tp546 41 Posted January 19, 2017 Author Posted January 19, 2017 Yes. Can you press this link and see if your Vera device is responding with proper information: https://vera-us-oem-authd.mios.com/locator/locator/locator When I click that link, I just get a page with this: {} 1
chef 3811 Posted January 19, 2017 Posted January 19, 2017 (edited) AH HA! There is the issue right there! alright it isn't the plugin code! It's the Vera. That link should have done a reverse lookup on your Vera device and showed all the information about it! What version of the Vera UI are you using? is it UI7? Edited January 19, 2017 by chef
tp546 41 Posted January 19, 2017 Author Posted January 19, 2017 There is the issue right there! alright it isn't the plugin code! It's the Vera. That link sdhould have done a reverse lookup on your Vera device and showed all the information about it! What version of the Vera UI are you using? is it UI7? No it's UI5
chef 3811 Posted January 19, 2017 Posted January 19, 2017 No it's UI5 "Well holy shit-balls!" I thought I was going crazy! this plugin hasn't worked with UI5 for several months. Now we know what is happening, we can do one of two things: 1. You update to UI7 (because it is actually pretty sweet, and the plugin works only with UI7) this is easiest. 2. I build a version of the plugin that handles UI5. This isn't terribly hard to do, but you gonna have to help me because all the base class architecture is different from UI7, and I need to see all the JSON info that you get from certain links I send you. What you wanna do? I'm down for either of them really...
tp546 41 Posted January 19, 2017 Author Posted January 19, 2017 "Well holy shit-balls!" I thought I was going crazy! this plugin hasn't worked with UI5 for several months. Now we know what is happening, we can do one of two things: 1. You update to UI7 (because it is actually pretty sweet, and the plugin works only with UI7) this is easiest. 2. I build a version of the plugin that handles UI5. This isn't terribly hard to do, but you gonna have to help me because all the base class architecture is different from UI7, and I need to see all the JSON info that you get from certain links I send you. What you wanna do? I'm down for either of them really... Haha yeah, it hasn't worked for me at all but the other plugin used to work. I'd have to look into the process for upgrading to UI7 and what risks I am running in terms of compatibility and any potential problems I may run into. UI5 doesn't run that smoothly so maybe it's worth doing. 1
chef 3811 Posted January 19, 2017 Posted January 19, 2017 Press this link and tell me what happens: https://sta1.mios.com/locator_json.php
tp546 41 Posted January 19, 2017 Author Posted January 19, 2017 Press this link and tell me what happens: https://sta1.mios.com/locator_json.php now I get all my unit info populated
tp546 41 Posted January 19, 2017 Author Posted January 19, 2017 actually, if you don't mind making it compatible with UI5, that would be great and I can help. Most of the posts I read said that if you don't have to upgrade, you're better off not doing it. 1
chef 3811 Posted January 19, 2017 Posted January 19, 2017 Okay! It's getting late now, but we should start first thing in the morning. could you please copy and paste the unit information that is returned by that link, and PM me with the JSON string. I need to start building classes tonight so we can get you back up and running by tomorrow. And because it is a reverse look up on your system, best not post anything on this thread.
