vigilian 1 Posted January 1, 2017 Posted January 1, 2017 Hi, I had to activate the http connection to outside my network to be able to reach through ios app. Is that normal?
Solution Luke 42243 Posted January 1, 2017 Solution Posted January 1, 2017 Depends. Are you using the default self-signed cert? Unfortunately the iOS device will reject this and we can't currently override it. If you get a trusted cert such as LetsEncrpyt, then it should work. 1
vigilian 1 Posted January 3, 2017 Author Posted January 3, 2017 mmmh so it's because of the cert okey now I understand. I will try to make me up to date about let's encrypt when I have some time then
