tocks 4 Posted January 3, 2017 Posted January 3, 2017 Hello, I also have an hdhomerun. How do you configure emby to retrieve guides? Hdhomerun retrieves the guides on their own.Why does emby not get the guides all alone? Are we obliged to go through an external service in xml?
ebr 16335 Posted January 3, 2017 Posted January 3, 2017 Hi. You can use Schedules Direct or an XML source if you have one. We do not have access to the guide information on the HDHR device itself. Please see: Live TV and let us know if you have more questions. Thanks.
tocks 4 Posted January 3, 2017 Author Posted January 3, 2017 thanks, for your reply. But i am in french and Schedules Direc don't send guide for EUROPE. i have test tvheadend ans it's find alone the guide. Emby can not do the same? Do you know an xml stream for france with pictures? Thanks,
Luke 42242 Posted January 3, 2017 Posted January 3, 2017 Hi @@tocks, I'm sure there are xmltv sources available for France. http://mythtv-fr.org/wiki/comparatif_grabber
tocks 4 Posted January 5, 2017 Author Posted January 5, 2017 thanks a lot, I have find with your link a epg http://xmltv.dtdns.net/alacarte/ But, i's ok if a download the xml in local. But if a tahe the url of my xml, emby don't update the liste http://xmltv.dtdns.net/alacarte/ddl?fichier=/xmltv_site/xmlPerso/tocksfr.xml Can you confirm that this link is ok for emby ?
tocks 4 Posted January 6, 2017 Author Posted January 6, 2017 but it's not ok for me. Where are download the xml file in emby ? I am on synology I want to check that the file downloaded by emby is good.
Luke 42242 Posted January 6, 2017 Posted January 6, 2017 It's not in a format where you can easily access it. Best thing to do is refresh the guide and then attach the complete emby server log. thanks.
tocks 4 Posted January 13, 2017 Author Posted January 13, 2017 It works perfect now thank you. You can close the post
