Luke 42237 Posted February 13, 2017 Posted February 13, 2017 Emby Theater fully supports a TV remote, FYI.
nairnmonster 6 Posted February 13, 2017 Posted February 13, 2017 (edited) Emby Theater fully supports a TV remote, FYI.Oh... that changes things massively. What about live TV support with BGT tuner cards? Also, recording TV ability? Edited February 13, 2017 by nairnmonster
Luke 42237 Posted February 13, 2017 Posted February 13, 2017 You can do that with a live tv plugin from our catalog. For out of box Emby support...stay tuned.
nairnmonster 6 Posted February 13, 2017 Posted February 13, 2017 You can do that with a live tv plugin from our catalog. For out of box Emby support...stay tuned. Last question, how is media played with the Emby Theater app. Does it use local codecs and play direct or is it streamed?
nairnmonster 6 Posted February 13, 2017 Posted February 13, 2017 Last question, how is media played with the Emby Theater app. Does it use local codecs and play direct or is it streamed? I lied, I have others haha. How is the media played when using Emby Theater, direct or streamed? Can the Emby ios app be used to scheduled recordings, series links? Is there a EPG search funcation? Can custom channel icons be used on the EPG? Thanks
Luke 42237 Posted February 13, 2017 Posted February 13, 2017 The Windows version embeds LAV filters and will direct play everything. Yes, all of our mobile apps can be used to schedule recordings. EPG search coming soon. Channel icons, yes.
nairnmonster 6 Posted February 13, 2017 Posted February 13, 2017 That's amazing, I think I might have an issue. My tuners are in the actual HTPC's. Not the server where Emby server is installed. I guess for the tuners to be used, Emby server needs to be installed on the machine with the tuner?
Luke 42237 Posted February 13, 2017 Posted February 13, 2017 Well Emby only currently natively supports HDHomerun network tuners. You can use your internal tuner by installing a Live TV plugin, which will add support for that tuner via external software. You can learn more about this in our Live TV wiki: https://github.com/MediaBrowser/Wiki/wiki/Live%20TV In the future we hope to improve this such that the external software will not be needed. Thanks. 1
nairnmonster 6 Posted February 13, 2017 Posted February 13, 2017 I had a look and a quick play, but because I don't have an EP subscription I was unable to test the Emby Theater app to see if I can access my Tuner. I did install some of the plugins and follows instructions but unable to test. Does seem like a lot of work to get the end result I already have if you get me. My EPG on WMC is now run with EPG123 + Schedules Direct and is much better than with the unreliable WMC EPG data. Also, having the Emby app within MCE is my desiered system. Emby theater is much faster, and also visually stuning. But having to set up all TV again plus buy an Emby sub and pay additional for the 3rd party application, just don't know if it's worth the work just to have actor images load faster. Will wait and see what can be done within Emby for what you suggest for the future. Thanks for all your help and time.
nairnmonster 6 Posted February 14, 2017 Posted February 14, 2017 I bought a subscription today to test ET. It's nice, fast and looks great. But the TV side of it is limited compaired to WMC. So looks like im going to stick with WMC for TV and EMC for media. If I could just get the cast images to load at an acceptable time I would be completely happy with EMC.
Luke 42237 Posted February 15, 2017 Posted February 15, 2017 The TV features in ET will be changing very soon.
nairnmonster 6 Posted February 15, 2017 Posted February 15, 2017 What about the actor\cast images loading faster? Is this something that can be resolved? Is there a way to store the images on the HTPC for local access like MB2, would this work better?
Luke 42237 Posted February 27, 2017 Posted February 27, 2017 Does the latest server help at all? The issue is mostly in EMC but as the server gets faster it may help improve this (even if only a little). Also make sure to check this out: https://emby.media/community/index.php?/blog/1/entry-355-emby-for-ps4-updated-with-new-live-tv-screens/ It's about PS4 but relates to other platforms as well. Thanks.
d00zah 152 Posted February 27, 2017 Posted February 27, 2017 Sadly, no. Actor images still load very slowly. Chapter images, however, are nearly instantaneous.
nairnmonster 6 Posted February 27, 2017 Posted February 27, 2017 Does the latest server help at all? The issue is mostly in EMC but as the server gets faster it may help improve this (even if only a little). Also make sure to check this out: https://emby.media/community/index.php?/blog/1/entry-355-emby-for-ps4-updated-with-new-live-tv-screens/ It's about PS4 but relates to other platforms as well. Thanks. No sorry, exact same as before. But as d00zah stated, the chapter images load almost instantly.
Solution ebr 16332 Posted March 1, 2017 Solution Posted March 1, 2017 Set your update level in EMC to Dev and try updating to .308. 4
Teddy 100 Posted March 1, 2017 Author Posted March 1, 2017 (edited) Great work ebr, now the cast appears almost instantly, behaving like the rest of apps.Thanks again. (Just a question of curiosity, where the cache of EWMC photos are stored now?) Edited March 1, 2017 by Teddy
nairnmonster 6 Posted March 1, 2017 Posted March 1, 2017 Set your update level in EMC to Dev and try updating to .308. Brilliant, worked for me. Just like MB2 again in terms of performance. Thanks again.
ebr 16332 Posted March 1, 2017 Posted March 1, 2017 Great work ebr, now the cast appears almost instantly, behaving like the rest of apps. Thanks again. (Just a question of curiosity, where the cache of EWMC photos are stored now?) Thanks for confirming. The image cache is in the same place it has always been - programdata\mediabrowser-classic\imagecache 1
Overseer 66 Posted March 2, 2017 Posted March 2, 2017 Will this be pushed out to the other channels or should we all go to DEV? Thanks.
lurch9366 16 Posted March 9, 2017 Posted March 9, 2017 This fixed it for me as well. Thanks for keeping WMC alive!!!
Chubchuckle 2 Posted October 11, 2017 Posted October 11, 2017 Thank you! I was having the same the problem with cast as well. I have been a supporter since the early days of MB2 and I've tried mostly all the new front end apps for Emby. Nothing compares to EMC. Thank you guys again. 2