tp546 41 Posted January 19, 2017 Author Posted January 19, 2017 Okay! It's getting late now, but we should start first thing in the morning. could you please copy and paste the unit information that is returned by that link, and PM me with the JSON string. I need to start building classes tonight so we can get you back up and running by tomorrow. And because it is a reverse look up on your system, best not post anything on this thread. Done. Thanks. 1
PrincessClevage 175 Posted January 19, 2017 Posted January 19, 2017 Gentlemen I went to add the Vera plugin for Emby server and it is no longer listed, is this by design? 1
chef 3811 Posted January 19, 2017 Posted January 19, 2017 (edited) We had to remove it temporarily while we build a compatible version for Vera UI5. We'll have it back in the catalogue tonight. @@PrincessClevage Edited January 19, 2017 by chef 1
PrincessClevage 175 Posted January 20, 2017 Posted January 20, 2017 Plugin is working great, except I can't get the pause un pause scenes to work on movie with ET to work, any one have these working? P.s I'm using the same scene as start movie and stop movie for pause functions and the scenes work with start/stop movie
Alain Falardeau 0 Posted January 20, 2017 Posted January 20, 2017 (edited) @@PrincessClevage same here... but while looking at the logs I saw an "event" or "command" when a movie starts which seems to trigger the plugin to run the MoviePlay scene... same thing for the MovieStop scene... but there doesn't seem to be any such status (or event or command) generated by Emby Theater when pausing a movie in order to trigger the PauseMovie scene??? So I assumed it's not possible at the moment? But I'm not a programmer nor a developer so what do I know? Edited January 21, 2017 by Alain Falardeau
PrincessClevage 175 Posted January 21, 2017 Posted January 21, 2017 We had to remove it temporarily while we build a compatible version for Vera UI5. We'll have it back in the catalogue tonight. @@PrincessClevage Hi Chef,Just curious if the pause u pause is some thing planned for future update ?
tdastrup 0 Posted January 24, 2017 Posted January 24, 2017 How do I refresh the plugin list? I must have installed Emby during the time this plugin had been removed from the catalog for development. I'm assuming it has gone live again, but I still don't see it in the plugin list. I can't see an option anywhere to manually refresh the plugin list either. Am I blind? What do I need to do to get the plugin to display in the catalog?
Happy2Play 9814 Posted January 24, 2017 Posted January 24, 2017 How do I refresh the plugin list? I must have installed Emby during the time this plugin had been removed from the catalog for development. I'm assuming it has gone live again, but I still don't see it in the plugin list. I can't see an option anywhere to manually refresh the plugin list either. Am I blind? What do I need to do to get the plugin to display in the catalog? "MiOSEmbyZWaveControllerCS" is in the catalog.
chef 3811 Posted January 25, 2017 Posted January 25, 2017 I'll look at the pause events. Because emby doesn't really contain "pause /unpause" events trough the plugin API. You have to monitor the playback and check if the session is paused or not. It isn't complicated but I was experiencing lights flashing during a paused movie so I commented out the code. I will give it another go! 1
PrincessClevage 175 Posted January 29, 2017 Posted January 29, 2017 How do I refresh the plugin list? I must have installed Emby during the time this plugin had been removed from the catalog for development. I'm assuming it has gone live again, but I still don't see it in the plugin list. I can't see an option anywhere to manually refresh the plugin list either. Am I blind? What do I need to do to get the plugin to display in the catalog?just restart emby server service (or app if that what's you run)
PrincessClevage 175 Posted January 29, 2017 Posted January 29, 2017 I'll look at the pause events. Because emby doesn't really contain "pause /unpause" events trough the plugin API. You have to monitor the playback and check if the session is paused or not. It isn't complicated but I was experiencing lights flashing during a paused movie so I commented out the code. I will give it another go! thanks Chef!
PrincessClevage 175 Posted February 1, 2017 Posted February 1, 2017 (edited) Looks like the Chef has served up another great dish and the latest release is now working with pause and unpause/play with my system. Thanks again Chef! Edited February 1, 2017 by PrincessClevage
PrincessClevage 175 Posted April 14, 2017 Posted April 14, 2017 I'll look at the pause events. Because emby doesn't really contain "pause /unpause" events trough the plugin API. You have to monitor the playback and check if the session is paused or not. It isn't complicated but I was experiencing lights flashing during a paused movie so I commented out the code. I will give it another go! hi Chef Since the last emby server update I seem to have lost my save profile in the Mios app. I have save a new profile but no scenes are triggering on the Vera unit. I have checked the scenes and can manually trigger them and they also display in ET app correctly. Is your app still working?
chef 3811 Posted April 14, 2017 Posted April 14, 2017 I'll check it out @@PrincessClevage All my scenes have been set to the Xbox theater so I haven't used them lately... Ahhrrmmmm....
chef 3811 Posted April 14, 2017 Posted April 14, 2017 I'm not seeing any problems here. What does your plugin configuration look like? "plugins\configuration\MiOsZWaveController.xml"
