TFO2020 1 Posted January 2, 2017 Posted January 2, 2017 Hello all; Does Emby support external audio tracks? Say for example I have a video in MKV format that has a few audio streams in it, and I also have an external audio stream in AC3 format for the same video file. Is there a way to configure Emby to expose the external audio track to the cleints and allow it to be selected instead of one of the intenral audio streams in the MKV file? Thanks!
Luke 42246 Posted January 2, 2017 Posted January 2, 2017 Hi, can you please discuss some examples? thanks.
TFO2020 1 Posted January 3, 2017 Author Posted January 3, 2017 (edited) Here are the media details from the Emby Web Client for one example. Video Codec H264AVC YesProfile HighLevel 41Resolution 1920x800Aspect ratio 2.40:1Anamorphic NoInterlaced NoFramerate 23.97602Bitrate 6009 kbpsBit depth 8 bitPixel format yuv420pRef frames 5NAL 4 Audio Language engCodec DCAProfile DTSLayout 5.1Channels 6 chBitrate 1536 kbpsSample rate 48000 HzBit depth24 bitDefault YesTitle Eng Surround Sound Subtitle Language engCodec SRTDefault NoForced NoExternal YesTitle Eng Subtitle Language freCodec SRTDefault NoForced NoExternal YesTitle Fre Subtitle Language spaCodec SRTDefault NoForced NoExternal YesTitle Spa Subtitle Language SpanishCodec SRTDefault NoForced NoExternal YesTitle Spanish Container mkv So this is a MKV video with a 6 channel DTS audio track, and Spanish sub titles in the MKV, Then there are English, French, and Spanish external SRT subtitles. I have a AC3 audio track that is external with the .AC3 extension. I would like for the Server to identify the .AC3 external audio track and list it here just like the external subtitles. During playback I would like to be able click the music note icon in the top right corner to select from the MKV internal audio track, or the external .AC3 audio track just like I can for the subtitles where I can select from the internal Spanish subtitles or the external .SRT subtitle files. My goal is to be able to provide external multi-channel audio tracks for some videos that only have stereo audio tracks internal to the container. I hope this makes more sense. Thanks! Edited January 3, 2017 by TFO2020
ebr 16338 Posted January 3, 2017 Posted January 3, 2017 And what is the source of this external audio track?
Solution Luke 42246 Posted January 3, 2017 Solution Posted January 3, 2017 It's in an .ac3 file so that would be a whole new paradigm for us. If there's adequate demand then it's definitely possible. Keep in mind this sort of thing will almost always require the server to convert the media on the fly as most players will not be able to support external audio, even if they already support ac3. If you don't care about this then it's not really a problem, but if you're interested in efficiency then you'll want to just embed the audio into the track. 1
TFO2020 1 Posted January 4, 2017 Author Posted January 4, 2017 Thank you for the feedback. For my purposes I don't think transcoding would be an issue. I would assume the default audio track would be the internal stereo track, so unless a user explicitly selects the external audio track no transcoding would be required. It would be nice to have the option to use the external multi-channel audio if desired. The does however answer my question. It would be awesome to see this feature implimented, but for now I will explore other alternatives. Thank you for all the work you do and for creating an amazing projuct. I'm proud to be a Premiere supporter.
Happy2Play 9814 Posted January 4, 2017 Posted January 4, 2017 Why don't you just add the track to the mkv with mkvmerge? It can be done is seconds. 2
shrouski 7 Posted April 18, 2019 Posted April 18, 2019 Hi All Did this get any further? There are many reasons for not wanting to touch the MKV/MP4 files for seeding. An on the fly Remux using an external .mka for example should ideally be possible. I've just tried and it seems it's not currently possible. Thanks
MrL0c0 0 Posted January 20, 2020 Posted January 20, 2020 to add external audio playback is the development ongoing?
Luke 42246 Posted January 20, 2020 Posted January 20, 2020 Hi, it's not something we've looked at up to this point. It's possible for the future. Thanks.
arianx999 0 Posted April 18, 2021 Posted April 18, 2021 it is possible to add external audio to file by using mkvtoolnix but if you have a large library of these files it takes time for ever please add this feature tnx
Carlo 4561 Posted April 19, 2021 Posted April 19, 2021 How/where do these external audio tracks come from? In the couple of decades of using media servers I've never come across this before. I think many of us are trying to understand the use case for this.
