wzzly 0 Posted March 1, 2019 Posted March 1, 2019 Is it possible that the official synologyy media server package installed this version? I installed it after emby server. Because I thought it was maybe needed for HW transcoding.
Luke 42243 Posted March 1, 2019 Posted March 1, 2019 OK can you undo the hack? Emby ships it's own ffmpeg. Thanks.
wzzly 0 Posted March 1, 2019 Posted March 1, 2019 How because in the first post it says I need to do the hack to get HW transcoding on my ds214play...?
solabc16 379 Posted March 5, 2019 Author Posted March 5, 2019 Hello @@wzzly The h/w transcoding available on 'evansport' based Synology systems, is essentially proprietary. The FFmpeg changes needed to support the transcoding h/w available did not find their way back into the open source project. I've discussed this elsewhere, for example : https://emby.media/community/index.php?/topic/43282-hw-transcoding-on-evansport-ds415playds214play-machines/?p=443715 So this 'workaround' / 'hack' was developed in response to user demand, as you'll see through the evolution of this thread amongst others. It's certainly not clean and there are probably steps we could take to improve it, but it really is a 'best efforts'. Essentially what the instructions mentioned here do, is allow the version of FFmpeg being used by Emby Server to be switched on the fly, so if you have content that can take advantage of the h/w transcoding capabilities offered by the 'evansport' based systems you can try it out and see if it works for you. From Emby Server's perspective, the platform does not provide h/w transcoding support through any of the typical interfaces, which on Synology means the VA-API. Best - James
jacs 0 Posted June 3, 2019 Posted June 3, 2019 Hi, I have installed Emby Server onto my Synology DS214play to try out your hardware transcoding, and have two questions please: Does this require a Emby Premiere License to work? Does DTS sound playback with this? Thank you.
Luke 42243 Posted June 3, 2019 Posted June 3, 2019 Hi, I have installed Emby Server onto my Synology DS214play to try out your hardware transcoding, and have two questions please: Does this require a Emby Premiere License to work? Does DTS sound playback with this? Thank you. Hi, for hardware transcoding yes, and yes, dts sound is supported. 1
jacs 0 Posted June 3, 2019 Posted June 3, 2019 Hi, for hardware transcoding yes, and yes, dts sound is supported. Hi again and thanks for your reply, I have been trying it out without a Premier License and DTS is not playing back unless I disable the H/W transcoding, is that supposed to happen?
Luke 42243 Posted June 3, 2019 Posted June 3, 2019 Hi again and thanks for your reply, I have been trying it out without a Premier License and DTS is not playing back unless I disable the H/W transcoding, is that supposed to happen? No, let's look at an example. Please see how to report a media playback issue. thanks !.
jacs 0 Posted June 4, 2019 Posted June 4, 2019 Hi, I am having no problems playing back my music files, some of my films play back with sound (aac files) but none of my DTS & some AC3 films will playback with sound, the picture quality is perfect. Everything played back perfectly before doing the H/W Transcoding I am including the ffmpeg-remux log...I hope that is correct? ffmpeg remux log.rtf
jacs 0 Posted June 11, 2019 Posted June 11, 2019 Nothing from anybody, so I am assuming it is a no go on my Synology DS214Play?
sonny_life 2 Posted June 11, 2019 Posted June 11, 2019 Nothing from anybody, so I am assuming it is a no go on my Synology DS214Play? As far as I remember there is no DTS sound with emby and H/W transcoding enabled.
patje57 9 Posted June 11, 2019 Posted June 11, 2019 Nothing from anybody, so I am assuming it is a no go on my Synology DS214Play? Didn't get the H/W transcoding workaround working with DTS sound on DS415play either. So indeed a no go on DS214play / DS415play. All other formats are working well with the H/W transcoding workaround thou. There may other work arounds avaible, i stopped googling as DTS isn't really an issue for me. I'm good with this solution.
Luke 42243 Posted June 11, 2019 Posted June 11, 2019 As far as I remember there is no DTS sound with emby and H/W transcoding enabled. This isn't true, that is mis-information, and that log isn't using hardware acceleration anyway so even then it would be inapplicable.
Luke 42243 Posted June 11, 2019 Posted June 11, 2019 Hi, I am having no problems playing back my music files, some of my films play back with sound (aac files) but none of my DTS & some AC3 films will playback with sound, the picture quality is perfect. Everything played back perfectly before doing the H/W Transcoding I am including the ffmpeg-remux log...I hope that is correct? ffmpeg remux log.rtf What Emby app are you playing from here?
sonny_life 2 Posted June 11, 2019 Posted June 11, 2019 This isn't true, that is mis-information, and that log isn't using hardware acceleration anyway so even then it would be inapplicable. Sorry to disappoint you, but I already reported DTS playback issues on page 2 in this thread. DTS sound never worked with my DS214play in any of the versions that I tried.
jacs 0 Posted June 12, 2019 Posted June 12, 2019 Hi, I have Ember Server 4.1.1.0-1 on my Synology DS214play and hear no sound when playing back files on either my web browser (Safari & Chrome Emby mobile 4.1.1.0) or on my Apple TV4K. As I wrote earlier, no problems before doing the H/W transcoding workaround.
jacs 0 Posted June 13, 2019 Posted June 13, 2019 Don't worry about answering my questions anymore as I am deleting it from my server, thanks to those who tried to help.
Luke 42243 Posted June 13, 2019 Posted June 13, 2019 I would suggest trying again with the next release as there is another round of hardware transcoding improvements. Thanks. 1
patje57 9 Posted June 14, 2019 Posted June 14, 2019 I would suggest trying again with the next release as there is another round of hardware transcoding improvements. Thanks. Luke, are you saying you're considering enabling standard H/W transcoding on Evansport? At least this is how i tend to understand your answer. I've always understood neither Emby nor the others have that on their list, I believe due to the processor not supporting VAAPI
jmassaro87 28 Posted November 25, 2019 Posted November 25, 2019 Is this still necessary? Or are we to a point where it is built in to the SW package? Just got my DS418play up and running.
Luke 42243 Posted November 25, 2019 Posted November 25, 2019 Hi there, have you checked out our hardware acceleration setup guide: https://github.com/MediaBrowser/Wiki/wiki/Hardware-Acceleration-Overview ?
jmassaro87 28 Posted November 25, 2019 Posted November 25, 2019 Hi there, have you checked out our hardware acceleration setup guide: https://github.com/MediaBrowser/Wiki/wiki/Hardware-Acceleration-Overview ? I Have. Not even sure what my device falls under. Linux i know but thats about it. Running a test right now. Streaming a movie from work. It is transcoding, NAS CPU is right at about 40% so doesn't seem to be over taxing. Might not need to do anything?
Luke 42243 Posted November 27, 2019 Posted November 27, 2019 I Have. Not even sure what my device falls under. Linux i know but thats about it. Running a test right now. Streaming a movie from work. It is transcoding, NAS CPU is right at about 40% so doesn't seem to be over taxing. Might not need to do anything? Can we look at an example? thanks.
patje57 9 Posted November 30, 2019 Posted November 30, 2019 (edited) Is this still necessary? Or are we to a point where it is built in to the SW package? Just got my DS418play up and running. The workaround is normally not needed for DS418play. The DS418play doesn't have an Evansport type processor, but later generation Intel Celeron J3355 (same as in the DS218+) which should support HW transcoding out of the box, at least it does on DS218+. BR, Pat Edited November 30, 2019 by patje57 1
Luke 42243 Posted July 25, 2020 Posted July 25, 2020 For those interested in trying something new, please try this: Thanks !
