schmitty 66 Posted January 2, 2017 Posted January 2, 2017 Hello, I would like to know which 3D format tag I should use for 3D Blu-Ray rips
Oxide 139 Posted January 2, 2017 Posted January 2, 2017 Check out the Wiki here: https://github.com/MediaBrowser/Wiki/wiki/3D-videos
schmitty 66 Posted January 2, 2017 Author Posted January 2, 2017 (edited) I have read that. I don't know which is the correct format though. According to this post, Blu-Ray 3D is known as FHD3D. Perhaps, this could be added to the detection. Edited January 2, 2017 by schmitty
Luke 42186 Posted January 2, 2017 Posted January 2, 2017 Can you explain more about what you don't understand? thanks !
schmitty 66 Posted January 2, 2017 Author Posted January 2, 2017 I just don't know which is the correct tag I should use, as I believe Blu-Ray 3D format is different to the options Emby detects.
Happy2Play 9801 Posted January 2, 2017 Posted January 2, 2017 @@Luke I don't have any 3d material but does it truly matter which one you select? Does Emby do anything different besides identifying the media a 3D?
Luke 42186 Posted January 2, 2017 Posted January 2, 2017 it will have some effect on image extraction.
Waldonnis 148 Posted January 2, 2017 Posted January 2, 2017 If it's a straight copy from a 3D BR disc, then it's likely MVC. Note that not all software players support MVC, but it's gotten better recently. Worst case, ffprobe will probably detect it, so you could try adding it without a suffix and see what the media info looks like (or just ffprobe manually/check with MediaInfo if you're on Windows), then just rename/re-add it afterward. 2
schmitty 66 Posted January 2, 2017 Author Posted January 2, 2017 I just had a look at Minions 3D in MakeMKV, and the video format is actually Mpeg4 MVC. Now that I know this, should the file tag be 3D-MVC, or should it be something else? 1
Waldonnis 148 Posted January 3, 2017 Posted January 3, 2017 I just had a look at Minions 3D in MakeMKV, and the video format is actually Mpeg4 MVC. Now that I know this, should the file tag be 3D-MVC, or should it be something else? That should do it. From the wiki, this example would be appropriate: moviename-3D.mvc.mkv 1