rbjtech 5345 Posted April 19, 2021 Posted April 19, 2021 11 hours ago, arianx999 said: it is possible to add external audio to file by using mkvtoolnix but if you have a large library of these files it takes time for ever please add this feature tnx A quick batch script to add via mkvtoolnix CLI will automate this operation or you can use ffmpeg to demux, add the track and remux if that suits you better. I'm with the other though, unless you are converting an existing track to a different format for compatibility reasons (say adding an AAC track from an existing DTS track), then I've never seen audio only tracks being available to 'append' to existing AV media. Is there an 'Audio' version of the subtitle providers that we are unaware of ? 1
dolpsdw 2 Posted November 29, 2021 Posted November 29, 2021 (edited) On 4/19/2021 at 5:03 AM, cayars said: How/where do these external audio tracks come from? In the couple of decades of using media servers I've never come across this before. I think many of us are trying to understand the use case for this. This could be useful when you want to have the original 5.1 7.1 mkv with all the original stuff. And you want to add more friendly audio streams (2.0_fdk) without touching the original mkv. I googled the feature just to check if it was a thing, and find this thread. Edited November 29, 2021 by dolpsdw
Carlo 4561 Posted November 29, 2021 Posted November 29, 2021 While it might be a thing, it obviously has never gained any popularity. It's just to easy to remux the original file to add any additional tracks you might need. Then it should be 100% compatible with any software you use.
rbjtech 5345 Posted November 30, 2021 Posted November 30, 2021 As a technical exercise - this works just fine as ffmpeg can accept multiple input files - you just need to map them accordingly. This is working just fine in emby using an EXTERNAL AC3 file .. (see below for a stripped down ffmpeg transcode log with all the important bits highlighted) But while technically it's easy to do - to accommodate this into Emby as a supported function is a totally different challenge... Quote >>>>>> DIAGNOSTIC OPTIONS ACTIVE !!! Warning CommandLineOptions.SearchText: Original: Actual: -i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.mkv" -map 0:0 -map 0:1 Warning CommandLineOptions.ReplaceText: Original: Actual: -i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.mkv" -i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.AC3" -map 0:v -map 1 !!!WARNING!!! Applied Diagnostic Command Line Change: '-i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.mkv" -map 0:0 -map 0:1' >> '-i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.mkv" -i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.AC3" -map 0:v -map 1' Original: -y -print_graphs_file "D:\Emby-Server-Beta\programdata\logs\ffmpeg-transcode-c7de82dd-dab8-4ced-a51d-a95d10f46154_1graph.txt" -copyts -start_at_zero -init_hw_device "qsv=qd0:hw,child_device=0,qsv_use_dx11=1" -f matroska,webm -c:v:0 h264_qsv -hwaccel:v:0 qsv -i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.mkv" -map 0:0 -map 0:1 -sn -c:v:0 h264_qsv -b:v:0 4808001 -g:v:0 72 -maxrate:v:0 4808001 -bufsize:v:0 9616002 -sc_threshold:v:0 0 -level:v:0 40 -keyint_min:v:0 72 -r:v:0 23.976024627685547 -profile:v:0 high -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "d:\Emby\transcoding-temp\48C21C.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "d:\Emby\transcoding-temp\48C21C_%d.ts" Modified: -y -print_graphs_file "D:\Emby-Server-Beta\programdata\logs\ffmpeg-transcode-c7de82dd-dab8-4ced-a51d-a95d10f46154_1graph.txt" -copyts -start_at_zero -init_hw_device "qsv=qd0:hw,child_device=0,qsv_use_dx11=1" -f matroska,webm -c:v:0 h264_qsv -hwaccel:v:0 qsv -i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.mkv" -i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.AC3" -map 0:v -map 1 -sn -c:v:0 h264_qsv -b:v:0 4808001 -g:v:0 72 -maxrate:v:0 4808001 -bufsize:v:0 9616002 -sc_threshold:v:0 0 -level:v:0 40 -keyint_min:v:0 72 -r:v:0 23.976024627685547 -profile:v:0 high -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "d:\Emby\transcoding-temp\48C21C.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "d:\Emby\transcoding-temp\48C21C_%d.ts" D:\Emby-Server-Beta\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "D:\Emby-Server-Beta\programdata\logs\ffmpeg-transcode-c7de82dd-dab8-4ced-a51d-a95d10f46154_1graph.txt" -copyts -start_at_zero -init_hw_device "qsv=qd0:hw,child_device=0,qsv_use_dx11=1" -f matroska,webm -c:v:0 h264_qsv -hwaccel:v:0 qsv -i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.mkv" -i "\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.AC3" -map 0:v -map 1 -sn -c:v:0 h264_qsv -b:v:0 4808001 -g:v:0 72 -maxrate:v:0 4808001 -bufsize:v:0 9616002 -sc_threshold:v:0 0 -level:v:0 40 -keyint_min:v:0 72 -r:v:0 23.976024627685547 -profile:v:0 high -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "d:\Emby\transcoding-temp\48C21C.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "d:\Emby\transcoding-temp\48C21C_%d.ts" 12:22:00.101 Input #0, matroska,webm, from '\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.mkv': 12:22:00.123 Input #1, ac3, from '\\media\Films\Air Force One (1997)\Air Force One (1997) - 1080p x264 AC3.AC3': 12:22:00.123 Stream mapping: 12:22:00.123 Stream #0:0 -> #0:0 (h264 (h264_qsv) -> h264 (h264_qsv)) 12:22:00.123 Stream #1:0 -> #0:1 (ac3 (native) -> mp3 (libmp3lame)) 12:22:00.409 Stream #0:1(eng): Audio: mp3, 48000 Hz, stereo, fltp, 192 kb/s (default) 12:22:00.409 Metadata: 12:22:00.409 encoder : Lavc59.12.100 libmp3lame 12:22:00.409 elapsed=00:00:00.28 frame= 1 fps=0.0 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 12:22:00.633 [segment @ 00000283c0300cc0] Opening 'd:\Emby\transcoding-temp\48C21C.m3u8.tmp' for writing 12:22:00.634 SegmentComplete=video:0 Index=0 Start=0.000000 End=3.003000 Duration=3.003000 offset_pts=0 start_pts=0 Frames=72 filename=48C21C_0.ts 12:22:00.634 [segment @ 00000283c0300cc0] Opening 'd:\Emby\transcoding-temp\48C21C_1.ts.tmp' for writing 12:22:00.862 [segment @ 00000283c0300cc0] Opening 'd:\Emby\transcoding-temp\48C21C.m3u8.tmp' for writing 1 1
