chef, Latest stable version of emby server 3.2.20 mios app no longer triggers scenes. I have tried ET client mios profile and IOS mios client profile. I have also tested that I can manually trigger the scene successfully
chef 3811 Posted June 17, 2017 Posted June 17, 2017 Hi Chef, Latest stable version of emby server 3.2.20 mios app no longer triggers scenes. I have tried ET client mios profile and IOS mios client profile. I have also tested that I can manually trigger the scene successfully Okay, if you remove the configuration xml and restart the server, adding devices back into the config, does it work? Don't delete the xml just move it from the configuration folder. Please let me know how it goes.
PrincessClevage 175 Posted June 17, 2017 Posted June 17, 2017 (edited) Okay, if you remove the configuration xml and restart the server, adding devices back into the config, does it work? Don't delete the xml just move it from the configuration folder. Please let me know how it goes. I did observe that saved configuration were no longer available in the mios plugin and I had to manually recreate them (main one for ET desktop and a test one for IOS) both don't work. I did also restart emby server, restarted Vera and restarted routers and manually tested the scene. All scene are showing correctly in the mios plugin (I added 2new scenes and they show up). Edited June 17, 2017 by PrincessClevage
chef 3811 Posted June 17, 2017 Posted June 17, 2017 (edited) I did observe that saved configuration were no longer available in the mios plugin and I had to manually recreate them (main one for ET desktop and a test one for IOS) both don't work. I did also restart emby server, restarted Vera and restarted routers and manually tested the scene. All scene are showing correctly in the mios plugin (I added 2new scenes and they show up). But they won't run? Okay, I'm on it! I already think I know where the issue is. There was a DAta Transfer Object name change in the API which might be a problem. Edited June 17, 2017 by chef
PrincessClevage 175 Posted June 17, 2017 Posted June 17, 2017 But they won't run? Okay, I'm on it! I already think I know where the issue is. There was a DAta Transfer Object name change in the API which might be a problem.As this is re-occurring is it possible that emby server is being deployed for various test environments, one of which has this different object name ?
chef 3811 Posted June 18, 2017 Posted June 18, 2017 As this is re-occurring is it possible that emby server is being deployed for various test environments, one of which has this different object name ? Well it wasn't what I thought it was. Now I'm confused. I have been trying to recreate the issue. I have some new versions ready. If you have time to try it out.
PrincessClevage 175 Posted June 18, 2017 Posted June 18, 2017 Well it wasn't what I thought it was. Now I'm confused. I have been trying to recreate the issue. I have some new versions ready. If you have time to try it out. Sure, are they available via emby plugins or do you have a link to dl?
chef 3811 Posted June 18, 2017 Posted June 18, 2017 Here is one to try. Sorry but you may have to recreate the configuration again. https://www.dropbox.com/s/x97lacsihcks0oy/MiOSEmbyZWaveControllerCS.zip?dl=0
PrincessClevage 175 Posted June 18, 2017 Posted June 18, 2017 (edited) Here is one to try. Sorry but you may have to recreate the configuration again. https://www.dropbox.com/s/x97lacsihcks0oy/MiOSEmbyZWaveControllerCS.zip?dl=0 Thanks Chef this fixed the issue. I did have some problems with ET display only a back screen after adding the mios .dll but I don't think it was not related and coincidental (had to uninstall re-install ET2.7.9) Edited June 18, 2017 by PrincessClevage
