CalypsoCowboy 4 Posted January 2, 2017 Posted January 2, 2017 I apologize a head of time, there have been Window's patches, unRAID version changes, and Emby updates, system restarts so I don't know when these errors started occuring. My movies and music are setup on a separate unRAID server and the shares are setup so that Public can see them. The only users setup on the server are root, test, and mymovies user. I'm running Emby 3.1.2, installed as my main user, on a Windows 10 Home box that is patched at currently levels. Emby is normally setup to run as a service, with it setup to logon as "local system". I've got it setup on a Delayed Start and it seems like only recently I've had problems. I don't have the logs of when the problem started. What I currently see happening is that when the service starts the Library Monitor isn't able to find or see the network path 2017-01-01 10:11:12.1244 Error LibraryMonitor: Error watching path: \\cascade\Movies *** Error Report *** Version: 3.1.2.0 Command line: C:\Users\Josh\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe -service Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Josh\AppData\Roaming\MediaBrowser-Server Application directory: C:\Users\Josh\AppData\Roaming\MediaBrowser-Server\System System.ArgumentException: The directory name \\cascade\Movies is invalid. at System.IO.FileSystemWatcher..ctor(String path, String filter) at Emby.Server.Core.IO.LibraryMonitor.<>c__DisplayClass38_0.<StartWatchingPath>b__0() System.ArgumentException at System.IO.FileSystemWatcher..ctor(String path, String filter) at Emby.Server.Core.IO.LibraryMonitor.<>c__DisplayClass38_0.<StartWatchingPath>b__0() When I stop the service, and just run the server from the desktop, it is able to see the directory. 017-01-01 10:24:28.6962 Info LibraryMonitor: Unable to add directory watcher for \\cascade\Movies. It already exists in the dictionary.2017-01-01 10:24:28.6962 Info HttpClient: HttpClientManager POST: http://192.168.0.1:54312017-01-01 10:24:28.6962 Info LibraryMonitor: Watching directory \\cascade\Movies2017-01-01 10:24:28.7118 Info HttpClient: HttpClientManager POST: http://192.168.0.1:5431 I've attached the log files from a service and desktop starts. -Josh server-63618862258-service.txt server-63618863060-desktop.txt
Solution ebr 16307 Posted January 2, 2017 Solution Posted January 2, 2017 Did you configure credentials for the service? Unable to access media when running server as a service 2
Deathsquirrel 745 Posted January 2, 2017 Posted January 2, 2017 When running as a service and accessing files by UNC path, \\cascade\movies in your log, the service should not be running under the account Local System. It doesn't have the rights uou need. Change the service to run under your user account or some other user with rights to \\cascade\movies. 1
CalypsoCowboy 4 Posted January 3, 2017 Author Posted January 3, 2017 I could have swore I had it running before with Local System, but maybe not. Thanks for the information. I need to do some changes, but will set it up with an appropriate user. -Josh
Happy2Play 9801 Posted January 3, 2017 Posted January 3, 2017 If everything was on the same machine then "Local System" would work fine, but everything is external so specific user logon is needed.