semioniy 4 Posted May 6, 2022 Posted May 6, 2022 For those who don't see the point in this functionality, you may have not consumed a lot of media with fan-dubs Here's a use-case I have: Movies/series with english audio track embedded in .mkv / .mpg / .mp4 / whatever else Anime with original japanese dub in .mkv / .avi / .mp4 / whatnot + external audio tracks in a subfolder with naming scheme like "./<language> sound/<particular dub>", e.g. "./Rus sound/[Anilibria]/", mostly in .mka format Merging these files would certainly be possible, but then I wouldn't be able to seed through torrents (only legal stuff, of course). I'd totally benefit from emby being able to do that, and so would do a bunch more people that watch media not recorded/produced/licensed in their native language. 1
Carlo 4561 Posted May 6, 2022 Posted May 6, 2022 (edited) The disc format needed for seeding files is quite different from the recommended guide lines used for Emby or other media servers. Regardless of the source of the media, best practices used for streaming servers will use common formats that work optimally for clients you support. That could be standardizing on H.264 or H.265 video, making sure a 2 channel AAC or AC3 audio track is present. Removing audio & subtitle tracks that aren't needed or wanted. Adding missing subtitles that are needed for your users. Making sure all codecs and formats used are compatible with client apps your server streams to, etc. There are many tools built into Emby server to convert/manipulate your media for optimal streaming to many different clients as well as lower resource uses when streaming. These tools can rename files, add files as well as change or replace files. Some people use a pipeline outside of Emby to standardize their media before adding it to Emby. In either case the resulting file sets can be quite different than what they started as. Emby should not be bound nor use files as typically found in unpacked seeds as is, since they are often not optimal for streaming. If this is something you or others want to do, that's your business but you should allocate separate storage for these two drastically different purposes so each can be optimized for it's specific purpose. Trying to use shared storage to accommodate both purposes is a poor design choice that can never be optimal for either purpose and put artificial limitations on what you can and can't do causing you to start making compromises in how you handle things since your first priority is what's on disc instead of how your system streams content. Some of the formats used for specific genres typically found in seeds do not follow streaming standards, they use codecs that shouldn't be used with the container they are found in often using bitrates that shouldn't be used. These types of files used as is can cause all kinds of grief for streaming servers as they won't be supported by most clients. If lucky the Emby Server may be able to transcode files on the fly to make them compatible with industry standards and the different devices Emby Supports. These kinds of compromises further box you in, ultimately requiring special handling for processes that otherwise are simple to accomplish. Adding an additional audio track is a perfect example. The correct way to handle this and have files that meet industry standards and be playable by different clients is to add the track directly to the media where it can by properly synced to the video. Trying to find or create an alternate solution for a self created problem that goes against standard practices and not supported by any media standards is self defeating. Separate your storage for each purpose, so never the two shall meet and then optimize each for it's intended purpose. That could mean you need to expand your storage or even double it but comes with the territory. While not a true backup (1 to 1 files) it might help to think about the alternate source of files your version of media backup (that needs reprocessing). Edited May 7, 2022 by cayars 1
semioniy 4 Posted May 6, 2022 Posted May 6, 2022 Can't say this wasn't a bit passive-aggressive, but definitely insightful, so thank you for the response. 1
Luke 42246 Posted May 6, 2022 Posted May 6, 2022 Please note that doesn't determine whether we'll support it or not. In fact I think it's a reasonable request . But when we might actually do it depends on how many people want it compared to other things.
Carlo 4561 Posted May 7, 2022 Posted May 7, 2022 19 hours ago, semioniy said: Can't say this wasn't a bit passive-aggressive, but definitely insightful, so thank you for the response. I had just got done helping someone who was rather demanding and adamant we change our software so he didn't have to follow our naming guide and could keep his crazy layout /genre/year/director/movie or show. Besides, there's quite a difference between that and a polite feature request so I'm sorry for tone, but know it wasn't really directed at you. PS removed the top line so it's a bit less snarky. 1 1
