riccote 2 Posted January 2, 2017 Posted January 2, 2017 (edited) Live TV works on Android Apps and firestick, but not in any web browsers. It just has a spinning circle. I've tried them all and on different computers, local and remote. No error messages. Do I have to install a service/ Live TV plugin? Emby Version 3.1.0.0 on FreeNas Tuner : HDHR4-2US Edited January 2, 2017 by riccote
Luke 42242 Posted January 2, 2017 Posted January 2, 2017 Hi there @@riccote ,we're sorry to hear about this. Can you please provide the information requested in how to report a media playback issue? thanks !
riccote 2 Posted January 2, 2017 Author Posted January 2, 2017 Logs attached. ffmpeg-transcode-ebbb850c-222f-4bd8-9ef9-883099f148f1.txt server-63618825599.txt
Luke 42242 Posted January 2, 2017 Posted January 2, 2017 @@riccote, how did you install emby server? in other words, what package is this? it looks like there's a problem with your ffmpeg build. thanks !
Luke 42242 Posted January 2, 2017 Posted January 2, 2017 @@josh4trunks, what do you make of this error? thanks !
Luke 42242 Posted January 2, 2017 Posted January 2, 2017 @@riccote I see similar errors all the time when I choose to rebuild ffmpeg for the plugin. The plugin should have all libraries in /usr/pbi/emby-amd64/lib but since this is not normally searched they need to be linked to a standard location (/usr/local/lib). The 'external-links' file does that during the PBI build process. https://github.com/josh4trunks/freenas-plugins/blob/master/plugins/emby/external-links I see that my plugin jail came with the 'libiconv' package already installed, so that is probably why I didn't need to add that link for the plugin's ffmpeg to work. Either this user deleted packages from their plugin jail, or the plugin jail has been updated and no longer comes with this package. A workaround is either to install libiconv, or to run.. ln -s /usr/pbi/emby-amd64/lib/libiconv.so.3 /usr/local/lib 1
